Author Topic: Lohner Tl - L75 (1/32, Lukgraph)  (Read 32996 times)
Re: Lohner Tl - L75 (1/32, Lukgraph)
« Reply #135 on: May 18, 2023, 06:52:04 AM »
The center section test fit looks perfect to My Eyes! Well Done!!
« Reply #136 on: May 18, 2023, 05:09:18 PM »
Senses working overtime...
  :o
« Reply #137 on: May 18, 2023, 10:57:23 PM »
Your progress on the Lohner looks as intimidating as impressive. I never really felt frightened by the complexity of a kit (before building it, I mean), but that’s really tough what you do here. How do you align the struts? Auxiliary structure made of cardboard? By eye?
« Reply #138 on: May 18, 2023, 11:38:13 PM »
Thank you.
Andreas, I am scared of this kit, too. For the time being I used a cardboard jig for lower wings alignment. And I will also use it when attaching the top wing to stabilize the wing cellule.
 The tail assembly was a nightmare and I did it  "by eye", a bit of trial and error which was surprisingly successful in the first attempt.  ???
The lower part of the engine support was very stable with its N struts which joined both the engine bearers and the horizontal truss under them. The upper N struts are now attached too, but here my eyes tell me they are not perfectly symmetric in the front view, they will need to be corrected by rigging.
And I have still to decide if I attach the centre section itself and the outer wing panels later followed immediately by interplane struts. Or assemble the complete top wings set before attaching it.
The first option has a danger of not getting the correct sweep back, the second one can be difficult because of the large weight of the wings assembly. In any case, the interplane struts will be attached after the wings are aligned as this is imho the only way to ensure their proper inclination...
Well, it certainly is the most difficult model in my life...
« Reply #139 on: May 19, 2023, 12:18:02 AM »
This build just keeps on astonishing me! When you mount the top wing could you possibly show us how you go about it? I have a bit of a tough stage coming up on my project and am keen to see how you go about solving this riddle.
« Reply #140 on: May 19, 2023, 06:18:57 AM »
The first steps towards making it a biplane. The top wing assembled with required 10deg sweepback. The hull with lower wing back to the jig. And the first pair of rigging cables in the tower upper storey tightened and the symmetry restored. Also the throttle control linkage scratch built.
« Reply #141 on: May 19, 2023, 07:55:40 AM »
The upper wing looks great! The rigging start also looks Fantastic! You should have a Biplane soon  8)
« Reply #142 on: May 19, 2023, 08:04:42 AM »
Great update, you went for the one piece upper wing installation then. It's good to see how you've set up the jig. It's been a masterclass in thorough preparation from day 1 of this build.
Offline Boch
« Reply #143 on: May 20, 2023, 09:17:44 AM »
A true beauty. Amazing work. It is pure pleasure to admire it.
Lukasz.
« Reply #144 on: May 20, 2023, 11:15:05 PM »
When YOU fear a model I start running. Your patience is definitely paying off.
« Reply #145 on: May 22, 2023, 03:54:22 PM »
It is a great relief. The dryfitting of top wing showed that the interplane struts are OK in length, at least surely not too short. So now to install the last turnbuckles in the struts and to the final assembly.
« Last Edit: May 22, 2023, 04:43:29 PM by PrzemoL »
Offline Boch
« Reply #146 on: May 22, 2023, 04:50:45 PM »
Hello,
It presents itself splendidly. The end of work is near. I'm looking forward to the rigging and final photos. Have you already chosen your next model?
Lukasz
« Reply #147 on: May 22, 2023, 10:02:14 PM »
Thanks, Łukasz.
Next I will go back to the interrupted build of Polish Caudron G.3
https://forum.ww1aircraftmodels.com/index.php?topic=13595.0
And after that - something simpler from my WNW stash...  ;D
Offline Boch
« Reply #148 on: May 22, 2023, 10:57:16 PM »
Ooo Caudron G.3. I have it in my plan as well, but Nieuport gave me such a hard time that I have to put the CSM company on hold for a while. So I will follow the end of building a flying boat and the continuation of new projects.
« Reply #149 on: May 23, 2023, 02:02:19 AM »
That is a Gorgeous Biplane/ Boat Przemo!
