Author Topic: Fokker D. VI Roden 1/72  (Read 3459 times)
Offline Wolf
« on: September 15, 2014, 05:27:05 PM »
One of my favorite WW.1 biplanes and the smallest I have built so far is the Fokker D. VI.
The old Roden kits are not easy to build. The Fokker D. VI is no exception. Especially the stuts and the upper wing made some touble. The wing was disorted like a banana. Droppiong it several times in Hot water and carefull bending and aligning solved the problem.
I used the PE set from part to enhance the model. 75% of the set was used, maybe 25% are visible ;)
I was not happy with the Roden decals and used the Eagle Strike decals which at the time when the model was built,  were to my opinion the best available.
The struts were also disorted and very thick. I sanded them down as much as possible and straightenend them. This had to be done very carfull as the plastic was somewhat prone to break, because it was porous.
Weathering was only done with the airbrush and heavy dilluted Tamiya Smoke, Gunze sail and Gunze mud. No oil Colors, no pastels.
Offline Squiffy
Re: Fokker D. VI Roden 1/72
« Reply #1 on: September 15, 2014, 11:13:28 PM »
That's very nice and the first D.VI I've seen on here. I've also built the same kit but I haven't shown it on here because it was my first attempt at putting on lozenge decal and I made a bit of a mess of it.  :-\
« Reply #2 on: September 15, 2014, 11:29:13 PM »
Very nice! The weathering works very well.
« Reply #3 on: September 16, 2014, 04:55:59 AM »
Gorgeous little D.VI, Wolfgang! the lozenge and paint work are magnificent.
« Reply #4 on: September 16, 2014, 05:01:31 AM »
Exellent build.
Squiffi it was not the first D VI.
I have one scratch/conservation build in 1:48. You can see this here under scratch builds.
« Last Edit: September 16, 2014, 08:21:24 AM by radio »
« Reply #5 on: September 16, 2014, 08:13:30 AM »
Wolf,
I can't say it any better than My Amigo! MAGNIFICENT!
Offline Rob Hart
« Reply #6 on: September 16, 2014, 10:50:41 AM »
I think you possess some magic. Your models are like jewelry.
« Reply #7 on: September 18, 2014, 03:06:19 AM »
Excellent build of one of the less known late war aircraft. Great to see this and such a beautifully finished example too.
Offline xmald
« Reply #8 on: September 18, 2014, 06:51:57 AM »
A great model indeed and the lozenge looks perfect! I really admire your craftmanship in such a small scale!
Best regards
Filip
« Reply #9 on: September 18, 2014, 05:34:15 PM »
Fantastic, Wolf. It is probably the best D.VI model I have ever seen. Congratulations!
Offline Stuart Milliken
« Reply #10 on: September 19, 2014, 10:57:43 PM »
Little gem--love it!
Stuart
« Reply #11 on: September 20, 2014, 12:58:11 PM »
Hello Wolf:
Great job on this little gem.  The lozenge turned out quite nicely and the weathering enhances the model.  Very nicely done.
