Author Topic: WNW 1/32 AEG White 2  (Read 21486 times)
Re: WNW 1/32 AEG
« Reply #45 on: May 11, 2015, 10:44:20 AM »
Lovely work on the machine gun, those tiny PE bits can be a bit fiddly at times, the lozenge application looks really good.
Re: WNW 1/32 AEG
« Reply #46 on: May 11, 2015, 08:36:23 PM »
Good update.
Offline Ssasho0
    • Scale Models Club Bulgaria
Re: WNW 1/32 AEG
« Reply #47 on: May 12, 2015, 05:36:39 PM »
When I grow up into a big, strong and skille dman, I want to be able to paint guns like you :)
Bets regards,
Sasho
Think globally, act locally!
Offline petrov27
Re: WNW 1/32 AEG White 2
« Reply #48 on: May 18, 2015, 02:37:22 AM »
Thanks again for the interest!
Some progress - doesn't look like much but it feels like it has taken significant effort to get to this point of having the fuselage halves closed up. Some putty and sanding has been required along the turtledeck seam and on the front but not too bad. I prepped the tail empennage surfaces as well but managed to ruin the paint when glossing for lozenge - tried the Tamiya spray gloss and wow that stuff is hot - really reacted badly with the acrylic paint. Getting a good gloss remains a challenge for me I guess :)
Also have decided to do the scheme for "white #2" though with the early version crosses from scheme white #1 instead of the later field modified (I figure it is safe to believe that #2 was delivered with those same crosses as #1 as they were the same production batch and close in airframe number)
-Patrick
« Reply #49 on: May 18, 2015, 02:54:23 AM »
Very great work. It looks very beautiful.
« Reply #50 on: May 18, 2015, 03:47:42 AM »
Brilliant cockpit, Petrov!  Looking forward to your next update.
Offline BigBlue
« Reply #51 on: May 18, 2015, 05:33:35 AM »
Love it.  Looking really good, Petrov.
Offline Russell
« Reply #52 on: May 18, 2015, 05:41:31 AM »
I hope to order an AEG shortly, to be built as this aircraft so I'm particularly enjoying this build.
Russell
« Reply #53 on: May 18, 2015, 12:46:01 PM »
Looking great all closed up around that beautiful interior!
Offline LukasTheLight
  • Addicted to Wingnuts...
« Reply #54 on: May 19, 2015, 01:08:30 AM »
That fuselage looks magnificent!!! Reminds me body of a speed boat ;)
Lukas
Lukas
Offline Pgtaylorart
« Reply #55 on: May 19, 2015, 02:59:51 AM »
Very nice, Petrov! Your interior looks great. This looks like a fun one to build. I can't wait to start mine.
George
Offline petrov27
« Reply #56 on: June 14, 2015, 11:12:30 AM »
Fuselage and lower wing all lozenged now. Entire fuse is covered with decals - biggest decal job I have ever done and the most difficult getting them to settle down over the top coaming and nose. Lots of things not really satisfied with but ah well. Still some more touch ups to do....
The worst is that after all the lozenge, I applied the other markings which went fine till the serial numbers - they silvered terribly... All the other decals went on fine so not sure what happened there. I have some extra lozenge so I may just apply a section over the serial numbers to cover them up - not sure what else to do  :P
-Patrick
« Reply #57 on: June 14, 2015, 11:34:55 AM »
Looks terrific! The Lozenge is outstanding. I can't seem to see the silvering on your serial numbers but I am sure there is a method to help with the silvering after application. I just can't think of what it is at this time  :-\
Offline Dave in Dubai
  • Beyond the blue horizon
« Reply #58 on: June 14, 2015, 12:27:58 PM »
Looks fantastic Petrov,
Really lovely to see the kit supplied lozenge on the model.
I am going to use the Aviattic lozenge on my build so it will make a good contrast to see models built with different interpretations of the night lozenge fabric.
Reference your silvering problem.
You may be able to tease off the existing serials by using decal softener or just plain water and a paintbrush?
The technique may be very slow, but I have managed to do this successfully in the past.
To prevent silvering of serials, I always apply them by using some wet future applied with a paintbrush on the area the decal has to be applied to. You have to be very careful though to carefully blot out the excess underneath otherwise you can end up with wrinkles in the overlying decal. Let it dry naturally, and there should be no silvering at all underneath.
If you need spare serials, drop me a message and you can have mine , as I won't be using the same decals for my kit.
Good luck and best wishes with the rest of the build!
Dave :)
PS- does anyone have any idea why there is a raised C- section ridge in the area above the fuel tank, on the lower centre section wing? I can see no purpose for this, and wondered whether there was supposed to be some other part for this area? Cannot see why.
« Last Edit: June 14, 2015, 12:36:32 PM by Dave in Dubai »
« Reply #59 on: June 14, 2015, 02:42:24 PM »
Hi Petrov!!!
That looks absolutely magnificent to behold... that fuselage is simly stunning!!!
Cheerio
Lukas
Lukas
