Author Topic: WNW Hannover Cl.II 1/32 "White 4"  (Read 21346 times)
Offline AndrewS
« on: August 11, 2014, 11:51:20 PM »
Hi!
Time to build Another WnW kit.
This Time I've decided to build the Hannover Cl.II, mainly for the challenge of painting the Fuselage logenzes  :P
I'll build this one
As aftermarket items I'll use Wood&Wire Lozenges and Gaspatch Turnbuckles.
let's start with cockpit as usual.
Before painting the wood I've masked and sprayed the fuel tank, because the masking over the oil paint would be tricky
Some chipping done with maskol. I'll decide later if is too much, and in case is easy to correct with some grey paint.
Oils applied over a Sand color acrylic base
Some details added (no shading or wethering yet)
The kit has some molded fuel lines details. I deleted them and replaced with copper wire.
The glossy spots that you see are from clear paint used to fix the wires and they will be corrected with some clear overspray.
Same work on fuselage
Now, will I wait for oils to dry I'll start covering the wing. In the next post...
bye
Re: WNW Hannover Cl.II 1/32 "White 4"
« Reply #1 on: August 11, 2014, 11:55:00 PM »
It's coming along nicely Andrew. I'm looking forward to seeing how you tackle that lozenge.
Offline AndrewS
« Reply #2 on: August 12, 2014, 12:01:45 AM »
Now the Wood&Wire decals
Some comparison with kit decals
looks good, but can you spot the error ?  ::)  Later we'll see...
prepared the wings: white base and then gloss clear
Cut the decals from support ( before this you have to spray a clear cote over them)
And apply! No problem , they are delicate, but with a little attention they look good and conform very well to details   :)
Now the aileron.. and guess what? 2 Left undersurface aileron decals and no right ones!!  >:(
I've used Some spares decals that I had, they are a little darker, but will be on the underside and they could be an aileron covered with another fabric batch  ::)
I was a little disappointed  with this error. Nobody tested the decals before selling???  ???
Anyway , that's all for now.
Bye
« Reply #3 on: August 12, 2014, 12:14:29 AM »
Super, love the gas tank & dash
« Reply #4 on: August 12, 2014, 12:38:28 AM »
Hello AndrewS:
You are doing a great job on the interior pieces and the lozenge work.   I like the W&W lozenge with the fabric detail as well.  Looks good so far.  This is a scheme on my list and I will be following to see how you manage to do it.  You're under the "microscope".  ;)
Offline stefanbuss
« Reply #5 on: August 12, 2014, 12:52:18 AM »
Absolutely convincing work on the wooden parts.
I agree, the fact that you have two left aileron decals but none for the right side is disappointing. Maybe contacting W and W with this problem might be of any help?
Stefan
« Reply #6 on: August 12, 2014, 02:47:08 AM »
Very nice work Andrew; your decal work is really done well and your wood grain and interior detail superb. I'd leave the fuel tank as is...........it is very convincing.
Offline LukasTheLight
  • Addicted to Wingnuts...
« Reply #7 on: August 12, 2014, 06:22:17 AM »
I love this marking!!!! Also love your wood surface....  :)
Looking forward to see more!!!!
Lukas
Lukas
« Reply #8 on: August 12, 2014, 07:29:10 AM »
What a super start Andrew. This is shaping up beautifully. I can't wait to see how you handle the fuselage lozenges.
« Reply #9 on: August 12, 2014, 07:51:46 AM »
You're off to a flying start Andrew, and what you have achieved so far is looking excellent.
« Reply #10 on: August 12, 2014, 08:24:06 AM »
This is one of those Rocket Starts! Beautifully done wood and the tank looks excellent to me. Also the Lozenge looks to be applied very nicely! Outstanding Start to say the least!!!
« Reply #11 on: August 12, 2014, 08:53:56 AM »
Most excellent start so far Andrew . I would be disappointed as well with the lozenge decals .
Offline petrov27
« Reply #12 on: August 12, 2014, 09:07:23 AM »
Great start there! Love this scheme - it is the one I would like to do also but am not sure how I could effectively pull off the fuselage loz....
-Patrick
« Reply #13 on: August 12, 2014, 09:13:59 AM »
Excellent beginning, Andrew.  Pity about the aileron loz, but you recovered beautifully.
« Reply #14 on: August 12, 2014, 09:27:13 AM »
Great start, Andrew!  Your woodgrain and fuel tank are both superb.  Your work
on the lozenge is really well done, despite the printing error. I look forward
to the next updates.
