The WW1 modelers' reference library
Weapons - Propellers - Aircraft Equipment and Miscellaneous WW1 photos
Laminating and Carving Scale Wooden Propellers
Topic: Laminating and Carving Scale Wooden Propellers (Read 3783 times)
Ranger822
Newbie
February 10, 2023, 02:04:41 AM »
Does anyone here make their own wooden props? I am curious if you would share your technique, materials, best references, and etc.
Ranger822
Newbie
Re: Laminating and Carving Scale Wooden Propellers
February 10, 2023, 02:11:02 AM »
Should have looked farther down the forum . . . sorry!
https://forum.ww1aircraftmodels.com/index.php?topic=282.0
Last Edit: February 10, 2023, 02:21:03 AM by Ranger822
KiwiZac
Global Moderator
February 10, 2023, 05:55:40 AM »
Haha it happens to the best of us Tony! I'll lock this for you.
lcarroll
February 10, 2023, 06:23:12 AM »
Tony,
It's been more then ten years since I posted that Tutorial, I can't believe how quickly the time has past. I still carve most of my props but have changed the technique significantly. I now hand carve right from step one using a couple of #11 or 12 blades, use a Dremel tool with a small sanding drum to work the contours around the prop hub and hand sand the rest with paper and sanding sticks. If you check out the photos here on pages 13 to 16 you should be able to follow the sequence.
https://forum.ww1aircraftmodels.com/index.php?topic=9771.210
My "go to" source of veneers recently stopped marketing the stuff but an online search should provide some alternatives. If you have any questions at all don't hesitate to contact me.
