Author Topic: WNW 1/32 AEG White 2  (Read 21482 times)
Offline spartacus2000
Re: WNW 1/32 AEG White 2
« Reply #75 on: September 19, 2015, 08:32:06 PM »
Great work as fo far  Petrov i like this airplane
Offline petrov27
« Reply #76 on: February 06, 2017, 06:47:36 AM »
Just back on the bench here - touching up some chips and applying clear to the decal repaired center section of the top wing then I have to get going on the engines....
Did you use the Taurus timing gear with lifters on your build? I simply could not get it all to line up and it ended up being a major factor why this went to the "shelf of doom" for many months :)
-Patrick
Offline petrov27
« Reply #77 on: February 06, 2017, 08:04:19 AM »
Wow - nice engine assembly line there!
I think I might have had the early Taurus set(s) - maybe I will order a couple new ones and start over
Which of their plug set do you favor for the DIV?
-Patrick
« Reply #78 on: February 06, 2017, 08:23:56 AM »
a dunk in very hot water will cure any banana issues with camshafts -- do this while still on the casting block...
« Reply #79 on: February 07, 2017, 01:50:51 AM »
Beautifully done Petrov!
She's going to be a beast! Love the lozenge...
« Reply #80 on: February 07, 2017, 02:52:13 AM »
Fantastic job on this kit.
« Reply #81 on: February 07, 2017, 08:47:49 AM »
The details on the engine look fantastic. Especially considering they are mostly covered!
