Author Topic: WNW Hannover Cl.II 1/32 "White 4"  (Read 21465 times)
Offline stefanbuss
Re: WNW Hannover Cl.II 1/32 "White 4"
« Reply #75 on: October 04, 2014, 03:30:19 AM »
Really nice paintjob. I didn't expect that would work so well. Congratulations.
Stefan
Online RAGIII
« Reply #76 on: October 04, 2014, 10:01:06 AM »
Beautiful job on the lozenge, Andrew!  This is going to be a real stunner when finished.
I agree 100%
« Reply #77 on: October 10, 2014, 03:47:09 AM »
Hello Andrew:
Kudos for the effort on the lozenge.  Quite a challnge and effort and you pulled it off nicely.  I am looking forward to seeing how you wrap this up.
BestMark
« Reply #78 on: October 10, 2014, 09:21:11 AM »
I agree 100%
The 3rd Amigo agrees !!
« Reply #79 on: October 10, 2014, 09:30:39 AM »
I've just caught up on this one...great job on the hand painted lozenge - I know exactly what you're going through....
Offline AndrewS
« Reply #80 on: October 10, 2014, 05:02:27 PM »
Thanks to everybody  for the nice comments!
I'll post some updates in the enxt days. I'm painting the underside lozenges, so not too much to show you...
Just a lot of masking  ;D
Offline AndrewS
« Reply #81 on: October 13, 2014, 04:36:38 PM »
Hi!
The fuselage is finished   :D
Now I need a gloss coat, decals and weathering...
Meanwhile I'm going on with other parts.
Here's the engine. I've added the lifters and spark plugs cables.For the cables I've used elastic thread instead of the usual copper wire and I must say that is much easier  :)
I still need to paint some details of the intake assembly.
Now that the fuelage is painted the work should speed up.
That's all!
« Reply #82 on: October 13, 2014, 06:40:12 PM »
You have done a superb job Andrew painting the lozenge and the engine looks amazing.
« Reply #83 on: October 13, 2014, 09:30:45 PM »
Dear me, that Argus of yours looks so real! Fantastic modelling!
« Reply #84 on: October 13, 2014, 09:49:25 PM »
Looks fantastic Andrew!  What a great mix of colors in the lozenge paint.
Can you please explain how you used elastic thread for the spark plug cables?  Anything that is easier is always welcome. :D. Thanks.
Offline AndrewS
« Reply #85 on: October 13, 2014, 10:02:25 PM »
hi,
The red part is an albion alloy tube  (0.9 mm maybe a 0.8 is the right measure, but I had only 07 or 0.9...)
I've inserted in the tube 6 pieces of elastic thread (eazy line)
I've attached the tube to the cylinders and then I've cut to measure and attached the wires to the distributor (i've used white glue).
For the pieces from the plugs to the tube I've simply attached a piece of elastic thread to each spark plug, then cut to the right lenght (a little higher than the base of cylinders) and then I've attached the other end to the tube
Then paint and there you go  :D
If something is not clear just ask.
By the way, I've copied this technique, but I don't remember if from a forum or an article from a magazine (maybe a Windsock one..)
Offline KitRookie37
« Reply #86 on: October 14, 2014, 01:12:06 AM »
Hello to all,
A great painting and patience lesson !!  :D :D
Best regards.
Alain.
Use the force, Luke.
« Reply #87 on: October 14, 2014, 01:17:33 AM »
A fantastic work to your plane and engine.
Online RAGIII
« Reply #88 on: October 14, 2014, 01:39:00 AM »
Outstanding progress! Your painted lozenge is beyond words and I love the engine!
« Reply #89 on: October 14, 2014, 02:23:23 AM »
Your lozenge painting is brilliant and that engine is so realistic.  Excellent work, Andrew.
