Author Topic: WNW 1/32 AEG White 2  (Read 21557 times)
Re: WNW 1/32 AEG White 2
« Reply #60 on: June 14, 2015, 03:05:01 PM »
Absolutely stunning Petrov, the decals look fantastic and as far as the silvering, I can't see it in the photos, you are doing a brilliant job.
Offline Ssasho0
    • Scale Models Club Bulgaria
« Reply #61 on: June 14, 2015, 08:30:18 PM »
It is looking absolutely fantastic! I know that everyone said the same thing, but it is damn
true, so one more time is not too much.
Best reagrds,
Sasho
Think globally, act locally!
« Reply #62 on: June 14, 2015, 11:15:31 PM »
If you dare: my cure for silvering is to carefully prick any bubbles with a needle, then Mr Color Lacquer Thinner applied directly to the offending decal with a brush, no scrubbing, just a thin coat then do not touch it. Let it sit 24 hrs. Repeat as necessary. Coat with several coats of Tamiya clear.
« Reply #63 on: June 15, 2015, 05:13:59 AM »
It looks exellent.
Offline petrov27
« Reply #64 on: June 15, 2015, 09:00:30 AM »
Thanks gents for the postive feedback! Really helps to keep the motivation (it was super hard to stay focused during all that lozenge application)
Regarding the silvered decals, I actually had tried fixing it via pin-pricks and future application prior to posting the pics here but it did not seem to help much and now the decals are pretty much fused to the lozenge now :-\
The silvering in the pics is not noticable but I intentionally shot them at an angle where it wasnt apparent - it is really noticeable at higher angles....
Debating if I should try to remove that area of lozenge where the serial # is or just apply another piece of lozenge right over the top - seems both could screw it up further....
Dave - regarding the raised "C" on the wing center section - I think that is to just lock the wing into the fuselage maybe? There is a corresponding hole on the fuse where it slots together?
-Patrick
Offline petrov27
« Reply #65 on: September 18, 2015, 09:38:28 AM »
well slowly some progress. Bombs are lashed to the racks with sections of Modelkasten line. Decided to do this section as a module prior to attaching to the fuselage - not sure that was the best idea as it was quite tricky getting it attached to the fuselage without breaking anything.
« Last Edit: September 18, 2015, 10:21:18 AM by petrov27 »
-Patrick
Offline petrov27
« Reply #66 on: September 18, 2015, 09:44:33 AM »
And here is the lower center section attached to fuselage. Wow the pics show up lots of rough spots but ah well! I dont think I would choose to decal the front gunner's section if I were to do another - so hard to get those to conform correctly around the very front of the nose....
-Patrick
« Reply #67 on: September 18, 2015, 09:46:38 AM »
Very nicely done Petrov, the bombs and undercarriage look excellent.
« Reply #68 on: September 18, 2015, 10:05:42 AM »
Oooh!  Lovely work, Petrov!  She's shaping up magnificently and those bombs are brilliantly painted.
Offline Pgtaylorart
« Reply #69 on: September 18, 2015, 10:34:57 AM »
Looking great, Petrov! The bombs and racks are very well done!
George
« Reply #70 on: September 18, 2015, 01:31:05 PM »
I agree 100% with Bud....as usual! The Bombs are Magnificantly painted!
Offline rhwinter
« Reply #71 on: September 18, 2015, 05:14:26 PM »
WOW, Petrov, beautiful!
« Reply #72 on: September 18, 2015, 06:52:09 PM »
Very beautiful, Petrov.
« Reply #73 on: September 18, 2015, 08:38:32 PM »
Superb work, Petrov!  I think you have done a terrific job
of the lozenge as well as  the bombs and undercarriage.
Looking forward to the next updates, my friend.
Offline petrov27
« Reply #74 on: September 19, 2015, 09:10:05 AM »
again thank you for the positive feedback! Hoping things will proceed a little quicker now but still tons of work to do!
-Patrick
