Author Topic: Francesco Baracca's Ni17/2614 Academy 1/32  (Read 28018 times)
Re: Francesco Baracca's Ni17/2614 Academy 1/32
« Reply #60 on: November 24, 2014, 06:16:58 AM »
Hello Andonio:
I like what you have done so far.  The cockpit is shaping up nicely and the master Caster assembly enhances the overall appearance of the cockpit.  The gauge is a nice touch, as that can be seen once you button it all up.  Nice touch!
Offline Dric
« Reply #61 on: November 25, 2014, 12:48:12 AM »
Nice job on this bird, congrats.
Dric
« Reply #62 on: November 25, 2014, 02:02:40 AM »
Fantastic work on the cockpit, Antonio!
I agree 100%
« Reply #63 on: November 25, 2014, 02:04:04 AM »
Thanks guys!!!!
« Reply #64 on: January 09, 2015, 10:40:47 PM »
Hallo friends...
after a long time here is finally an update, I had gone forward but had no time and energy to upload the images and organize a post, well, now here I am...
I analyzed a couple of pictures:
and prepared the Gaspatch MG with personal modifications.
The shield under the gun's mouth is a brass PE provided along with the 2 Vickrs kit by Gaspatch, the lever with handle was made by me with electric copper wire and the white things are plasticard added by me.
The front supporting pieces are not even in length, they have already been modified to a more acceptable and even dimension.
I understood just after completion of the piece that the small tripod was buried in the cowling so it was not visible... but I like the way I have made it and will leave it there!!
I was also mislead by observing this picture:
where the MG seems not to touch the cowling, all the other Ni17 pics I found around showed the MG laying directly on the cowling.
In the above pictures you can see also the attempt to recreate the seaming thread fixing the top cowling to the sides of the fuselage, I know, it's not a good work, also the thickness of the wire is a bit excessive... OK red mark on it but let's go ahead...
here you see the attempt to re-create the oil tank, the windshield was provisionally put in place to see the way it looked.
After I sprayed the fuselage with gray primer and painted glossy black the metal components to have a different shade of aluminum.
I will spray the model using a rattle-can of Tamiya TS 83 "Metallic Silver".
« Reply #65 on: January 09, 2015, 10:49:57 PM »
I turned my attention to the V shaped inter-wing struts: here they are: the metallic horizontal bands are just a couple of "positive" marks and the moulding marks are very thick.
So I filled the space between the positive marks with Mr.Surfacer 1000 and filed away the extractor marks:
Finally I painted them (some necessary touch up appears after magnifying...)
Undercarriage ready and primer-ed:
Undercarriage, wheels and fin painted:
« Reply #66 on: January 09, 2015, 10:58:16 PM »
Last things done yesterday were to preshade the tail plans, glue the control horns on them, fix the assembly to the fuelage and set the rigging in place:
Here I completed the tail assembly with the small struts, I used 0.8 mm diameter plasticard rod in place of those supplied by the kit, in my opinion too thin:
Some preshading also on the rear part of the fuselage:
Dry fit test of the rudder on the model:
That's all for now!!!!
Thanks everybody for the attention...
AnDonio
Offline Adam
« Reply #67 on: January 10, 2015, 12:44:54 AM »
With enviously I observe your progress in the construction of your Nieuport.  ;)
Unfortunately, I had to suspend the work on my Nieuport.   :'( Just before Christmas, my aunt broke her leg.  :'( Because she lives alone so I invite her and now she is staying in my room where I have a workshop.  :'(
Adam.
« Reply #68 on: January 10, 2015, 12:58:37 AM »
Adam.
Adam, thanks for your comment, it is a very lovely decision to host your wounded aunt...
By the way for her health and for your hobby I wish the poor lady a fast recovery!!!!
Offline IFF1418
« Reply #69 on: January 10, 2015, 02:17:54 AM »
Hi Andonio,
This is such a nice and wonderful build to follow. Your inventiveness and craftmanship are fabulous. Teriffic research you did too. Wonderful!
Kind regards
Patrick
« Reply #70 on: January 10, 2015, 02:48:39 AM »
Very nice, Antonio!  I love your machine gun mount.
« Reply #71 on: January 10, 2015, 02:24:28 PM »
Looking good Antonio. Like Bud I really like the Machine Gun Mount!
Offline xan
« Reply #72 on: January 10, 2015, 09:50:59 PM »
very interested i your mount.
I do love the Nieuports, and italian decoration are quite unusual.
keep going on!
Xan
« Reply #73 on: January 10, 2015, 10:41:33 PM »
Thanks everybody!
« Reply #74 on: January 14, 2015, 02:23:40 AM »
Hallo...
yesterday I had time to put in place the cabane struts and the rigging between the two front struts
Then I tried to position (just laying it on top of the struts) the upper wing
And it went to its place very precisely... wow
Now I was looking again to this image
and noticed Baracca was using an Aldis gunsight, for sure he had one on his SPAD, therefore I will try to reproduce one.
I don't have any picture (other than this) to understand where it was placed, but from this picture it seems to be on the left of the Vickers and maybe on the left of the windshield too...
What do you think?
Is it possible it was in front of the glass ? Could Baracca aim without putting his eye on the lens?
Let me know your opinion!
Antonio
« Last Edit: January 14, 2015, 03:27:11 AM by andonio64 »
