Author Topic: Caproni Ca.3 1/32 Scratch.  (Read 43458 times)
Offline Jose Chaica
  • Jose "Von Muttley" Chaica
Re: Caproni Ca.3 1/32 Scratch.
« Reply #15 on: July 10, 2012, 08:02:35 AM »
Looking great!  :)
Jose Chaica, from Portugal.
« Reply #16 on: July 10, 2012, 09:02:04 AM »
Simply exquisite craftsmanship Ron. I always look forward to seeing how you scratch build things, so keep those image updates coming!
Offline Whiteknuckles
« Reply #17 on: July 12, 2012, 11:20:31 AM »
Another 'Wow' project!!
Excellent work Ron, enjoying your detailed build very much.
Eternal Apprentice
« Reply #18 on: July 13, 2012, 06:08:53 AM »
Im not sure how I missed this before now but all I can say is - amazing!!! Great building techniques and problem solving!!!
« Reply #19 on: July 13, 2012, 12:28:19 PM »
Ron,
    I must have been sitting in the same "cone of silence" as Steve this past while, completely missed this thread but so glad I found it! Wonderful to follow through your progress, lots learned, and certainly tremendous compliments on what is truly a great example of the Modeller's Art even at this early stage of your build.
   Press on, this is really great!
Offline chuckd
« Reply #20 on: July 15, 2012, 12:32:54 PM »
WOW!  Unbelievable work on a cool subject.  Your work is so crisp!  Can't wait to see further progress.
Offline Ronkootje
« Reply #21 on: August 05, 2012, 07:24:33 AM »
Slow progres on the build now started rigging the fuselage. pics soon.
Ron
« Last Edit: August 05, 2012, 10:18:47 AM by Des »
« Reply #22 on: August 05, 2012, 12:43:14 PM »
....pics soon....
Looking forward to them!!
Eternal Apprentice
Offline Ronkootje
« Reply #23 on: August 26, 2012, 04:58:22 AM »
Finally an update lots of pics so enjoy!
Starting with the seat made a mold of basswood and vac formed the backrest from 0.5 styrene sheet.
Next up made the radiator from styrene since i need 6 of them i decided to make them out of resin, i have done casting before with poor results.
This result was poor because i didn't had a vacuum chamber to degas the silicone and resin.
So i made a vacuum chamber and bought a vacuum pump along with all the bits and peaces.
here is the master part.
Gonna poor 6 of them out of resin. Same thing with the engine witch i hope ill start next month.
Here are all the parts so far that need to be fitted in/on the fuselage.
Next the Front landing gear.
Used 2mm brass rod for this.
At this point i leave the Rodd intact for easy handling, used the gasstoof to heat up the brass until it was red hot and let it naturally cool off, this way the brass becomes easy to bend.
Next using round plyer shaped the Rodd in the global shape of the part and then start hammering with a flat hammer and pound it Flatt.
After beating the life out of the brass this is what i ended up with.
Used a waterproof pen to outline the part and started to sand file sand and file until the shape was the same on the drawings.
I used the same method for the main landing gear.
Then using masking tape of 2mm wrapped the landing gear.
eventually it looks like this.
The reason why i use brass is that i can make real small parts and solder it which in turn makes a strong structure.
The fuselage was a hard thing to build but i'm happy with the result.
Ron
« Last Edit: August 27, 2012, 07:46:35 AM by Des »
Offline Ronkootje
« Reply #24 on: August 26, 2012, 05:00:57 AM »
Overall this is where i am now.
Ron
« Last Edit: August 27, 2012, 09:49:05 PM by Des »
« Reply #25 on: August 26, 2012, 05:10:43 AM »
Ron,
    This is a spectacular Build. I have often been tempted to try a scratch build project, if and when I do I'll be checking back here for sure. Your work is truly "world class"!
« Reply #26 on: August 26, 2012, 07:33:24 AM »
Bravo, Ron! Thanks so much for sharing your techniques -- lots of inspiration here. Your craftsmanship is terrific, too. Super.
« Reply #27 on: August 26, 2012, 08:15:51 AM »
Exceptional workmanship Ron, everything you have done so far is brilliant, the rigging on the tail section is superb, extremely well done.
« Reply #28 on: August 26, 2012, 08:52:04 AM »
 :o
No words can express my respect for your talent.
Well done!
BVB
« Reply #29 on: August 26, 2012, 02:46:00 PM »
Superb Ron, she's looking a treat ;)
Excellent craftmanship.
Eternal Apprentice
