Author Topic: Pair of Albatros D-Va's. Roden 1/72  (Read 15721 times)
Offline LukasTheLight
  • Addicted to Wingnuts...
Re: Pair of Albatros D-Va's. Roden 1/72
« Reply #45 on: June 01, 2015, 02:04:00 AM »
Great piece of skills going on here!!!  ;) It looks great!!!
Lukas
Lukas
Offline vincentm
« Reply #46 on: June 04, 2015, 08:27:56 AM »
Thanks Lukas. At last they look a bit more realistic after weathering the airframes and adding a coat of flat varnish.
The lower wings have been attached to the root-part under the fuselage. Udet's upperwing, which will lie upside down on the ground, was sprayed with a miw of flat varnish and sand paint, to make it a little dull:
Udet's fuslage has received the same treatment with a brush used vertically, which caused dust traces and broke up the too dark shade of the black paint. A final coat of flat varnish has been added.
The exhaust stack has been first painted burnt-metal, then polished and various washes of rust have been added onto the welding points.
The upperwings have received a dirty wash (black + brown oil) in the hinges and around the radiators. The mirror and radiator lever are visible too:
The Jasta 18 bird appearing rather clean on the pix, I've put a very light wash into the panel lines, mainly around the engine. Weapons are visible besides the perforated windscreen typical to this machine:
A bit of dirt around the tail surface hinges and horns. The overall look of lozenges is quite different with blue rather than salmon rib tapes:
The lower wings were glued with insuficient dihedral angle, so I had to raise-up the wing templates (visible here between the wings) in order to have enough height at the cabanes level. I will then have to remove the templates and slightly bend the soft lower wings in order to give them the good dihedral and glue the V-struts in place. The rigging will further help for rigidity.
To end up, the structure of the maintenance tent. Only the front half will be built, and the cutting plane was cut into cardboard. Then the tubular frame was made from Evergreen rods. The tent itself will be made from glued and painted cloth.
Offline Pgtaylorart
« Reply #47 on: June 04, 2015, 08:31:40 AM »
Excellent! Your two Albs are looking great! Your painting is spot on. They look much larger than 1/72.
George
Offline Thumbs up
« Reply #48 on: June 04, 2015, 09:21:21 AM »
Superb!
« Reply #49 on: June 04, 2015, 11:29:28 AM »
Beautiful work, Vincent! These will be real gems when they're finished.
« Reply #50 on: June 04, 2015, 11:43:19 AM »
Second this  8)
« Reply #51 on: June 04, 2015, 12:07:59 PM »
This is continuing to be a fascinating build to watch. Your techniques and results are awesome!
Offline frame
« Reply #52 on: June 04, 2015, 05:46:23 PM »
Great job!
I look forward to seeing the development of your work on the tent.
Оtherwise "Black beauty" is wonderful.
Best Regards
Hristo
Offline vincentm
« Reply #53 on: June 04, 2015, 08:35:20 PM »
Thank you all.
Sure, the black "LO" is definitely beautiful, I been thinking it's a pity to put her upside-down for a while. But now that wings and rudder are bent, and the prop broken, there's no way back. But that doesn't matter since her duty is to show up the underside lozenges.
Offline dtomko
« Reply #54 on: June 04, 2015, 09:26:48 PM »
Really fantastic work, Vincent!
Drew
« Reply #55 on: June 05, 2015, 04:39:11 AM »
Outstanding paintwork and great working to all.
Offline vincentm
« Reply #56 on: June 09, 2015, 09:40:31 AM »
Thanks all!
The cabane struts installed on Udet's machine. This requires a precise adjustment of the templates but when all eight attachment points are aligned, the most difficult part of the build is behind you. The arrows show the weathering, consisting into a wash of a rather clear earth color, instead of my usual dirt mix of brown and black oils.
After the cabanes were glued in place, the templates were removed and the V-struts installed, with elastics keeping the wings in place. Unfortunately this led to an excessive dihedral angle for the lower wings.
I have gently un-glued the V-struts from the lower wings, added a small plastic rod and cut the reinforcement braces away. This view shows a close-up on the valve springs and all the bits and pieces below the upperwing: radiator grid handle, gun levers etc
After that, the base of the V-struts is glued again on the lower wings, using again the elastics. The dihedral is now much closer to that of the real thing.
An underside view of the "Jasta 18" bird, since not much of this will still be visible when it's stuck on its diorama. I have added mud spills behind the wheels and tailskid. The holes in the underside cross are for the aileron cables. They will be filled up with a touch-up of white paint.
Now it's knitting time. Except two on the right, the wires are now made from nylon thread which is much easier to tend though more difficult to paint. The picture shows the method: a large buckle is made in order to have enough room for handling the wire tip and tube. When the tip has been passed a second time through the tube (as on the photo), you just need to draw on the wire tip while pushing the tube towards the wire's end and hook.
It's not as easy as it would seem to make loose wires, as some of Udet's aircraft need to be because of the crash. Sometimes the thread goes in the wrong direction and does not look like hanging as it should. I will have a go with thread of a smaller diameter on the other side and see if that's easier.
« Last Edit: June 09, 2015, 09:46:34 AM by vincentm »
« Reply #57 on: June 09, 2015, 09:58:26 AM »
Really starting to take shape now , finish line is getting closer  ;)
Offline jknaus
« Reply #58 on: June 09, 2015, 11:58:52 AM »
Those look gorgeous.
James
« Reply #59 on: June 10, 2015, 04:22:59 AM »
Very great work.
