Author Topic: Pair of Albatros D-Va's. Roden 1/72  (Read 15584 times)
Re: Pair of Albatros D-Va's. Roden 1/72
« Reply #75 on: June 25, 2015, 07:13:58 PM »
If it can help here is my solution to the turnbuckles + eyelets "problem"
http://forum.ww1aircraftmodels.com/index.php?topic=1731.msg34646#msg34646
I know it was an 1/48 scale model but maybe it can give you some hints for a future build...
Please accept my great appreciation for your superb build !!!
Antonio
Offline vincentm
« Reply #76 on: June 25, 2015, 07:31:49 PM »
Thank you both.
Very interesting info Bo. I had noticed the wires were stranded on the closeups of a VTAL D-V. So, the drag wires are then most certainly thicker than flying ones, and probably close to a 1cm diameter. My 0.12mm nylon thread should be OK at 1/72. Flying wires are too thick, but fortunately they are in the shadow of the upperwing most of the times, which makes them appear a little thinner.
Yes Antonio the new method I want to try looks a bit like what you did on your model, the main point being to have thinner tubes for turnbuckles. I was thinking about using buckles from an Eduard PE sheet but the inner diameter of the hole is inferior to 0.10mm, which would be too small. So for the time being, the only thing to do is building buckles the way you did.
Offline vincentm
« Reply #77 on: June 27, 2015, 08:38:28 AM »
The red and white birdie is waiting for the new 0.12mm nylon thread and I'll redo most of the rigging when I have it. I've ordered black thread which will hopefully be easier to paint "steel" color and more discrete.
Meanwhile I completed the stand which is basically a wooden frame painted black with plaster inside. The plaster has been painted and drybrushed then I sprayed flocking material of various shades of green. The maintenance tent was then added.
