Author Topic: WNW AMC DH2 24 Sqn. Major Lanoe Hawker VC  (Read 60384 times)
Re: WNW AMC DH2 24 Sqn. Major Lanoe Hawker VC
« Reply #180 on: January 28, 2015, 12:53:06 AM »
Edo,
    The roundels are the kit Decals, the "lighter Blue" ones.
Patrick,
     The rigging is really getting slow now, the sequence has limited the amount I can move the model around to do the next rigging step without damaging it; a lot of the lines now have to be done with me moving around instead of the model, at times I have to step back as I'm all but standing on my head! The double control wires from fuselage to the lower pulleys and then to the rudder and tail skid are the challenge presently, lots of fun!
Offline BigBlue
« Reply #181 on: January 28, 2015, 05:37:50 AM »
This really looks great, Lance!
I did a double take of your close up of the boom attachment point since the rigging looked so realistic.  If I ever get the nerve up to build one of these marvelous beasts, I will be digging through this thread for guidance!
« Reply #182 on: January 28, 2015, 06:17:55 AM »
Thanks Chris, it's not as easy as most to rig but as I keep saying, with a slow approach it's not all that bad!
« Reply #183 on: January 28, 2015, 09:19:55 AM »
Exellent rigging Lance.
« Reply #184 on: January 28, 2015, 02:32:04 PM »
Lance,
This is continuing to be an educational Masterpiece! Lovely work on the rigging
« Reply #185 on: January 28, 2015, 02:42:31 PM »
You ahve done a superb job with the rigging Lance, it may be time consuming but well worth the effort.
« Reply #186 on: January 28, 2015, 05:51:53 PM »
Well done on the rigging Lance..
Looks scary! Keep going though  ;)
« Reply #187 on: February 14, 2015, 10:46:59 AM »
   Lots done in the past three weeks but at a very slow pace. Prior to completing the rigging I cobbled together this neat little adjustable work stand, I believe someone here posted the idea, whoever it was many thanks, it's a real boon to the rigging phase as it can be bent to virtually any angle and, at eye level on your bench, it helps the process immensely.
    The Flight Control cables were added which required a lot of work in the restricted spaces between the wings. First on were the elevator cables, then the rudder cables. Here's the elevator cables from the large bell crank on the nacelle........
    Here they pass through the pulley on the rear strut of the first bay.........
.......and they then run to the upper and lower control horns on the elevators.
The rudder and tailskid control cables start as two and are then split to three cables by a brass and leather fitting. The Kit supplies a rather over sized Photo Etch fitting which I trimmed down in size and re-drilled........
    Getting it mounted and then ensuring that, when completed, it would hold it's proper vertical alignment proved tricky however if you........ hold ......your tongue......just.......so!
    The aileron control system was changed to the retractable bungee type as mentioned last thread and the lower wing aileron cables and fairleads were added.
   Several other flying wires were then added and the landing gear as well.
    All that remains now is the upper wing fuel tank, Lewis Gun, and prop to install, some touch ups (lots of scratches to cover and re-sealing of edges where the decals have frayed a bit) bit more Post Shading "a-la Bud" and some weathering. It's been a long haul with lots of real life delays and interruptions but I'm almost there!
« Last Edit: February 14, 2015, 11:44:22 PM by lcarroll »
« Reply #188 on: February 14, 2015, 10:52:52 AM »
Superb is an understatement to describe your rigging, very well done considering how intricate it is, don't you just love those aeroplanes that had heaps of rigging  :) ;)
Offline LukasTheLight
  • Addicted to Wingnuts...
« Reply #189 on: February 14, 2015, 12:15:42 PM »
Hello,
she is absolute beauty!!! It is great to see her getting so close to be finished ;) I love your rigging and still craving your post-shading!!!
Lukas
Lukas
Offline eindecker
    • Models In Scale
« Reply #190 on: February 14, 2015, 04:12:11 PM »
Smashing! Wizard! Cowabunga! Really… marvelously well executed DH. The rigging is superb, and I know, having done a not-so-super rigging job on my FE.2b. Thanks for the bonus shots of your rigging stand. I'm building one. Soon.
I will say that following your build here has moved a Wingnut Wings DH-2 to the top of my buy list.
Waiting for the finished photos.
Michael Scott
Offline xan
« Reply #191 on: February 14, 2015, 04:49:19 PM »
very impressive work congratulation !
Xan
Offline KitRookie37
« Reply #192 on: February 14, 2015, 05:00:42 PM »
Hello gentlemn,
I agree: kowabunga !!! What a string ball !! Awesome work.
Best regards.
Alain.
Use the force, Luke.
« Reply #193 on: February 14, 2015, 06:00:50 PM »
Wow,Lance, what an impressive piece of work. Well done!
Offline Edo
« Reply #194 on: February 14, 2015, 06:38:32 PM »
Hi Lance!
you did a wonderful work! The rigging is top class, I'll use your build as a guide to my DH2
ciao
Edo
