Author Topic: Pair of Albatros D-Va's. Roden 1/72  (Read 15696 times)
Offline vincentm
« on: April 06, 2015, 10:11:55 AM »
I didn't plan to build more than one Albatros D-V in my 'WWI list' but you all know how it goes: you start with one, then two, three...at least, building both at the same time will spare time, and moreover, I've already built and painted two spare Mercedes D-III engines.
The first is a Jasta 18 late D-Va with external aileron cables and reinforcing braces on the V-struts. Those red and white birds are just gorgeous. It will be one of these four, of which I have time pix:
Two of them are visible on this shot:
The second is the well known black D-Va of Ernst Udet at Jasta 37:
This aircraft is well documented, and I found this very picture interesting, because building the aircraft in this state and position would highlight the underside five-color lozenges which are usually not much visible.
Both kits will be from Roden, as this kit is actually a D-Va with the above mentioned details. It is also the most accurate D-Va in 1/72 scale in my opinion, although certainly more difficult to build than the Eduard issue, because the upper and lower wings must be built from several parts (due to common tooling with their D-III and D-II models).
This pic is blurry, but it shows the wing parts with the optional center sections for other versions:
Luckily, it will not be necessary to make a precise wing building for Udet's aircraft, as everything was more or less bent during the crash...The lower wings must even have a negative dihedral angle.
Re: Pair of Albatros D-Va's. Roden 1/72
« Reply #1 on: April 06, 2015, 12:40:48 PM »
I am really looking forward to seeing what you do with this build!
Offline vincentm
« Reply #2 on: April 07, 2015, 09:19:29 AM »
I have the decals for Udet's plane from an FCM sheet, and I've already drawn the lozenge sheets as well as crosses and insignias for the Jasta 18 birds. I'm still working on various versions of the lower lozenges before chosing which one I'll use for printing.
Offline vincentm
« Reply #3 on: April 11, 2015, 08:44:56 AM »
Here are the two Mercedes engines with valve springs, spark plug wires and a little piping added, along with a painted Wolff prop.
Well I'm cheating a bit, those parts were made during my last serial build (Pfalz D-III's) as they use the same engine.
« Reply #4 on: April 11, 2015, 05:01:17 PM »
Excellent!
« Reply #5 on: April 11, 2015, 07:05:38 PM »
What a beautiful pair of engines, well done, along with a really nice propeller.
Offline vincentm
« Reply #6 on: April 12, 2015, 03:59:52 AM »
Thanks. If I have enough courage, I'll try building the Spandaus in series too, as I have 4 to build, I can add a pair or two since they will soon be useful...
« Reply #7 on: April 12, 2015, 09:15:28 PM »
Very good beginning.
« Reply #8 on: April 21, 2015, 11:54:24 AM »
Cool ! Following along on these ones ...
Offline vincentm
« Reply #9 on: April 23, 2015, 02:27:51 AM »
Thanks.
I've started with the wood effect inside the fuselage and on other wooden parts:
Since it will take time before the oil dries up, I've rebuilt the four Spandaus using the Roden breeches and Eduard PE parts:
Both engines with the completed and painted Spandaus (matt black + pencil)
I've printed the lozenges for both aircraft, adding rib tapes and underwing crosses which will spare a lot of time. Here's the sheet for the Jasta 18 bird:
I will try using the decal instead of paint for the upperwing topside as this should also spare time for rib-shading. But I will have to manage and find the same red for the nose using paint this time.
« Reply #10 on: April 23, 2015, 07:12:38 AM »
Your DVas' are looking great. The wood work and self made decals look fantastic.
« Reply #11 on: April 23, 2015, 07:47:42 AM »
Very good work and painting.
« Last Edit: May 06, 2015, 05:09:21 AM by radio »
Offline BigBlue
« Reply #12 on: April 23, 2015, 09:59:44 AM »
Both the painted pieces and the decals look very good.
I will be interested in seeing how the wing top works vs. painting.  Do you foresee any trouble matching colors with the painted fuselage?
Offline vincentm
« Reply #13 on: April 23, 2015, 08:19:05 PM »
Quote
yes this is the main possible issue. This is why I printed the decals before painting anything, since it's easier to mix paints to match the printed color.
Offline vincentm
« Reply #14 on: May 06, 2015, 04:19:56 AM »
the panel lines have been rescribed since they were too shallow, and some were missing:
Next, cockpit walls, floor, cockpit strengtheners, fuel and oil tanks. The fuel tank is not thick enough but on my previous D-V, I had trouble housing the engine. This time everything fits.
Detailing the cockpit sides. On the SB side: small dashboard, greasing pump and various bits:
Left side: handles and levers. A rod under the floor is used to attach the rudder pedals and stick on it. The seat has had a cushion and belts added:
Last, the tubular structure that carries the RPM gauge. I made only the empty shell box since the ammo cases are not visible from the cockpit aperture:
On Udet's machine which will be shown upside down , the cockpit is very simple, including only the RPM gauge and seat. The belts were glued without being bent, since they will hang from the cockpit. The horseshoe-type frame in front of the engine was also scratchbuilt since the broken spinner makes it visible:
« Last Edit: May 06, 2015, 09:26:39 AM by vincentm »
