Author Topic: Pair of Albatros D-Va's. Roden 1/72  (Read 15627 times)
Re: Pair of Albatros D-Va's. Roden 1/72
« Reply #15 on: May 06, 2015, 04:58:28 AM »
Nice work on the details Vincent!
« Reply #16 on: May 06, 2015, 05:08:46 AM »
Great detailing for the interior.
Offline vincentm
« Reply #17 on: May 12, 2015, 11:45:32 AM »
It appears that footstraps on the rudder bar and control cables would be visible through the cockpit aperture. I will make them on further Albatroses.
The closed fuselages. I used Milliput to fill up the gutter between the fin and fuselage. Milliput is shaped with water before drying, which prevents from further sanding and preserves the kit's surfaces.
The stabilizer and control surfaces in place. This is Udet's aircraft with a bent rudder. The engine cutout lip was made with stretched sprue.
As shown on the pic, Udet's right upperwing is broken.
Hinges were later made from adhesive aluminum. The control horns were made from plasticard glued in slots and shaped in place.
Parts of Udet's machine: the broken aileron, exhaust stack and broken spreader, on which the wheel axle was scratcbuilt.
Both fuselages prepared for painting: metal parts were painted with cellulosic aluminum while wooden and fabric-covered parts ware quickly painted in a light shade of brown, just in case the following paint would flake here or there:
The wings have just received a white primer on the lowersides and light tan on the upper.
« Reply #18 on: May 12, 2015, 12:27:23 PM »
Beautiful work in any scale but even more stunning in 1/72nd!
« Reply #19 on: May 12, 2015, 01:18:41 PM »
Great stuff Vincent
Offline Ssasho0
    • Scale Models Club Bulgaria
« Reply #20 on: May 12, 2015, 05:35:50 PM »
Excellent update :) I also use miliput a lot of filling those gaps and then my wet finger or cottonbud to get rid of the excess without the need of sanding - great stuff!
Best regards,
Sasho
Think globally, act locally!
Offline vincentm
« Reply #21 on: May 12, 2015, 08:43:42 PM »
Thanks. I also used cottonbuds on this one, as well as on the lowerwing-fuselage joint of my previous Pfalzes.
They're rather ugly at the moment with their rough coat of brown, but painting will come soon, starting with the white areas.
« Reply #22 on: May 13, 2015, 05:50:02 AM »
Very great work Vincent.
Offline vincentm
« Reply #23 on: May 18, 2015, 03:49:48 AM »
Thanks.
The Jasta 18 bird has had its tail painted pure white, then the ribs have been masked:
Then a coat of off-white oversprayed with white to melt all up. It's not much visible on photos, it requires to be discrete but it works. On Udet's machine, the tail has first been painted white, the stripes have been masked and a coat of black has been sprayed. After that, the cockpit padding received a basic brown color.
The wings uppersides have been painted light tan to alter the lozenge color in an attempt to simulate the linen color underneath:
The lower sides are white in order not to alter the lozenge colors and have white areas under the crosses which were printed along the lozenges. All holes for masts, wire hooks and cables have been drilled, then the radiators have been painted.
I started applying the lozenges on Udet's upperwing, but the ink started to flake when I rubbed it with a cloth...So, to prevent this, I had to spray another coat of varnish on all the decals I had printed, and re-print this area.
This shot shows how the undercoat alters the lozenge colors:
Udet's both lower wings. I still have to paint the tape that goes around the whole wing, since I couldn't print this with the rest.
Printing the rib tapes with the lozenges helps sparing a lot of time.
I was eager to see how would look the Jasta 18 upperwing with the red decal including rib shading and crosses. There will be some touch-ups to do with red paint but it works and I like the color. This wing upperside was painted white as an undercoat not to alter the shade of red and to create white areas around the crosses.
Now I need to make a mix from red paint to get the same shade and do the touch-ups, and paint the front fuselage the same color.
Offline dtomko
« Reply #24 on: May 18, 2015, 01:20:35 PM »
Looking great!
Drew
« Reply #25 on: May 18, 2015, 05:46:41 PM »
Very nice modelling. Fine shading on the wings. Great interior detail!
« Reply #26 on: May 18, 2015, 07:50:34 PM »
Very good work.
Offline vincentm
« Reply #27 on: May 19, 2015, 03:17:54 AM »
Thanks. I've reprinted the faulty decals and should be done with the wings tonight.
« Reply #28 on: May 20, 2015, 01:35:05 AM »
Truly brilliant work all around, Vincent.
Offline vincentm
« Reply #29 on: May 20, 2015, 03:29:35 AM »
Thanks Bud.
