Author Topic: LFG Roland D.VIa (1/32, Wingnut Wings)  (Read 28022 times)
Re: LFG Roland D.VIa (1/32, Wingnut Wings)
« Reply #15 on: December 19, 2014, 07:10:57 PM »
Thank you, everybody. Your kind words are greatly appreciated!
Perhaps we should have had a group build?  ;D
I do not object, if there is one I will gladly join!
BTW, once we had a custom of mini-group-builds at one of Polish forums. Such thing was started when at least four build threads on the same topic were started. It seems we just have four running now!
Beautiful, Prez! Looking foreward to what's to come...! By the way: No Polish version available?
Not that I would be aware of it. Pity. But we are still proud to owe the only one survivor in Cracow!
Welcome aboard  :D
Beautiful cockpit, from where you take the time to build so fast?
Greetings.
Jacek
No idea, Jacek. I just happen to use every minute of my spare time. It is not a hobby anymore, it is an addiction!
Offline rhwinter
« Reply #16 on: December 19, 2014, 07:20:59 PM »
[/quote]
That's why I asked, Prez. How did the plane make it to the Kraków museum? A Freikorpsplane from the post WW1 fightings in Upper Silesia? Or Beute from WW2?
« Reply #17 on: December 19, 2014, 07:29:05 PM »
WW2 trophy, as far as I know.
Offline vincentm
« Reply #18 on: December 20, 2014, 01:38:14 PM »
The cockpit is gorgeous. The colors are crisp and beautiful, with just enough weathering and shading.
« Reply #19 on: December 20, 2014, 07:53:24 PM »
Outstanding start as usual! Lovely wood work on the interior and terrific details!
« Reply #20 on: December 20, 2014, 09:20:23 PM »
Good grief, Prze, every time I decide to try one of your builds
you start another.  To say you are a prolific modeler is a huge
understatement, but it is a real bonus to learn from one of the
best.  Excellent start, by the way. Nothing new there. ;) ;D
Offline LukasTheLight
  • Addicted to Wingnuts...
« Reply #21 on: December 21, 2014, 01:17:04 AM »
Absolutely beautiful!!!...as always... your cockpit is truly inspiring!!!  ;)
Lukas
« Reply #22 on: December 23, 2014, 09:39:39 AM »
Many thanks for your kind words, gentlemen.
The modelling continues...
I have closed the fuselage and added the MG cables as per The Red Baron's build  ;)
Then I started with Mercedes D.III. At the beginning I was tempted to build it almost out of the box and shamelessly cover the missing bits it with cowling. But then I had a glimpse at my Albatros and realised that I would never forgive myself, if I had not tried to detail this engine again (most probably for the last time!). So here it goes:
The holes for the Taurus's valve springs and spark plugs drilled:
The springs are in:
This time I decided to use Taurus set "Easy to paint" with the rocker mechanism in separate pieces (19 elements instead of one). I almost regretted this decision but finally I got it assembled:
And to end the day, I have added the spark plugs and tubes for electric wires ( I have managed to break one of these, the keen-eyed can probably tell which one it is).
Offline KitRookie37
« Reply #23 on: December 23, 2014, 05:07:45 PM »
Hello to all,
Amazing work my precious... ;) ;D
I use Taurus products too, good one I think.
Best regards.
Gol...heu....Alain.  ;D
Use the force, Luke.
Offline stefanbuss
« Reply #24 on: December 30, 2014, 05:53:20 PM »
Quote
Put there during WW2 to prevent any bomb damage and stayed there after the war. The Roland was originally on display at the Zeughaus in Berlin, afaik. I think to remember that information came from Windsock International Volume 26/something, describing the build of WNW's model. If you need to know, I can check during the next days.
Stefan
« Reply #25 on: December 30, 2014, 06:43:38 PM »
Nice to see the engine going together, you have done a good job with the tiny Taurus springs and spark plugs.
« Reply #26 on: December 30, 2014, 07:13:23 PM »
Lovely..
They're very fiddly..
Offline IFF1418
« Reply #27 on: December 30, 2014, 08:38:19 PM »
Hello Prezmo,
Another beauty in the make. Absolutely gorgeous interior and your painting is as always fabulous. Keep on the magnificent work. You are going faster and faster with every build.
Kind regards
Patrick
« Reply #28 on: December 31, 2014, 09:52:39 AM »
I love the engine stand! Brilliant!
Isn't it?  ;) I am so proud of it!  ;)
The engine is basically completed, only some grime to finish it. (BTW, the merciless macro-photography revealed some flaws in the paint and disconnected spark plugs... already corrected) I have added electric wires, air pump pipes, carb and magneto control mechanisms. The control rods/cables will be added after the engine is mounted
I have also added a fuel line which may just be visible when the engine gets installed.
« Reply #29 on: December 31, 2014, 09:54:14 AM »
Beautiful detail work on the engine and fuel line!
