Author Topic: A second attempt at a Nieuport  (Read 14874 times)
Re: A second attempt at a Nieuport
« Reply #45 on: July 19, 2022, 08:20:05 AM »
Thanks Zac - So glad it's not just me  8)
The number of times "just enough pressure" to mount the extra wing turns into "wings pancaking onto one another"...!
Online DaddyO
« Reply #46 on: July 19, 2022, 04:55:46 PM »
I have also reached that conclusion! And it goes well with my idea that alla builds start out as flawless and full of opportunity only to be reduced and limited by each step in the build. The largest problem is of course that if you let this realisation get to you, you won't be able to finish a build again. :) So ignore it and press on! :D
/F
Absolutely right. Working commercially I quickly found that getting the job completed was better in the long run for your learning rather than endlessly trying to produce something 'perfect'  ;D
LOL Zac - that's exactly why the original went back onto the shelf of doom (and the appaling amount of dust I was managing to get each time I added a layer of paint!)
Online DaddyO
« Reply #47 on: July 30, 2022, 08:22:32 PM »
Well not as much progress on these this week as I'd like, but sometimes other stuff just gets in the way  ::)
Managed to stick a few bits together and get a bit of weathering done on both so we're now ready to assemble I think. (I also replaced the tail on the silver one because I kept knocking the damn elevator off and it was getting tattier and tattier so eventually I just picked another one out of the box and repainted to match)
I'll lay off the coffee today so hopefully I'll be able to do some assembly without breaking anything  ;D
Online DaddyO
« Reply #48 on: August 10, 2022, 04:12:47 AM »
Well if that don't put the tin hat on it :-[ Managed to get the wing onto the silver one to my satisfaction after three attempts (To be fair it was okay after the second, but then I managed to partially break it off so decided to remove it and do the job properly)
Anyway back to my original rant, if I may . . . .just added some rigging which has worked better than expected by taking it very slowly. Now that it's finished I realised that the reason the monofilament looks 'chunky' is that I picked up the wrong line and the stuff I used is twice the thickness of the intended (.12mm rather than .06mm) >:( Buggered if I'm removing it at this stage though. So I'll press on with the final details over the next couple of days and post some pics at the weekend
Online DaddyO
« Reply #49 on: August 11, 2022, 06:26:21 AM »
Here's a quick update of the rigging going on . . .
Leaving us with a hairy bipe  ;D
Finally here's the first stages of the pilots for these two wee beasties ready to be hacked about
« Reply #50 on: August 11, 2022, 07:19:55 AM »
Great to see a wing mounted and I look forward to more on those fugures!
« Reply #51 on: August 14, 2022, 09:23:47 AM »
Looking wonderful!
WD
Online DaddyO
« Reply #52 on: August 14, 2022, 06:31:28 PM »
Looking wonderful!
WD
Thanks WD  ;D
Cheers RagIII (I'm looking forward to seeing them myself)  ;)
Here's the TaDa moment. I'll post a couple of other pics on the finished thread later
« Reply #53 on: August 14, 2022, 07:47:49 PM »
Beautiful!
« Reply #54 on: August 14, 2022, 09:10:43 PM »
Fascinating to see how small it is compared to your hand (I'm guessing you have normal sized hands :) ), because the first picture really doesn't show it to small at all. Well built!
Online DaddyO
« Reply #55 on: August 14, 2022, 10:13:41 PM »
Beautiful!
Thanks Andonio64  ;D
Cheers Fredrik  ;D
Yep normal sized hands, but it is a bit of a tiddler.
Funny the drawings in the Datafile look okay, but when you have a strut which is only 6 or 7 mm long and it pings off somewhere into the depths of the room you re-assess slightly ;D ::)
« Reply #56 on: August 14, 2022, 11:46:12 PM »
That is a Lovely Little Nieuport! I Look forward to more photos in the Completed thread!
« Reply #57 on: August 21, 2022, 10:18:44 PM »
Nice! Such tiny butterflies!!
« Reply #58 on: August 31, 2022, 01:29:29 AM »
Still waiting for the other one to hatch out.
Any progress?
WD
Online DaddyO
« Reply #59 on: August 31, 2022, 02:10:11 AM »
Thanks guys  :D
Nearly there WD. Been working on the rigging so just the touching up and top mounted Lewis to sort out (My dog died a couple of weeks ago so haven't felt much like doing anything really. Just starting to do a bit more modelling now)
