Author Topic: 1/32 albatros D:III roden  (Read 83141 times)
Offline mc65
Re: 1/32 albatros D:III roden
« Reply #30 on: May 17, 2013, 12:19:44 PM »
hi all,
here I am again for a little updating...
understood that going as per instructions will be over my capacities, I tried the cancian's style:
3214
gone the cloche, I'll try to paint and build (or build and paint..) the most here, then fit in the fuselage...
3210
and, hey! it seems working!! all my apologies to roden, the styrene is quite workable and solid, also to my goofy hands!
3215
now the day's question: behind the seat there is a black hole... in other carts may be seen a canvas tent... here the same?
3217
it seems also that I must thin the end near the spinner... no prob.
3218
and also the cover seems to be right... well, more or less..
3219
that's all, folks!
a big thanks to mr. cancian and bo for the inspiring works they did and doing!
cheers, p.
Offline mc65
« Reply #31 on: May 19, 2013, 04:48:25 AM »
little upgrading...
the engine will drive me crazy. water passage, cut the magneto plate.
3236
first base for wood.
3238
3244
wiring the instruments. by the way, the eduard ones make me not so happy... ideas?
3239
maybe a question I should have done before open the panels...
3240
erase the original front panels. not satisfied about, redo.
2699
new radiator try in place.
3246
fuselage look at.
8935
next upgrading... nextly. first have some sleep. then, there is a forest outside, grass to be cut urgently!
bye, p. :)
« Reply #32 on: May 19, 2013, 07:11:05 AM »
Fine work, P  ;)
Looking forward to seeing more updates from you.
VB
« Reply #33 on: May 19, 2013, 11:07:05 AM »
Nice progress on what looks to be a complicated Roden build!
« Reply #34 on: May 19, 2013, 12:21:20 PM »
Go Paolo go!
-Sören-
« Reply #35 on: May 19, 2013, 02:49:42 PM »
Have You seen the Instrument dials from HGW? I think they Looks very good. They come in brass, black and silver on one etched Frame.
-Sören-
« Reply #36 on: May 19, 2013, 02:57:48 PM »
Is this the wing with the centered radiator You have sanded smooth? I've thought about it to grind away the old radiator and simply  build it new with etched parts on the offset position. But what about the wing spars on the old Position?
« Reply #37 on: May 19, 2013, 09:05:57 PM »
Quote
... the eduard ones make me not so happy... ideas?
You are right, they are horrid. The WNW decals are superb, and their alternate marking sheets come with full sets, so that is an option, but expensive. There are also semi generic WWI instrument faces available from airscale(? Check des's main site ) that aren't as nice as WNW but miles better than the printed Eduard stuff.
« Reply #38 on: May 19, 2013, 11:07:41 PM »
  Paolo,
Outstanding progress my friend. Looking forward to seeing more of this project.
« Reply #39 on: May 20, 2013, 12:42:36 AM »
Looking very nice. I started back into the Hobby with this Kit; she can be a real monster but with effort builds into a very nice result. I'm looking forward to following your Build.
Offline mc65
« Reply #40 on: May 21, 2013, 03:02:03 AM »
hi,
thank you all for encouraging and supporting!
bob,
just received an envelope in very good ealth from you...  ;)
soren,
I tried on the HGW site, but something doesn't work, I was unable to see their products!
about the radiator, this wing has it in the offset position yet, I just carved out the original too big and rough one and put in a spare WNW one. but, wanting to do the work on a center one, I suppose the only way is to rebuild the spar (actually the ribs) with plasticard layers smoooooothed out with some sandpaper and zen attitude...
bo,
I just ordered the airscale decals.. thank you very much for the info!
well, now I have to wait to news from taurus and airscale to go ahead with engine and fuselage... what I can do meanwhile? :)
« Last Edit: May 21, 2013, 03:05:08 AM by mc65 »
« Reply #41 on: May 21, 2013, 06:33:55 AM »
Hi Paolo,
 Thanks for the info  ;)
Offline mc65
« Reply #42 on: May 21, 2013, 07:58:48 AM »
well,
after a very long day, I tried to relax a little on the bench. but not all donuts come out with hole...
the idea was just spray a little of green and tan over the frame, and test if it's better to paint the parts before assembling. actually masking the built structure was a nightmare, so I began to give primer to the D.V parts.
without check for ejector signs, that sure where there, positive and negative. what a courtyard's chicken.  :-[
stopped with primer, will work them out.
3272
3273
so, just some paint here and there... the WNW fuselage sports a tremendous difference with the roden one:
3270
3264
3267
just after cleaning the airbrush, I realized that the green should reach the engine supports...
3275
so I gave up, for today. enough is enough. :(
now I'll go to see what in the hell roschach thinks about that:
3271
bye, p.
« Reply #43 on: May 21, 2013, 09:16:18 AM »
The difference in panel lines I was speaking of is that the OAW has 4 panels as seen on your aircraft. The Albatros built birds had 3. Also the vertical panel line where the 3 horizontal panels end is a bit closer than on the OAW. I had an article on Internet Modeler showing the differences. Have trouble with Java Script so cant provide a link.
Offline BLOWHARD
    • Great War In The Air - Dave Douglass Gallery
« Reply #44 on: May 21, 2013, 10:32:08 AM »
It's going together nicely :D
DAVE IPMS 16124
