Author Topic: Halberstadt Cl.II - 3EWlkp (1/32, Wingnut Wings)  (Read 12238 times)
Re: Halberstadt Cl.II - 3EWlkp (1/32, Wingnut Wings)
« Reply #30 on: June 23, 2022, 04:28:05 AM »
Very nice Prze!
WD
« Reply #31 on: June 24, 2022, 07:16:23 AM »
Thank you.
The fuselage closed, together with engine covers. Some tweeking was necessary to enclose the nose but finally it was easier than I expected. The worst places are at the front cockpit coaming where the rear engine panels touch the fuselage halves. Some tricky sanding will be necessary there, not to damage the fine detail.
« Last Edit: January 03, 2023, 09:51:09 PM by PrzemoL »
« Reply #32 on: June 24, 2022, 09:36:45 PM »
Looks like you have succeeded in a perfect fit!!
« Reply #33 on: June 25, 2022, 03:24:09 AM »
Shaping up nicely, Prze. I'm taking notes on your build - thanks for sharing the stories about the tricky parts  :)
« Reply #34 on: June 28, 2022, 03:23:45 AM »
Taking notes as well for the one sitting in the stash .
« Reply #35 on: June 28, 2022, 08:47:03 PM »
Looking great, Prze!  ;)
Thanks for sharing
« Reply #36 on: July 01, 2022, 06:01:09 AM »
It is now a phase of the tedious and little spectacular work. Cleaning of the seams and polishing of the wings and stabilisers surfaces in preparation for Aviattic transparent losenge decals.
And in between some more interesting bits. Like the unusual exhaust which I am building from a spare bit. It was destined for a larger engine so I had to cut off and shorten all six pipes, fill the holes and narrow the chimney. Test fit successful but it also shows a collision with the front cooling pipe (not present in the photos) which will need to be reshaped and rerouted, but that later.
Also, the test fit of the composite stabiliser-elevator element to the fuselage showed that the elevator will be warped. The only remedy I saw was to cut off the elevator and widen a bit the gaps for the hinges to give it some more space to adjust to the shape of the stabiliser. Problem solved.
« Last Edit: January 03, 2023, 09:51:47 PM by PrzemoL »
« Reply #37 on: July 01, 2022, 06:21:19 AM »
Amazing work Prze!
WD
« Reply #38 on: July 02, 2022, 04:27:14 PM »
Nice work on the exhaust  :)
« Reply #39 on: July 04, 2022, 11:10:23 PM »
Beautifully Done on all Przemo!
Offline Jorgo
« Reply #40 on: July 12, 2022, 03:55:26 PM »
This will be another masterpiece ! I like your clean and accurate modeling
Jörg
« Reply #41 on: August 07, 2022, 02:18:39 AM »
Finally back to this project. All the parts are cleaned, this included polishing down the surfaces of wings in preparation for transparent losenge decals.
Colouring started. White background will be also shaded with greyish along the ribs. First wood panels done.
And a small detailing amendment - Polish 201/18 had one more inspection at the engine left side, so I scratched the missing cover from a plastic slice and a couple of metal fittings.
« Last Edit: January 03, 2023, 09:52:22 PM by PrzemoL »
« Reply #42 on: August 07, 2022, 12:45:40 PM »
Looking good Prze , very nice wooden effect on the cowl panels .
« Reply #43 on: August 15, 2022, 07:04:40 AM »
Thank you, Alexis.
More progress... Fuselage wood painted and Aviattic losenge applied.
« Last Edit: January 03, 2023, 09:52:38 PM by PrzemoL »
Offline rhwinter
« Reply #44 on: August 15, 2022, 04:08:13 PM »
Looking SO beautiful!!
