Author Topic: 1:32nd scale Lloyd C.V  (Read 11582 times)
Offline Umlaufmotor
Re: 1:32nd scale Lloyd C.V
« Reply #15 on: September 01, 2022, 10:33:48 PM »
The wood color tone looks first class.
A superbly built with super researched detailing
You are truly the master of resin kits in my eyes Mike.
Servus
Bertl
« Reply #16 on: September 02, 2022, 06:48:04 AM »
I'm intending to add a flare and a grenade ammunition rack.
So I thought I ought to add the flare and grenade pistols to the gunners cockpit.
Both 'spares' from previous 'Wingnut Wings' models.
The stowage containers were made from photo-etch and 1.4 mm diameter tube.
I also added a map,
« Reply #17 on: September 02, 2022, 12:15:10 PM »
Truly amazing work.
« Reply #18 on: September 02, 2022, 05:19:34 PM »
As always, your work is stellar...
Offline s.e.charles
« Reply #19 on: September 02, 2022, 06:49:27 PM »
full disclosure: i build automobile models and steal ideas for my engines & interiors from threads like this!
« Reply #20 on: September 02, 2022, 10:36:32 PM »
Just beautiful! I like all the small scratches.
« Last Edit: September 02, 2022, 11:08:44 PM by FAf »
« Reply #21 on: September 02, 2022, 10:47:49 PM »
Fuselage closed up now, then and the throttle control rod added (0.4 mm Nickel-Silver tube),
« Reply #22 on: September 03, 2022, 03:56:33 AM »
Your well-researched project is looking fabulous, Mike. Nice work on the fuselage interior & engine.
« Reply #23 on: September 20, 2022, 09:03:15 PM »
I've not posted in the last few weeks, as we took a holiday abroad.
The first time in three years due to the Covid restrictions etc.
The four of us arrived home yesterday.
Yes, you guessed it!!
I have Covid, so does my wife and the wife of our friends we went with.
Anyway, once we're back to normal I'll crack on with the Lloyd model.
« Reply #24 on: September 20, 2022, 11:30:23 PM »
Hope you get well soon, Mike.
The work you've done so far looks excellent.
« Reply #25 on: September 20, 2022, 11:54:48 PM »
Best wishes for a speedy recovery to you Mike, and everyone else of the adventure! Take the time you need and we'll look forward to your return to the work bench!
« Reply #26 on: September 21, 2022, 08:45:48 AM »
I'm with them - take care of yourselves!
« Reply #27 on: September 23, 2022, 05:07:00 AM »
Well it has been a while since I checked in but the same awesome quality is in evidence!
« Reply #28 on: September 23, 2022, 11:53:35 PM »
After closing up the fuselage I found a problem with the rear fuselage cabane struts.
The two rear struts on each side were slightly bowed due to the angle they were fitted.
The bottom of two struts had also cracked (3D printed and not reinforced with rods).
Therefore, I cut the struts away and replaced them with shaped Brass tube and internal rod.
This also makes the struts stronger for bearing the weight of the upper wing halves,
« Reply #29 on: September 24, 2022, 04:25:38 AM »
This is looking so nice.  Neat solution for the exhaust pipes.
