Author Topic: WNW Fokker DVIIF: Erich Lowenhardt, Jasta 10  (Read 76496 times)
Re: WNW Fokker DVIIF: Erich Lowenhardt, Jasta 10
« Reply #30 on: October 17, 2013, 09:23:09 PM »
Hi Rick:
I am getting back into the forum as the weather is heading south and the motorcycle is all but put away.  I have a stalled DVII on the bench and your work is inspiring me to get back at it.  As always Rick, your work is stellar and the Aviatic decals, well, they look great!  So many great aftermarket products now for the 1/32nd WWI Modeler.  I will be following your build and look forward to your updates.
Thanks Mark. Your interest and support are always appreciated!
Rick,
You and Bud are really progressing, I'm lagging way behind, have not even started one of these yet as have 2 "other" projects in the queque.
Amigo 3
Thanks amigo  8) This kit really lends itself to relatively quick building.... unless you are detailing like Bo  ;D
« Last Edit: December 16, 2018, 02:20:56 PM by RAGIII »
« Reply #31 on: October 17, 2013, 09:26:24 PM »
I got a little carried away with construction and didn't take any photos of the panel before installation  :-[ That being said, a little touch up on the seat and the fuselage gets joined today.
PS: Also noticed a little touch up/re- gluing needed on the framework when I looked at the photos........ took care of that right away.
« Last Edit: October 17, 2013, 10:58:14 PM by RAGIII »
« Reply #32 on: October 17, 2013, 09:45:23 PM »
If all goes well with the remainder of my build and time allows I will be using this figure with my DVII:
Manta Figurines Latest release,
« Reply #33 on: October 17, 2013, 09:58:18 PM »
Wonderful job on the cockpit, Rick, and your choice for the
flyer to accompany the Fokker is first rate.  I'm enjoying your
build, my friend...looking forward to the next update.
« Reply #34 on: October 17, 2013, 10:58:53 PM »
Thanks for the Comments and Support Ernie!
Offline stefanbuss
« Reply #35 on: October 17, 2013, 11:04:06 PM »
I am really looking forward to yourself painting the pilot's figure. Choosing the mantafigurines one was a very good decision as this pilot goes rather well with your Fokker.
Stefan
« Reply #36 on: October 18, 2013, 08:18:05 PM »
Stefan
Thanks Stefan. The figure is nicely sculpted. Eventually I may also use the Kellrkind Mechanic with the Heinecke chute to augment the Pilot..... We shall see  ???
Offline IFF1418
« Reply #37 on: October 19, 2013, 01:51:21 AM »
Hi Rick,
Your cockpit is wonderfull and the instrument panel looks really great!
Kind regards
Patrick
« Reply #38 on: October 19, 2013, 07:01:30 AM »
Hi Rick,
Kind regards
Patrick
Thanks Patrick! I truly appreciate your comments. I have progressed since the last photos. I have added some wrinkles to the fuselage side using my usual technique of Delta Ceramicoat  acrylics, and have primed the fuselage in order to apply the WNW Lozenge. This will of course be painted over with Yellow!
« Reply #39 on: October 23, 2013, 08:41:19 AM »
I have assembled the fuselage and applied the WNW Lozenge. The nose panel and radiator were difficult to align, more so than my first WNW early Fokker Built DVII. I don't know if others had this issue but the part numbers for the lower fuselage panel and radiator,side panels etc. DID NOT Match the Numbers on the sprues? In the end I looked at the parts not for use and used the ones in the right positions.
« Reply #40 on: October 23, 2013, 09:14:37 AM »
Gorgeous work, Rick.  You did a brilliant job with the lozenge application.  Looking forward to seeing it painted over with yellow.
« Reply #41 on: October 23, 2013, 10:19:58 AM »
Thanks Bud! This is pretty standard WNW cookie cutter stuff. The colors are not that good but a tone down helps. Fortunately with the over paint a little bright is ok!
Offline Zabu
« Reply #42 on: October 23, 2013, 11:23:31 AM »
Very nice decaling, a perfect job for the lighter tone of yellow to be quite smooth.
« Reply #43 on: October 24, 2013, 04:23:36 AM »
dittos to the above, await the next pics !
ED
« Reply #44 on: October 24, 2013, 04:30:07 AM »
Beautiful work, Rick.  If my models come out as good as yours, I would
be some proud!  Lovely job and I look forward to the next photos.  They
will be a great reference when I finally get to my D.VII.
