Author Topic: Caudron G3 1:32 scale  (Read 37273 times)
Re: Caudron G3 1:32 scale
« Reply #75 on: July 14, 2013, 08:38:02 PM »
Thanks very much for all your kind comments, they are much appreciated.
The top wing is now fixed and I have started the rigging, I am using 0.12mm monofilament and brass tube all held together with CA. This aircraft has double flying wires and double landing wires so there will be quite a bit of rigging. Once the rigging is completed I will add the outrigger struts which will hold the wing tip of the top wing, these struts are about 75mm long and are angled at 45 degrees.
« Reply #76 on: July 14, 2013, 10:20:12 PM »
Here is a size comparison with the WnW Sopwith Snipe, the very long top wing makes the Caudron look big but when put beside a single seat fighter it is not a big aeroplane at all, and it's a two seater.
« Reply #77 on: July 14, 2013, 11:34:20 PM »
Outstanding work as always Des, a pleasure to see.
Thanks for sharing!
Offline Vladimir Ziska
    • Nordland Models
« Reply #78 on: July 16, 2013, 07:48:50 AM »
Hi Des,
It is neext master kit from master modeler. Viva for your hand.
Vladimir
Offline Zabu
« Reply #79 on: July 16, 2013, 09:02:42 AM »
In one word... Fabulastic!
« Reply #80 on: July 16, 2013, 11:28:03 PM »
You're outdoing yourself on this one Des. Another museum quality build for sure.
« Reply #81 on: July 17, 2013, 01:19:13 AM »
  Des,
Absolutely Outstanding project to date my old friend.I completely agree with Chris you have outdone yourself once again with this latest magnum opus.
Offline Flip Hendrickx
« Reply #82 on: July 17, 2013, 04:43:42 AM »
Wow, you never cease to amaze me, Des. That is one fantastic build. Truly inspiring!!!
Looking fwd to the rest of this build.
Grtz
Flip
Offline Old Man
« Reply #83 on: July 18, 2013, 09:43:30 AM »
Looking great, Sir.
Did they double up on the training version only?
I have quite forgotten if the standard service type had doubled wires.
« Reply #84 on: July 18, 2013, 11:24:08 AM »
Thanks Old Man, it is a bit difficult to work out the rigging system on this aeroplane, I have a lot of information and photos and it is half half, so I decided to go with the double wires, besides that, I love doing the rigging so the more the better. Most of the in sevice types I have seen have double flying wires but not the double landing wires, but there are some cases where both exist, so it's a guessing game. It's a bit like the wheels, some show them as being uncovered while others are covered, and the propeller type is different depending on the use of the aeroplane, all these things make scratch building fun.  ???
« Last Edit: July 18, 2013, 11:28:06 AM by Des »
« Reply #85 on: July 19, 2013, 01:07:50 PM »
The wing rigging is now finished, I also added the outrigger struts, these are also made from bamboo.
« Last Edit: July 19, 2013, 01:10:49 PM by Des »
Offline LindsayT
« Reply #86 on: July 19, 2013, 02:11:00 PM »
Incredible, Des!
Did you find there was a lot of back-and-forth on the rigging tension? Rig one end the other goes slack?
Lindsay
« Reply #87 on: July 19, 2013, 02:15:33 PM »
Thanks Lindsay for your comments, much appreciated.
I only had one set of rigging that went a bit slack, all I did was to apply a little heat from a soldering iron and tension was regained.
Offline Whiteknuckles
« Reply #88 on: July 19, 2013, 03:58:37 PM »
Wonderful spiderweb Des, are the outrigger struts bamboo skewers?
Eternal Apprentice
« Reply #89 on: July 19, 2013, 04:01:19 PM »
Yes Andrew, I turned them down to 2.0mm to be the same size as the toothpicks, they were then sut to length and shaped, they are 75mm long but very strong.
