Author Topic: Another WNW Snipe  (Read 9283 times)
Another WNW Snipe
« on: April 28, 2014, 10:58:53 PM »
Greetings folks:  I have been working on the WNW Sopwith Snipe.  I have been following the other builds and have learned a lot from them and thought I would post some of my progress to date.  It is certainly a complex kit with a complex interior.  I tried to take short cuts, but should have followed the directions.  I managed to make it all work though.  Let's start with the fuselage:
I painted the various sections and applied the standard wood grain technique to that portion called out in the instructions.
Here is the almost completed interior.  I pre rigged the rudder bar parts A13 and A6.  This is a very delicate assembly and care needs to be taken to prevent breakage.  I used invisible thread and BVB's tubing.  I then pulled the lines through the completed floor board assembly and through the pre drilled holes in part A36.  I didn't CA glue the ends, but rather paper clipped the ends together until the interior side walls were assembled giving it strength.  I also included a cross brace on the underside.
I used the HGW seat belts.  If I did it again, I would overlap the buckle end over the leather side.  I like using these.  HGW has really improved their product and assembly sequence.
Another view of the interior with the machine gun mount in place.
Here is the fuel/oil tank.  I experimented with oils along the fuel line and the fuel line input fitting.  As this is totally invisible once assembled, I thought it would be could to practice the capillary oil method.  I was fairly pleased with the results and applied it to some of the internal plumbing on the instrument panel and framing.
Here is yet another of the port side of the interior with the oil method and dry brushing to highlight some of the mechanisms in the complex interior.
The instructions were a little vague about the painting of this area.  After looking at the photo's in the instruction booklet and the actual a/c photo's, I decided to paint these parts aluminum.  Some are visible once the fuselage halves are together, so I went with aluminum.
The machine guns in place.  I painted them Testors Model Master Non Buffing Burnt Iron and  highlighted with dry brushing.  I painted the ends leather as per the photo's and instructions.  I think they look fine.
They are a little fiddly to put into the mounts, but with care and patience they eventually popped in.
That's it for now.  Stay tuned for more modeling excitement as it occurs.
« Last Edit: April 28, 2014, 11:06:06 PM by mgunns »
Re: Another WNW Snipe
« Reply #1 on: April 28, 2014, 11:46:40 PM »
Fantastic interior Mark, really looks great! I may tackle this one next so I'll be following your progress and the several other Builds here with interest!
« Reply #2 on: April 29, 2014, 12:46:14 AM »
Not Another Snipe build...an absolutely Beautiful Snipe build! I agree with your decision on the painting of that not so clear portion of the interior. An argument could also be made for service grey, IMHO.
« Reply #3 on: April 29, 2014, 12:47:15 AM »
Go get 'em,  Mark!  :o
Lovely cockpit - looking forward to seeing more.
vB
Offline Andi Little
« Reply #4 on: April 29, 2014, 12:47:41 AM »
It matters not that a Snipe has been built before - it's always a fresh treat to see one of these builds come together. That and each individuals take on problem solving and finish is enough to keep me coming back time after time.
And what a fabulous start you've made to the project - this is a thread I'll be keeping an eye out for!
KBO ............. Andi.
« Reply #5 on: April 29, 2014, 01:06:22 AM »
That looks excellent Mark!
« Reply #6 on: April 29, 2014, 01:08:02 AM »
Thanks guys for stopping by and your compliments.  I almost did go with the service grey, but; and that's a big but; I had the silver out painting some other sub assemblies, and thought I would just go ahead with that.  With the fuselage buttoned up I can move on to the painting and wings etc.
Thanks again
« Reply #7 on: April 29, 2014, 02:06:32 AM »
Beautiful start on what is sure to be another brilliant model from your capable and talented mitts, Mark!  I had the great good fortune of seeing Javier Arango's Snipe up close and personal a few years ago at his facility in Paso Robles.  The areas that you painted aluminum were indeed aluminum, so well done, buddy.  Looking forward to more.
PS-How's the NorCal house search coming?
« Last Edit: April 29, 2014, 04:13:56 AM by coyotemagic »
« Reply #8 on: April 29, 2014, 02:40:32 AM »
Beautiful start on what is sure to be another brilliant model from your capable and talented mitts, Mark!  I had the great good fortune of seeing Javier Arango's Snipe up close and personal a few years ago at his facility in Paso Robles.  The area's that you painted aluminum were indeed aluminum, so well done, buddy.  Looking forward to more.
Thanks Bud:  So far the model is coming along nicely.  The interior is pretty complex and I dallied on it.  I hope to have it complete by our next model club meeting.   As to NORCAL house hunting, as mentioned, Redding beckons.  We are going to Launch Claire in a month or two to scope it out up there.  We get a lot of info from the realtor so we need to scope it out.
Take care
Offline IFF1418
« Reply #9 on: April 29, 2014, 02:49:25 AM »
Sorry Mark, my message seems to have been whiped away by another incoming post.  What I wanted to say is like Rick said, this is not another Snipe build but a teriffic build of a beautiful a/c. Your interior is tremendously done and alive, with a magnificent seat, lovely cushion and very nice instrument panel. Add to this the beautiful guns and your up to make it a real winner. Well done my friend.
Kind regards
Patrick
« Reply #10 on: April 29, 2014, 04:31:36 AM »
Take care
Mark,
Is that Redding, California? If that's the case you will be riding your bikes more often. No 10 foot snow drifts to worry about  ;)
Good luck!
vB
Offline TomR1981
« Reply #11 on: April 29, 2014, 04:34:41 AM »
Looks great Mark.
Funnily enough I stripped the grey off those panels on my Snipe earlier today after realising if all the other metal parts were bare aluminium then those parts wouldn't have been painted. It'll be interesting redoing it with the fuselage already together.
Looking forward to seeing this one come together.
Tom
« Reply #12 on: April 29, 2014, 04:38:07 AM »
Take care
Mark,
Good luck!
vB
Hi Bob:
That is correct, Redding California, where the yearly average snowfall is 4"  not 6'!  Hopefully.
« Reply #13 on: April 29, 2014, 04:41:44 AM »
@ Bo:  Thanks for stopping by and checking it out.  Appeciate your comments.
@ Patrick:  Thank you for stopping by and your comments, duly appreciated.
@ TomR:  Thanks for stopping by and checking it out.  Aren't you building one as well?  There is one other person doing one I think from the Netherlands and Jknaus.  Almost a Snipe hunt! =0  (Veiled attempt at humor)
Offline treadhead1944
« Reply #14 on: April 29, 2014, 05:01:35 AM »
Stunning work, I look forward to watching it come along.
