Author Topic: LFG Roland D.VIa (1/32, Wingnut Wings)  (Read 27976 times)
Offline Adam
Re: LFG Roland D.VIa (1/32, Wingnut Wings)
« Reply #30 on: December 31, 2014, 09:12:40 PM »
The engine looks very nice.
Soon I'll start to building my motor. Also I have a parts Taurus and I'm afraid if I manage to mount it perfectly as you did it.
Adam.
Offline Umlaufmotor
« Reply #31 on: December 31, 2014, 10:24:11 PM »
Love the engin and the details on it, PrzemoL - very nice done ;)
....................but your engin stand is realy the coolest thing  :D
« Reply #32 on: January 01, 2015, 04:50:12 AM »
Very good engin and fuselage so far.
« Reply #33 on: January 01, 2015, 06:23:08 AM »
Beautiful engine, Prze. :D  What did you use for the sparkplug wires?
As usual, an uplifting update, my friend.
« Reply #34 on: January 01, 2015, 06:38:58 PM »
Looks super Prze  :D
I have an aversion to macro photography! After being really pleased with something I then want to chuck it in the bin after a close up shot...  ::)
Unlike Bo & Bertl - their detail work looks better in close up...  :P
Happy New Year...
« Reply #35 on: January 01, 2015, 07:30:45 PM »
Excellent work detailing the engine Przemol, it's all the fine detail that sets the engine off.
WarrenD
« Reply #36 on: January 02, 2015, 01:30:11 AM »
I love what you've done so far on the engine Prze!
« Reply #37 on: January 02, 2015, 05:16:08 AM »
Excellent job on that power plant, Prez!
Offline drdave
« Reply #38 on: January 02, 2015, 09:17:34 AM »
Tremendous. I've got mine out of the stash now!
« Reply #39 on: January 02, 2015, 09:12:26 PM »
Thank you, everybody! I am glad you like my efforts on the engine.
Ernie, the electric wires were made from thin copper wire (about 0.2mm) painted brown.
Justin, thank you for the heads up! I have noticed the problem and was going to write about it. However, I also tried it twice and it is possible to squeeze in both, the engine together with the oil tank to the closed fuselage. So I will not break the fuselage.
« Reply #40 on: January 04, 2015, 09:30:24 AM »
A few steps forward...
Spandau machine guns assembled
Tail painted white
Then I started working with Aviattic losenge. I can only say superlatives! Finely workable, covers all the surface details like a glove, fits to the kit elements perfectly and the linen image is spectacular. Yet, I had to learn first. My very first attempt was a failure. I have wrongly assumed that CDL base colour will be fine. I have added some beige rib shading. And the result was far too dark. Luckily I have experimented on the elevator for which two decal sets are included. So it was not a problem to scrape everything and start again. Now I went for off-white base (Pactra white and mid stone in about 1:5 proportion). And the result was just fine on the tailplane
Only that the Mid stone rib shading proved to be too weak. For the remaining surfaces I will probably go for something more pronounced. The under sides are now ready for it but I have enough for today.
Offline KitRookie37
« Reply #41 on: January 04, 2015, 05:25:02 PM »
Hello to all,
Thanks for sharing, so i'll not mistake using Aviattic decals.  ;)
Best regards.
Alain.
Use the force, Luke.
Offline IFF1418
« Reply #42 on: January 04, 2015, 08:16:46 PM »
Fantastic engine Przemo and the lozenge is fabulous!
Kind regards
Patrick
« Reply #43 on: January 04, 2015, 08:20:22 PM »
Hi again Prze
Yes, the lozenge is perfect! Looks brilliant when it's done as well as that  :)
Offline stefanbuss
« Reply #44 on: January 05, 2015, 08:11:43 PM »
Hello Przemol,
two questions:
a) did you use Master's update for the Spandau Barrels/jackets?
b) the Lozenge from Aviattic: Is this a set specifically for the Roland?
I hope you will succeed with your plan of shading on the wings.
Stefan
