Author Topic: Caudron G3 1:32 scale  (Read 37263 times)
Re: Caudron G3 1:32 scale
« Reply #60 on: July 04, 2013, 07:40:33 PM »
I made the top wing by glueing two sheets of 1.0mm styrene sheet together after the wing shape was cut out, while the glue was still wet I formed the wing shape over a length of aluminium tube. This was left taped to the tube for about half an hour. I left the wing overnight for the glue to fully cure before I added the ribs, these were cut from styrene strips. The rear ribs are of a larger size , this is where the wing warping took place. The top wing is over 41cm in length so it dwarfs the bottom wing. The photos show the top wing with only one coat of spray putty, many coats will be added then the wing will be sanded to give the hollows between the ribs.
« Reply #61 on: July 04, 2013, 10:02:06 PM »
She's coming along nicely Des. I'm looking forward to seeing the top wing when you have it finished.
Offline Zabu
« Reply #62 on: July 05, 2013, 12:24:15 AM »
Lovely!
« Reply #63 on: July 05, 2013, 04:26:09 AM »
Gee Des, I'm at a loss for words.  I think all the adjectives have
been used up, so just let me say it is such a pleasure to see
what an artist in our hobby can do.  Thanks for sharing it with us.
Best Regards,
« Reply #64 on: July 05, 2013, 10:36:38 AM »
This has gone together very well!! Im looking forward to the next installment. Any concerns about the top wing weight outside of those interplanes?
« Reply #65 on: July 05, 2013, 05:33:26 PM »
i thought the toothpicks looked really beefy compared to my toothpicks. the toothpicks commonly found in the u.s. are not bamboo, they are of a light, fragile wood. they are more like 1mm diameter. we have bamboo skewers used to spear sandwiches together at a deli. i think your product is more akin to what i call bamboo skewers. makes more sense. they look great and if they are bamboo i'm sure quite strong.
Offline LindsayT
« Reply #66 on: July 05, 2013, 11:06:20 PM »
Okay, that makes more sense. I'd never seen such a beefy toothpick, but I've seen plenty of bamboo skewers that would fit the bill. Toothpick...skewer, knickers...gotch, it's all the same!
So Des, how did you go about flattening the bamboo to get a consistent result? Between two boards in a vice?
Beautiful stuff, mate.
Lindsay
« Reply #67 on: July 06, 2013, 02:26:53 AM »
Hello Des:
I am just getting to this portion of the forum after a bit away.  WOW!  What an undertaking.  I think between you and Gregory you have certainly chosen some interesting and challenging scratch builds.  A pose down may be in order!    ;)Again, you have done outstanding work to date on a difficult and challenging subject and will have a fine model when complete.  Looking forward to seeing you progress.
« Reply #68 on: July 07, 2013, 10:38:23 AM »
Hi Scott - the toothpicks we use are as depicted in the photo below, they come in a pack of around 100 and are made from bamboo, very tight grain and very strong.
Hi Lindsay - To flatten the two sides of the toothpick I just used a No.11 scalpel blade (fixed to a handle), it is a very simple matter of scrapping the blade along the length of the toothpick, the material comes off quite easily, do both sides evenly and keep measuring until 1.0mm is reached. Once finsided I sanded the sharp edges to give a rounded look. Go here for a full description on how I made the struts.
http://www.ww1aircraftmodels.com/page42.html
Offline LindsayT
« Reply #69 on: July 07, 2013, 03:25:15 PM »
Right! I keep forgetting about your main page build log. Beautiful detail!
Lindsay
« Reply #70 on: July 09, 2013, 08:12:01 PM »
Top wing is just about finished, still needs a coat of satin clear, there will be no decals on the top wing. The top wing is just sitting on the struts for photo purposes. Thought I would toss in a few photos with some figures just for fun. Shown here are Steven Robson's immaculate spoked wheels and Doug Craner's brilliant laminated wood propeller.
« Reply #71 on: July 09, 2013, 08:30:51 PM »
Fantastic craftsmanship Des! ;D  She will be another stunning model when complete.
Thank you for sharing in such detail both here and in the main page build log.  I have learned a great deal from your scratch build logs, and the Lloyd I'm working on can trace its modeling lineage directly to the inspiration and information you have provided here.  I am very grateful to you, your knowledge and willngness to make it available to us all on this forum.  Thanks, and very well done! ;D
Offline Steven Robson
« Reply #72 on: July 10, 2013, 01:47:33 PM »
This Caudron just keeps getting better every time I log-in.
I'm very keen to see this one finished, I think rigging the wings will be exciting.
And lovely figures by-the-way, where did these come from?
Best Regards
Steven Robson
Offline Andrew H
« Reply #73 on: July 10, 2013, 07:12:34 PM »
Hello Des - very new member here. Just to say that seeing your fantastic work on the Caudron & the Taube just blows me away! Having just returned to modelling after a 15 year gap (mainly due to the output of Wingnut Wings) to aspire to do anything approaching your beautiful work is rather daunting to say the least! But I will persevere and can only say I wish this website was around in the 70s,80s & 90s.
Offline Old Man
« Reply #74 on: July 14, 2013, 05:52:05 AM »
Simply beautiful, Sir!
