Author Topic: WnW Sopwith Snipe 1:32 scale  (Read 38364 times)
Offline Chuckt5
Re: WnW Sopwith Snipe 1:32 scale
« Reply #105 on: February 27, 2013, 09:09:31 AM »
Looks fantastic Des. Looking forward to the next installement!  ;)
Forgive my ignorance, but how are you planning on simulating the buckles for this bird? The don't look like what I've seen on other WW1 aircraft so I'm kind of curious.
Offline IvotB
« Reply #106 on: February 27, 2013, 09:31:00 AM »
Looks like it is being produced by the Master himself. Excellent progress and beautiful build. On the stage it is now in I have only one question: how do you align all the struts: at what angle to the bottom wing and in line, or does the fit of the struts in the holes in the bottom wing leave no room for errors?
regards,
Ivo
« Reply #107 on: February 27, 2013, 09:34:30 AM »
She's really looking stunning with the markings, Des.  As always, a beautiful, clean, flawless project.  I really am looking forward to seeing her finished.
I'll echo what Bud said Des. She looks pristine.
« Reply #108 on: February 27, 2013, 06:46:57 PM »
Thanks guys for all your wonderful comments, I will try and answer some of your questions.
Ian - I don't wear gloves when handling the model, what I do is to wrap a tissue around the fuselage and tape it to itself, this gives me a good place to hold and manhandle the model without causing any marks on the paint work. No matter how clean you might think your hands are there is always marks left on the model if handled too often.
GCN - I found the Gunze Brown Violet to be a pretty good match to what is shown in the instruction book, it does not show up as the true colour in the photos, it appears to be more green where in actual fact it is leaning more towards brownish green.
Pete - Definitely get one, it is a brilliant kit and is so easy to build, you will not be sorry.
Dave - If you built this model OOB you would have a fantastic looking model, Wingnuts have everything you need in the box apart from rigging lines. All I did was to add fuselage rigging lines inside the fuselage, control column, rudder control cable and ignition leads to the engine. The only bit of detailing I have done, but this was for my own benefit only, was to hollow out the venturi and add cross pieces to the inlet.
Chuck - The control cables at the rear end, rudder and elevators, had turnbuckles, these will be added using my own home made variety. The wing rigging will be done using 0.12mm monofilament, I don't like the flat rigging material now available. The top wing will have small eyelets glued into the underside of the wing, the bottom wing will have a new idea I am still playing with, a short length of 0.4mm brass tube with the mono glued inside and a small brass nut to look like the adjusting nut, the brass tube will have a slight bend and be glued directly into the wing - this is an experiment so I will keep you informed if it works.
Ivo - The struts on this model have excellent locating pins and holes, each pin and hole is a different shape so the struts can't be mixed up and placed in the wrong hole. I fitted the two forward cabane struts first, these are an excellent fit and sit exactly where they are supposed to be, I then fitted the rear cabanes but checked the top wing fitment before gluing the struts just to make sure they line up with the holes. Once the cabanes are fixed in position the rest of the struts are very simple, glue each strut into position and with a straight edge run it along the top of the struts, they should all line up as a straight line. Wingnuts have made this task very easy as most of the struts lined up without any need of adjustment.
Offline IvotB
« Reply #109 on: February 27, 2013, 09:13:48 PM »
Des,
Thanks for the explanation. It is nice to follow your routine. Especially because it is almost thesame as what I did with my D.VII. That way I feel less a beginner ;) Perhaps there it was even a little bit easier on the D.VII as the forward cabane struts have 2 (or even 3) connections to the fuselage, leaving little room for misplacement. And after these were placed, the rest followed just as you described with your Snipe.
regards,
Ivo
« Reply #110 on: February 27, 2013, 11:33:00 PM »
Wow - sounds like WNW have eliminated all the possible little 'traps" like mixing up struts and locating holes. This one keeps calling........
Offline Ian from Doncaster
« Reply #111 on: February 27, 2013, 11:33:28 PM »
Thanks Des.  When I built my first WNW model - the RFC Pup - I deliberately painted all the surfaces in CDL "colour" first, before the PC10 representation.  Then, if by over handling the model there was any wear on the PC-10, this would show the underlying CDL as if the real paint had faded.
That said, your work is spotless.
Offline Chuckt5
« Reply #112 on: February 28, 2013, 05:09:46 AM »
Interesting! I will for sure keep my eyes on how this all come out.
« Reply #113 on: March 01, 2013, 07:35:05 PM »
The top wing has now been fitted, alignment with the struts was perfect and was so easy to fit, the locating pins on top of each strut give a really good secure fit. I have also rigged the cabane struts, wing rigging is next on the agenda. I fitted the windscreen as well, it has a hole through the middle for the Aldis Sight to pass through.
Offline michael
« Reply #114 on: March 01, 2013, 08:15:43 PM »
Fantastic as ever Des realy coming along now
michael
« Reply #115 on: March 02, 2013, 01:27:37 AM »
Hello Des:
This really is a neat looking airplane.  Seeing it unfold on your bench really brings out the uniqueness of it.   Glad to see too that the upper wing fit is an easy task.  The NINAk was too.  One would think with all those struts it would be a bit of a chore.
I like the Russian scheme as well.  Not real colorful, but neat.
« Reply #116 on: March 02, 2013, 01:43:36 AM »
She's really looking the part now, Des.  The more I read of the excellent fit and the ease of construction, the more I want to get started on mine.  Just have a couple things to clear of the bench first.  I'm looking forward to seeing her fully rigged.
Offline Pete Nottingham
« Reply #117 on: March 02, 2013, 03:14:04 AM »
Lovely build Des, neat colour scheme as well, looks good.
Pete.
« Reply #118 on: March 02, 2013, 03:49:15 AM »
Great looking bird and as about as sinister looking as a Snipe can get!!
Dekenba
« Reply #119 on: March 02, 2013, 04:31:37 AM »
Are you going to close the gap between rudder & fin?
I'm not sure you need to - the bottom illustration on the datafile 46 shows a gap big enough to drive a bus through!
