Author Topic: Lohner Tl - L75 (1/32, Lukgraph)  (Read 32989 times)
Re: Lohner Tl - L75 (1/32, Lukgraph)
« Reply #150 on: May 23, 2023, 05:13:53 AM »
It looks epic!
Great job, Przemo.
« Reply #151 on: May 23, 2023, 06:36:26 AM »
Going on...
After mounting the midspan turnbuckles on the struts I gathered my courage and attached the upper wing to the tower. And then inserted the front 4 interplane struts
After couple of minutes for the CA glue to set I started with the rear struts. They turned out to be about 1mm too short. I added the additional pieces of wire and did the left side pair. The right side later when I cool down... There is also a slight distortion in the plan view but this should be an easy correction with the rigging stagger lines.
« Reply #152 on: May 23, 2023, 06:42:08 AM »
Looks great and hopefully it will be as easy of a correction as you envision !
« Reply #153 on: May 24, 2023, 12:41:07 AM »
Awesome! I can't see any problem with the wing alignment in the photos but I am sure your great skills will correct anything you have noticed.
« Reply #154 on: May 24, 2023, 04:33:47 AM »
Thanks Rick and Richie.
There was indeed a distortion in plan view but as I expected a careful tensioning of stagger lines remedied it, so I can declare that now geometry of the wing cellule is sufficiently close to symmetry 😉
You can also see that the front supports of cantilevers are missing. Yesterday I found them to be a tad too long, so I decided to rig the wings first and then I will check again and adjust their length if necessary.
And yes, I am extremely happy to have this long and difficult project nearing the successful end.
« Reply #155 on: May 24, 2023, 04:49:31 AM »
Fantastic. A Happy End after a long and winding road…
« Reply #156 on: May 24, 2023, 04:53:47 AM »
It looks glorious, Przemol Vs Complex model= Przemol wins by knockout! :)
« Reply #157 on: May 24, 2023, 05:33:55 AM »
I think Richie Has said it perfectly! Looking Brilliant! I sort of wish this Aircraft were available in a Less complicated 1/32nd scale Plastic kit as your build is making Me want to do one!
« Reply #158 on: May 24, 2023, 10:09:29 PM »
Brilliant process!
« Reply #159 on: May 25, 2023, 02:54:50 AM »
This project is looking brilliant, Przemol.  Very clean work.
Offline Boch
« Reply #160 on: May 25, 2023, 04:08:25 AM »
Beautiful work Przemek. You have an amazing workshop.
Lukasz
« Reply #161 on: May 25, 2023, 05:53:45 PM »
Going on. The rigging is well advanced. The cantilever struts almost complete, I had to make new longer rear diagonal ones, they are airbrushed and ready for installation. I have also rigged the ailerons, which are also now ready to be attached. Two or three evenings and the beast should be finished (!!!).
« Reply #162 on: May 25, 2023, 08:08:25 PM »
Wow! great work so far, Prez.
« Reply #163 on: May 25, 2023, 11:17:09 PM »
   Impressive beyond words Prze, a beautiful model in all regards!
   A few words from the previous stand out; "complex and brilliant" say it well and particularly, as Borsos states, "epic". Your work brings so much to this Forum and is always a pleasure and privilege to share ...... many Thanks!
« Reply #164 on: May 26, 2023, 07:47:23 AM »
Thank you Dave and Lance.
Lance, your words are the highest recognition I might get, too high. It is my honour to be accepted here among so many great modelers of WW1 aircraft.
Well, a brief report from today, the main rigging finishedand ailerons attached, though not yet fully connected. Unfortunately I will have to make a 2 days pause, though I feel itching in my mind and fingers knowing that the end is just one good evening away...
And no, the box serving as a base during this stage does not hint at my next project, it was just sitting at the stash top when I was looking for the base  ;)
