Author Topic: Wingnut Wings WNW Roland C.IIa "White 2", Schusta 6  (Read 42318 times)
Offline DaddyO
Re: Wingnut Wings WNW Roland C.IIa "White 2", Schusta 6
« Reply #180 on: January 01, 2026, 07:06:33 PM »
Just WOW!  :o
Some beautiful detail work going on and even the paintwork has some lovely subtle touches to admire.
Offline Umlaufmotor
« Reply #181 on: January 05, 2026, 11:54:41 PM »
@Rick, Nigel, Tim and Paul.
Thank you very much for your kind comments!!
Servus
Bertl
Offline Umlaufmotor
« Reply #182 on: January 05, 2026, 11:58:38 PM »
The koi is obvious...
All markings are now on the fuselage - no decals were used, everything was "only" painted.
One or two drops of light gray were added to the matte black of the two fuselage bands, the iron crosses, and the background for the "white two".
It's funny when you unmask the fuselage after such a long time (over a year) and then see the cockpit again --  it's almost like meeting an old friend after years; somehow you recognize it immediately, even though you couldn't remember exactly what it looked like.
Servus
Bertl
Offline Umlaufmotor
« Reply #183 on: January 06, 2026, 12:04:18 AM »
The first paint removal was carried out immediately after the paint had dried.
To do this, twist some super-fine steel wool into a small sausage and then roll it back and forth over the fuselage without applying too much pressure.
This also works on attachments, such as the two ear coolers.
A magnet reliably removes any remaining steel wool.
Occasional touch-ups are necessary afterwards, but I have had quite good experience with steel wool for removing paint from old wooden, wire, and canvas planes.
Servus
Bertl
Offline Umlaufmotor
« Reply #184 on: January 06, 2026, 12:15:05 AM »
A few other components have also been completed in the past few days.
These include the windshield, which has been sanded down to less than half its original thickness (unfortunately, this cannot be seen in the picture without a comparison).
The frame was painted dark green with a fine brush, a little "smoke" was sprayed on with an airbrush to seal it, and then small, fine oil traces from the Mercedes engine were depicted with oil paint.
The wooden tail skid -- this was primed with Radome, then oil paint was applied to show the wood grain, and finally light blue paint was applied over it.
Before the light blue could dry, some of it was washed off again with a bristly brush and warm water.
The sanding marks on the underside of the tail skid shoe were painted on with "Dark Iron".
The claw brake lever -- some aircraft had wooden claw brake levers, while others had metal ones.
I don't know which material was ultimately used on the Roland, but I seem to remember reading in Otto Fuchs' book (a well-known German fighter pilot in World War I) "Wir Flieger" (We Pilots), published in 1933 by Hase & Koehler Verlag Leipzig, that he was just able to bring his Walfisch to a halt before the airfield boundary with the help of the metal brake bar.
In short, the bar on my model is made of metal.
It is painted with "Dark Iron", sprayed with a little rust red, the bracket is painted dark green, and the actual brake plow "the metal blade that digs into the ground" is polished accordingly.
Servus
Bertl
Offline Umlaufmotor
« Reply #185 on: January 06, 2026, 12:22:12 AM »
The masking, or rather the preparatory work such as cutting the painting templates for the Iron Crosses, etc., went quite smoothly.
The "white two" for the fin was a little more complicated - to make it look at least similar to the original in terms of shape, dimensions, placement, and typeface.
It's not perfect, but I'm still quite happy with the result.
Servus
Bertl
Offline Umlaufmotor
« Reply #186 on: January 06, 2026, 12:27:38 AM »
Elevators, elevator fins, and the wide "I" struts, which in the original are made of a wooden frame covered with thin plywood, are also finished.
The painted surfaces have also been treated with steel wool.
The original shows that fabric patches etc., etc., will also need to be added to the tail section of the model at a later stage.
Servus
Bertl
« Reply #187 on: January 06, 2026, 12:48:53 AM »
Hi Bertl,
I am an absolute fan of your work. Your attention to detail is second to none!
Offline Allan31
« Reply #188 on: January 06, 2026, 07:30:53 AM »
Great stuff Bertl, fun to follow along.
« Reply #189 on: January 06, 2026, 06:57:28 PM »
More superb work Bertl, the paintwork looks fantastic, the markings are great and I love the little detail weathering touches evertwhere.
Offline Jorgo
« Reply #190 on: January 06, 2026, 11:56:57 PM »
Second that !
Und Frohes neues Jahr !
Joerg
Offline Umlaufmotor
« Reply #191 on: January 07, 2026, 02:22:24 AM »
Thank you so much Willem, Allan, Nigel and Joerg  ;D
So, little by little, progress is being made on the Roland.
Today I painted the leather-covered cockpit trim.
Originally, this was usually a "sausage of fabric" filled with horsehair, which was sewn around the cockpit trim and covered with leather.
I didn't go to that much trouble this time   8) ? for me, a brownish-beige shade served as the base color, and a light and a dark brown weathering color each as "leather."
The base color was applied with a brush, the weathering color dabbed on.
Then, I gently blended the dabbed-on areas from the outside in with a very soft brush.
Now let it dry and seal it with satin varnish no earlier than tomorrow.
Servus
Bertl
Offline DaddyO
« Reply #192 on: January 07, 2026, 02:48:58 AM »
Every time I drop in for a look at this thread I'm completely inspired by your subtle approach to detailing
I've long since ran out of superlatives so please take it that if I can think of any others I'll add them and in the meantime keep posting the progress pics and technique explanations. I've never built a large scale model, but am really enjoying your description and build  8)
« Reply #193 on: January 07, 2026, 09:14:02 AM »
The finish on the cockpit trim is superb! Bravo, Bertl.
« Reply #194 on: January 07, 2026, 07:26:49 PM »
Very nice effect on the cockpit coaming. Another method to try..... :)
