Author Topic: Wingnut Wings WNW Roland C.IIa "White 2", Schusta 6  (Read 42299 times)
Re: Wingnut Wings WNW Roland C.IIa "White 2", Schusta 6
« Reply #195 on: January 08, 2026, 01:48:30 AM »
Just as Paul implied, I?m at a loss for words.  You mentioned at one point that ?it?s not perfect ? well, I would argue that your efforts are about as close to perfect as possible. Very inspirational work!
Tim
Offline Umlaufmotor
« Reply #196 on: February 01, 2026, 11:53:37 PM »
Tim
Hello Tim,
Thank you very much for your kind comment - it's true, I'm usually not 100% satisfied with my own work, it's just not perfect - although what's shown here might not be so bad after all.
Servus
Bertl
Offline Umlaufmotor
« Reply #197 on: February 01, 2026, 11:57:07 PM »
The finish on the cockpit trim is superb! Bravo, Bertl.
Hello Zac,
Thank you very much for your kind coment  ;D
Servus
Bertl
Offline Umlaufmotor
« Reply #198 on: February 01, 2026, 11:58:19 PM »
Every time I drop in for a look at this thread I'm completely inspired by your subtle approach to detailing
I've long since ran out of superlatives so please take it that if I can think of any others I'll add them and in the meantime keep posting the progress pics and technique explanations. I've never built a large scale model, but am really enjoying your description and build  8)
Hello Paul,
Thank you very much for your kind comment  ;D
Servus
Bertl
Offline Umlaufmotor
« Reply #199 on: February 02, 2026, 12:00:36 AM »
Very nice effect on the cockpit coaming. Another method to try..... :)
Hello Nigel,
Thank you for your kind comment - and yes, it is a fairly simple method.  ;)
Servus
Bertl
Offline Umlaufmotor
« Reply #200 on: February 02, 2026, 12:07:04 AM »
Some more detailing work - this time on the antenna boom and the antenna wire ... or the "Luftdraht".
Only the small funnel remained from the kit part.
The wire is a thin 0.06 mm copper wire, and the lead weight is a small lead ball that has been filed down to size.
I drilled a small 0.15 mm hole in this lead ball and glued the wire into it.
The lead weight was then dipped in Mr. Metalcolor "Dark Iron".
Servus
Bertl
« Last Edit: February 02, 2026, 01:56:02 AM by Umlaufmotor »
Offline Umlaufmotor
« Reply #201 on: February 02, 2026, 12:13:15 AM »
Continue with the bomb rack.
Instead of four bombs, the Roland should only have a single bomb attached.
The other three bomb racks remain empty - this allows the unused straps to be shown dangling loosely.
The attached bomb actually hangs only by its strap.
Servus
Bertl
Offline Umlaufmotor
« Reply #202 on: February 02, 2026, 12:19:00 AM »
The Orcarina exhaust, characteristic of the Roland C.II, is now also flanged to the engine.
Servus
Bertl
Offline Umlaufmotor
« Reply #203 on: February 02, 2026, 12:25:10 AM »
I will use the beautiful 3D-printed armament from Gaspatch for this model.
Of course, the forward-facing machine gun is missing the special mounts needed to attach it to the fuselage.
This meant a somewhat more delicate operation, as the two steel brackets from the kit machine gun had to be sawed off and modified to accommodate the 3D machine gun.
With a lot of patience, good tools, a strong magnifying glass, and some good heavy metal music in my headphones, it worked wonderfully.
Oh, and headbanging to heavy metal music is counterproductive at this point....  8)
Servus
Bertl
Offline Umlaufmotor
« Reply #204 on: February 02, 2026, 12:28:42 AM »
In these pictures, the Gaspatch 0815 MG is mounted for testing purposes - nothing has been glued yet.
It looks quite usable so far, I think.
Servus
Bertl
Offline Umlaufmotor
« Reply #205 on: February 02, 2026, 12:35:59 AM »
The Gun was painted 50/50 with Tamiya semi-gloss black and matte black, with a small drop of Natobraun added.
Graphite from a soft 8B pencil was used to dry paint the MG in various places to give it a slight metallic sheen.
The muzzle of the MG was drilled out with a 0.2 mm drill bit.
Hitting the muzzle - center was the most difficult part of this task.  8)
Servus
Bertl
Offline Richtrad
« Reply #206 on: February 02, 2026, 09:26:23 AM »
It is always such a joy to study your wonderful builds Bertl. And your research as well!
Warren Q
« Reply #207 on: February 02, 2026, 07:46:41 PM »
Lovely detailing work Bertl. That GasPatch gun and mounts looks superb, well worth the effort getting it fitted.
That made me laugh! I hope you have some Sabaton in your collection, they are quite appropriate for historical modellers......
Offline Umlaufmotor
« Reply #208 on: February 03, 2026, 04:04:39 AM »
Warren Q
Thank you very much, Warren  ;)
Servus
Bertl
Offline Umlaufmotor
« Reply #209 on: February 03, 2026, 04:10:45 AM »
Thank you very much, Nigel.
Sabaton, yes, of course.
I saw them live two or three times in Munich.
Each time was a great show.
But I have to say, my true heavy metal heart beats for Ozzy/Dio Black Sabbath, Led Zeppelin, Rainbow, Deep Purple, and Iron Maiden.
Unfortunately, I never got to see Black Sabbath and Led Zeppelin live, but I did see the others - all in Munich.
Servus
Bertl
