Author Topic: Fokker Streaking. Show your Method  (Read 93061 times)
Re: Fokker Streaking. Show your Method
« Reply #60 on: December 22, 2017, 10:14:21 AM »
Well Done !  my Amigo !!
« Reply #61 on: December 22, 2017, 10:34:11 AM »
And so says the third Amigo!
« Reply #62 on: November 17, 2018, 02:04:21 PM »
My latest streaking project. WNW Fokker DVII. I used a different Mixture of Oils this time. Prussian blue and burnt umber. Some was applied pre mixed and some in the form of dots blended together. All applied over an acrylic beige base. I used my usual damp flat brushes to remove unwanted pigment.
« Reply #63 on: November 17, 2018, 02:40:47 PM »
Spectacular results, as always, Amigo!  I know I must sound like a broken record, but I think this is my favorite.
« Reply #64 on: November 17, 2018, 08:08:23 PM »
Graet streaking, and great Fokker.
« Reply #65 on: November 17, 2018, 10:50:34 PM »
    Absolutely stunning work Rick, this finish is just plain spectacular. I scrolled way back to the beginning when you started this thread and the improvement in the effect is remarkable, nice work!
« Reply #66 on: November 18, 2018, 12:24:43 AM »
Simply outstanding Rick, your streaked Fokkers are world class.
« Reply #67 on: September 29, 2020, 02:55:56 AM »
I’ve been asked to add to this thread after my Meng Fokker Dr.I build. Just to demonstrate an alternative method of streaking.
I started off by painting the wings linen or any light beige shade to taste,
I then angled the wing across my cutting mat to the degree of slant required, fixed into place with Blu-Tack then used a steel rule an inch or so above the wing as a guide for the airbrush - using the parallel lines on the mat as a guide. But, I found this didn’t work so well on the kit wings. Because of the airfoil shape it didn’t produce dead straight lines, so I ended up doing them freehand but still with the wing fixed and using the mat lines as a guide again - starting well off the wing and finishing well over the other side. It looks like different colours, but it’s in fact the same MRP RAF Dark Green but just varying the intensity of the lines in sections.
I gradually built up the streaking effect. I limited the needle’s movement rearwards so I didn’t get a ‘splurge’ of paint and used a low pressure setting.
Simple really!
Offline kkarlsen
« Reply #68 on: September 29, 2020, 03:08:08 AM »
Very nice result!
« Reply #69 on: September 29, 2020, 04:54:15 AM »
Excellent results and thanks for adding this method to the thread! I am going to experiment on an old wing and see if I can do the basics your way and perhaps do just a tad with a brush. Again thanks for posting this beauty!
« Last Edit: December 03, 2020, 11:39:03 PM by RAGIII »
Offline rayb24
« Reply #70 on: December 08, 2020, 01:04:58 AM »
My first attempt with brushed on oils, using Windsor and Newton series 2 oils.. still a work in progress. This is a 1/48th F1 (voss’s) aircraft thats on my workbench..
Issues that I have to think through is the buildup on rib tapes and matching colours with airbrushed cowl.  But all in all its a fairly easy process
4E17F1D1-2CC8-4F27-878B-92C4FED728EE by Ray, on Flickr
FE241287-FBA8-4AF1-BC6A-40D414A5DEC1 by Ray, on Flickr
Ray
« Reply #71 on: December 08, 2020, 01:39:40 AM »
Looking great! As for the build up on the tapes you should be able to blend the oils in while still wet. On the other hand I have noticed some build up on the tapes(outlining almost) on the real birds. A wide, very soft, flat brush helps with the blending.
« Reply #72 on: January 25, 2021, 01:55:30 AM »
I tried a little different Method on this Roden Fokker DR1. I used Acrylics as seen in the photo. The wash was applied and also mixed with the other colors to add differnet intensities to the streaks. The usual brushes were used to remove and smooth the unwanted paint.
« Last Edit: April 04, 2023, 05:09:58 AM by RAGIII »
« Reply #73 on: January 25, 2021, 05:57:25 AM »
Rick, this looks nice and with acrylic paint it is may be a quicker method, but the streaking reference is (for me) your D.VII on top of the page! ;)
« Reply #74 on: April 16, 2022, 05:18:04 AM »
I figured I would add the other three Triplanes to the thread. All are done with oils using the standard method and colors: Ivory black, Cadmium Yellow (50/50 mix, and just a "Touch" of Harrison red.
« Last Edit: April 04, 2023, 05:09:30 AM by RAGIII »
