Author Topic: Merged: Old Shapeways-related announcements  (Read 185925 times)
Offline ermeio
Re: coming soon
« Reply #150 on: June 21, 2015, 07:42:14 AM »
incredible, Bo!
it's spectacular
Re: coming soon
« Reply #151 on: June 21, 2015, 08:46:10 AM »
Beautifully done Bo, I'm sure that the fuel tank will be very popular.
Offline jknaus
Re: coming soon
« Reply #152 on: June 21, 2015, 09:14:32 AM »
Ah man, I just glued mine in. Sigh. Too late for this one but will order for the other Albies in the stash. Bo you're a Wizard :)
James
Offline Pgtaylorart
Re: coming soon
« Reply #153 on: June 21, 2015, 09:40:47 AM »
Nice 3d work, Bo! Is this Rhino?
George
Re: coming soon
« Reply #154 on: June 21, 2015, 12:29:03 PM »
Good grief Bo, it's gorgeous!
  • Moderator
Re: coming soon
« Reply #155 on: June 21, 2015, 09:50:11 PM »
Cheers guys :)
Justin, yes I plan to include a few extra caps.
George-- yes I did this in Rhino 5 (Mac), my first "real" project in it. All polysurfaces per the "Rhino way." I've come around to really liking it overall, though there are some features in Maya that I miss....
Re: 1:32 Teves & Braun Airfoil Radiator for Alb D.III/D.V/D.Va
« Reply #156 on: June 22, 2015, 12:42:09 AM »
The package arrived a couple of weeks ago and I have finally had an opportunity to  do some research. First the radiator photographed on enlarged drawings from the Windsock Albatros special. The drawings are used with permission and are Copyrighted by Albatros Publications and the late Ian stair.
se5 035_crop by Richard Geisler, on Flickr
As can be seen the radiator fits the drawing perfectly!
Here is the radiator sitting on top of the Roden DIII wing. (I noticed that my alignment is a tad too far forward but that being said the Roden molded in radiator is wider and longer chord wise). In addition the Part PE radiator matches the Roden version so it also is oversized.
se5 038_crop by Richard Geisler, on Flickr
The conclusion is that Bo's radiator is more accurate and of course much more finely detailed. Next up will be using the calipers to check wing and radiator depth/thickness. I will create a separate thread in under construction for the actual building portion.
« Last Edit: June 22, 2015, 12:50:12 AM by RAGIII »
  • Moderator
« Reply #157 on: June 22, 2015, 12:55:46 AM »
Thanks for sharing that Rick. My part is dimensionally based entirely on the WNW part, and indeed they appear to have gotten it right. It makes senses that the D.III radiator would be interchangeable, after all the D.V/a wings essentially were as well...
My question remains whether the D.II (wing-mounted) radiator was also interchangeable. I suspect they might be, but I confess I haven't done the research.
« Reply #158 on: June 22, 2015, 01:00:45 AM »
That is next on my agenda  8)
Re: coming soon
« Reply #159 on: June 22, 2015, 03:55:05 AM »
Awesome BO! You are making it WAY TOO TEMPTING to purchase an OAW DVa  :-\ If you did the parts to convert to a DV I would cease to resist!
Offline Umlaufmotor
Re: coming soon
« Reply #160 on: June 22, 2015, 04:08:30 AM »
Nice, verrrrrry nice........................................Do not forget the badges for "Benzin" and "Öl" on the top of the tank, Bo.
  • Moderator
Re: coming soon
« Reply #161 on: June 22, 2015, 04:20:53 AM »
There's no öl badge, (oil tank is up front, remember?) -- but there is a ZAK stamp and a serial number plate... :)
  • Moderator
Re: coming soon
« Reply #162 on: June 22, 2015, 04:25:09 AM »
Hmmm all that is really needed are aileron horns, horn fairings (kit ones are wrong anyway) and a pulley for the end of the control stick. The D.Va ailerons could be easily modified by anyone worthy of holding a razor saw...
Maybe!
Offline Umlaufmotor
Re: coming soon
« Reply #163 on: June 22, 2015, 06:00:45 AM »
Yes, I meant the Zak-stamp, Bo.
Oh - oh, my brain is getting old.....................  :-[
Offline Mark
Re: coming soon
« Reply #164 on: June 23, 2015, 04:13:03 AM »
Beauty of a fuel tank, Bo! Can't wait for it to hit the website  :)
Mark G
