Author Topic: WNW AMC DH2 24 Sqn. Major Lanoe Hawker VC  (Read 59961 times)
Re: WNW AMC DH2 24 Sqn. Major Lanoe Hawker VC
« Reply #165 on: January 23, 2015, 06:44:36 PM »
Looking outstanding! Too bad about the small error but I am sure you will set things right in no time at all!
« Reply #166 on: January 23, 2015, 09:42:50 PM »
Nice to see the tail booms appear, Lance.  Continuing excellent work.
I am quite familiar with the one step forward, etc., dance step, but
at least you found it early and will have no trouble rectifying it. :D
« Reply #167 on: January 23, 2015, 10:44:51 PM »
   Prez, I forgot to address your comments on the glue from the strut attachments interfering with the eyelets and the rigging potential for tangles. The CA did foul a couple of eyelets causing some very awkward drilling to clean several out and I had to re-drill and replace one already. I still prefer that to working the entire task between the wings though. As for the tangles, yes, a definite challenge. I use little tabs of Tamiya Tape to group pairs etc. together but things still get all tangled together anyway. The secret is to untangle and move any that are in the way before working on a particular line and so on.
   As with any part of a build, there is no one foolproof method of doing anything!
Thanks, Lance, for your answer. As usual, everybody to his favourite methods. I am glad yours are working fine for you. Your DH.2 build is progressing to a fantastic result, I am sure!
« Reply #168 on: January 24, 2015, 12:58:18 AM »
Nigel, Rick, Ernie and Prze,
    Thanks for the votes of confidence as I continue to stumble on, fortunately although my error was huge the impact was minor and easily corrected. The potential to complicate the rigging process by using the wrong sequence and blocking access to a line or connection that should have been done before is high, I am spending a lot of time checking, cross checking, and doing "dry" runs on this one. The Tutorial on Bob's Site is a great help in this regard. The anecdote about releasing a pigeon in the latticework and, if it managed to fly out you've missed a line or two makes a lot of sense, there was a lot of wire for the Riggers to string on this beast! :o
Cheers!
« Reply #169 on: January 24, 2015, 03:15:31 AM »
Hi Lance:
Nice save on the pulleys!  Glad to see that there was no cosmetic damage and you can continue on this build.  Looking good to date.  Looking forward to seeing your next update.
Offline IFF1418
« Reply #170 on: January 24, 2015, 06:15:11 PM »
Hi Lance I totally agree with Mark. Such an inspiring and wonderful build. The rigging is absolutely fabulous!
Kind regards
Patrick
« Reply #171 on: January 24, 2015, 11:10:57 PM »
   Thanks Mark. Patrick, the rigging has slowed somewhat as I elected for mono for one line lower wing back to the Lattice and EZ Line for the rest. The mono provides good strength for the delicate Lattice Tail but has to be tensioned just right to not warp the frame work or, conversely, hang slack. I hope the whole equation doesn't change once She's on her feet and weight is supported on the tail skid......... :-\
    Worst case I'll be replacing the mono with EZ Line as the last step in the process. :(
« Reply #172 on: January 24, 2015, 11:17:30 PM »
I've not used the EZ line very much, Lance.  Are you using the "fine"
variety for the tail rigging?  Quite the balancing act once you get out
on the tail lattice!  With your abilities I have no doubts of a successful
outcome. :D
« Reply #173 on: January 24, 2015, 11:22:56 PM »
outcome. :D
Ernie,
    Yes, "Fine" made by Berkshire Junction. The "flat" stuff, and it shows! :-\
« Reply #174 on: January 24, 2015, 11:50:15 PM »
You make a marvelous work Lance.
Offline Edo
« Reply #175 on: January 26, 2015, 04:26:36 PM »
hi Lance! beautiful work indeed!
I added a copper wire eyelet to the brooms, but twisting the wire to make the eyelet itself it just cut throught the plastic.... how did you do that? how did you attach the turnbuckles there?
thank you
ciao
edo
« Reply #176 on: January 27, 2015, 12:43:55 AM »
My apologies for being so late the party again Lance but I've been catching up since my last visit and what you're doing here is marvelous. Looking in from the outside, the rigging is daunting to say the least, especially as its routing seems to be confusing in more than one or two instances. You're doing a stellar job with it and your build log will be a valuable tool when I finally get around to mine. Keep notes as I'll be pestering you!
« Reply #177 on: January 27, 2015, 02:11:56 AM »
thank you
ciao
edo
Martin, Chris, and Edo,
    Many Thanks, and I'll keep notes Chris. It's real easy to lose track for certain, and I have to keep going back to the references constantly.
Edo,
    I used the "lugs" already moulded onto the tail booms rather then use eyelets there. As you can see in the following photo they are more then strong and large enough for the purpose and, in fact, I easily got second runs of line through some of them when required. all except the crossed lines in the bay closest to the main nacelle are easy line as it's virtually impossible to use mono without warping the booms. It's a very slow process but not difficult. I did the cross rigging of the lines in each individual tail boom "bay" first, then the lines between the two sides of the boom or lattice assembly next. The other photos following serve as the next update; the rigging of the lattice tail assembly is now complete.
   Next step on the main structure is the myriad of flight control cables. Prior I'll be completing the Lewis Gun (Gas Patch version) and adding a few final touch ups to the landing gear assembly.
Offline Edo
« Reply #178 on: January 27, 2015, 04:28:14 PM »
I see, Lance!  :)  thank you mate!
you did a great job indeed!
btw, did you use decals or you painted those roundels? they look terrific to me...
ciao
edo
Offline IFF1418
« Reply #179 on: January 27, 2015, 05:05:12 PM »
Hi Lance,
Your rigging is fabulous my friend. Outstanding modeling this is all the way!
Kind regards
Patrick
