Author Topic: LFG Roland D.VIa (1/32, Wingnut Wings)  (Read 27953 times)
Re: LFG Roland D.VIa (1/32, Wingnut Wings)
« Reply #60 on: January 12, 2015, 05:07:44 AM »
It looks great.
« Reply #61 on: January 12, 2015, 05:25:09 AM »
Beautiful! The Lozenge and rib tapes are outstanding!
Offline vincentm
« Reply #62 on: January 12, 2015, 10:11:00 AM »
Really beautiful. I also plan to build Kissenberth's D-VIa...when I manage to get a hand on a 1/72 kit of it...
Quote
approachig the proud stage of a monoplane
I also like this step. Those birds look like racers of the 20's then, and they would also have a lot of appeal as monoplanes...
BTW, funny how the colors of the lozenges may vary depending on the lighting. On the topmost shot, the blue looks like purple, when it looks blue on others.
I went backwards in the post but couldn't find how you managed to highlight the riblets this way. A pre-shading?
« Last Edit: January 12, 2015, 10:17:35 AM by vincentm »
Offline stefanbuss
« Reply #63 on: January 12, 2015, 04:45:48 PM »
What will be your next step? Fitting the engine and it's covers, or rigging the undercarriage?
Having built the Kissenberth scheme myself, I really like watching what you are doing here.
Stefan
« Reply #64 on: January 12, 2015, 09:03:11 PM »
Thank you, gentlemen.
Vincent, the MAC kit in 72nd scale is quite fine, I have built it.
http://www.ikb.poznan.pl/przemyslaw.litewka/modele_pliki/roland6.html
 There is one flaw I remember, which I did not dare to correct, the wing span is about 1.5mm too short. Correction would influence the  rib pattern - it was too much for me 5 years ago. Now I would probably scrape the ribs down and restore them only by shading. Otherwise the kit was a pleasure to build.
Vincent, the different colours on the losenge are the fault of white-balance settings of the camera. This time I set them on auto and the first shot was taken with LED lamp lighting, while the remaining ones were with camera flash.
The riblets were masked with tape and preshaded. There is a photo showing such masking for undersides, where I used 1mm wide Aizu tape for the ribs. On the upperside I used additionally 0.7mm tape for the false ribs.
Stefan
Stefan, I will rig the undercarriage and complete it with the wheels first. Then I will go to the engine installation with some additional bits which can be added only when it sits on its place. I plan not to attach the side engine cowlings, they would obscure all the details added to the engine. The front and the top cover will do  ;)
« Reply #65 on: January 15, 2015, 08:13:55 AM »
Thank you, Richard. I am glad you like your decals as much as I do  ;)
I will try to take the final photos taking more care for the camera settings including the white balance to show the colours I really got.
And this build is clearly approaching its finale.
The recent assembly steps were:
- u/c rigging
- engine mounting plus some additional control cables and rods for the carburettors
- under-wing bits including Spandaus, windscreen, tacho and fuel gauge
- struts and the lower radiator pipe glued with the use of the top wing put on to control the geometry
- the top wing itself
- wheels
- the upper radiator pipe and the front cowling
I have also started painting the wood on the propeller
and prepared the ailerons control horns with their turnbuckles plus two further ones destined for fuselage-top wing cables.
WarrenD
« Reply #66 on: January 15, 2015, 09:39:29 AM »
Beautiful work Prze!
« Reply #67 on: January 15, 2015, 10:05:57 AM »
Wonderful work.
« Reply #68 on: January 15, 2015, 02:46:16 PM »
Beautiful work as always! By the way I am really envious of all of my fellow modelers who do such gorgeous props! Is yours masked and sprayed or pencil? I just can't seem to make the pencil method work  :-[
« Reply #69 on: January 15, 2015, 02:56:48 PM »
Amazing job, Prze.  Just a stunning model!
« Reply #70 on: January 15, 2015, 03:21:48 PM »
Phenomenal update, Prez!  Almost done!  How did you replicate the wood showing through the worn black paint?  Looks very convincing.
Offline stefanbuss
« Reply #71 on: January 15, 2015, 06:51:32 PM »
So, you are using your camera's flash for making your photos?
Quote
Good that you are doing those as well - it seems they are forgotten too often on those Roland builds, which i find very strange, as they are so obvious (if you take care to examine the fuselage thoroughly, that is),
Stefan
« Reply #72 on: January 15, 2015, 07:02:45 PM »
Thank you everybody for watching and comments.
RAG, the prop was painted, the layers pattern masked, then some additional touches with different colours were done with a fine brush. Finally the coat of clear orange. However, it is still not completed, I still have to polish it and cover with clear gloss before the Axial logo decals and the prop boss gets its metal colour.
To me it is not fully satisfying. But if you like it, I can sell you the technique ;) Simple - drybrushing the semi-dried beige brown paint pigment along the edges. Just this. Still, looks better than solid dull black.
Stefan
Only for in-progress shots. I do not have enough space at home to have the proper photo set with lighting, background, camera tripod, etc. open all the time. And I am too lazy to set it for each update.
Quote
Stefan
Actually these two turnbuckles are for two front cables - they will be located at the line mid span, more or less. The rear cables have the turnbuckles as well, but just under the top wing. Those two will be tied directly to the eyelets which are already glued there.
Offline stefanbuss
« Reply #73 on: January 15, 2015, 07:13:04 PM »
Looking at your last set of photos once more (actually to have another look at your prop), i suddenly realized that you actually had decided to give your Roland a set of eyes. Nice to see this version - on my build i decided against them, but they look cool.
 8)
Offline Ssasho0
    • Scale Models Club Bulgaria
« Reply #74 on: January 15, 2015, 07:29:28 PM »
Excellent build as always!
FOr some reason, I was thinking that you are going for a "wooden" fuselage, but the black one looks excellent especially with the eyes, nice detail :)
Best regards,
Sasho
Think globally, act locally!
