Author Topic: 1/32 albatros D:III roden  (Read 83266 times)
Re: 1/32 albatros D:III roden
« Reply #45 on: May 21, 2013, 10:46:43 AM »
  Paolo,
She's coming along wonderfully my friend. keep up the excellent work.
« Reply #46 on: May 21, 2013, 12:36:58 PM »
On the D.V, be careful not to get too much paint into the slots where the formers fit or it will not go together ...
Offline mc65
« Reply #47 on: May 22, 2013, 09:56:07 AM »
thank you, actually I see this kit as a curse, but, being a gymnasium for models to come, I'll can endure it.
RAGIII,
thank you for the info... check the images below.. you say also about the spreader between the wheels... so it must be just a straight axle?
bo,
got the lesson! here we are, ready to a coat of future....
3316
well, today I did quite something. first of all, I cut the grass close home. now remains just the two acres around! then, I decided to not wait the book on albatros nor the archer ribs I ordered but go on and just relax with it.
I rescribed the elevator and rudder, after modiyfing it, trying to render the structure under the canvas.
3292
then began to glue in place in position some PE from eduard, in order to be ready, one day, to paint the subassemblies.
3298
3300
spandau time!
3306
3309
3310
some nailing over the new panelling...
3321
3323
and, after some future, a try with uschi's decals.
3325
being an absolute beginner, and a woodhead, I managed to fail with the depth's lenght of the panel..
3327
well, that's all... see you at next session!
cheers, p.
« Reply #48 on: May 22, 2013, 01:13:05 PM »
I love it
« Reply #49 on: May 22, 2013, 01:52:11 PM »
  Paolo,
Great works from your talented bench my friend. Keep up the outstanding progress .
-Sören-
« Reply #50 on: May 22, 2013, 03:30:31 PM »
Can You discribe how You made the fabric structure on the rudder and the elevator?
« Reply #51 on: May 22, 2013, 07:54:06 PM »
RAGIII,
cheers, p.
 Looks as though you nailed the correct panel lines! You are correct reference the axle. Just the Axle and a small support bar to the rear of the axle. Your work on this kit is AWESOME!
« Reply #52 on: May 22, 2013, 09:52:27 PM »
I'm thinking Paolo scrapped away with a curved blade to create the effect, but I'm sure the man will correct me if I'm wrong  ;) :D
Doing great work, P!
Keep it up.
VB
WRONG!  :D
« Last Edit: May 23, 2013, 07:46:16 AM by bobs_buckles »
« Reply #53 on: May 22, 2013, 09:59:28 PM »
Good job, Paolo! I really admire your attention to detail.
 I'm, looking forward to more of your build.
Thanks for sharing it with us.
Best regards,
Ernie
Offline mc65
« Reply #54 on: May 22, 2013, 10:00:00 PM »
hi all,
thank for the encouraging, actually, I'm not happy with this kit, it lacks appeal, and I'm not working too much to improve it... :-[
RAGIII,
have you an image of the spreader? I'm still waiting for the book on albatros, and I'm moving blindly, meanwhile!
soren,
the work on control surfaces was quite simple, bob is right:
first I traced the braces position with masking tape, using the WNW kit as reference. I put on them some primer just to understand where I was working.
3286
3291
then I scribed roughly the concave area with a round blade,
3287
and after I worked out the areas with sandpaper, coarse first, fine then.
3290
after a coat of primer, I worked again the surfaces with fine abrasive compound,
3292
it's not enough, yet, but I'm closing to the right result, i think.
3312
3315
bye bye, p :)
« Reply #55 on: May 22, 2013, 10:40:46 PM »
Hey! No fair!! Your Spandau barrels are round whereas mine inevitably come out squashed and dented!  ;D
Offline mc65
« Reply #56 on: May 22, 2013, 10:52:03 PM »
it all depends on what angle you take photographing!! ;D ;D
but, annealing on a flame the metal before bending, and retempering it after (simply burning again and drop it in cold water) will help somewhat... ;)
« Reply #57 on: May 22, 2013, 11:23:57 PM »
Great updates!! Your reworking the flying surfaces has been very effective I think.
Offline mc65
« Reply #58 on: May 23, 2013, 03:47:30 AM »
thank you...
well,
today received the ribs archer. beautiful, but after a quick (not too fast, in fact) I realized that I would need at least 5 packs. at +17 USD each one, plus shipping, plus waiting for .... uuuuuuuuuuff. >:(
autarky, and the fear passes.
3334
autarky, and some 0,05 plasticard and patience!
3336
3337
batman, you're nobody!!! ;D ;D ;D
3339
3340
mmmh ... I failed the rib that straddles the radiator, I guess. :o
3341
3342
and I totally forgot the tail! :( Okay .... talk about it then.
bye, p. ;)
-Sören-
« Reply #59 on: May 23, 2013, 04:02:53 AM »
I'm amazed and learn.
