Author Topic: Lloyd C.V Polish service (1/32, Lukgraph)  (Read 48565 times)
Re: Lloyd C.V Polish service (1/32, Lukgraph)
« Reply #60 on: May 07, 2022, 07:12:59 AM »
Having missed a few updates all I can Say is WOW! Beautiful tones!!
« Reply #61 on: May 07, 2022, 11:36:37 PM »
Quite amazing progress, Przemo! A lovely thread to follow! Regards, Marc.
Offline hadzi
« Reply #62 on: May 08, 2022, 09:47:41 PM »
Very good work Przemek! Will you be with this kit in Bytom?
« Reply #63 on: May 09, 2022, 12:28:30 AM »
Thank you.
I may just be on time. Now it depends mostly on how good the fit of struts will be. If I have to correct their length, I will not finish this model before Bytom.
And for the time being - the wash done and varnished. The bits are basically ready for the final assembly.
Offline Umlaufmotor
« Reply #64 on: May 09, 2022, 05:15:09 AM »
@PrzemoL
This looks really good.
Beautiful interplay of colors and materials.
Superbly done...
Servus
Bertl
« Reply #65 on: May 09, 2022, 08:33:17 AM »
Thank you, Bertl.
A few more bits added...
« Reply #66 on: May 10, 2022, 04:32:10 AM »
U/c minus the plough brake complete! The rubber cord suspension from a thread soaked with diluted paper glue added. I need to put the model on its feet to attach the brake at the correct inclination - this soon.
The plan for tonight is also to attempt the assembly of the wing cellule... We will see...
« Reply #67 on: May 10, 2022, 07:35:43 AM »
The brake installed. And 4 main interplane struts are being attached using a funny ad-hoc installation of several bottles I had at hand and a heavy spool of soldering wire as a weight to keep the geometry of the upper wings which for now serve only to keep the struts geometry.
« Reply #68 on: May 11, 2022, 08:24:42 AM »
And now it finally is a biplane!
« Reply #69 on: May 11, 2022, 12:20:50 PM »
Wow Przemo, this is a beautiful and extraordinary  bird.
I see you are ready to get her rigged.
Can't wait to see her in full glory!
« Reply #70 on: May 12, 2022, 05:32:27 AM »
What a nice wooden biplane!
Thanks for answering my question regarding the primer, I have overlooked the picture before.
I asked because there used to be a special resin primer from Gunze, but I haven't found it anywhere. If it works as well on resin as the Metal Primer from this company does on metal parts, then I would have liked to test it.
Masking on resin can be risky if the primer does not adhere well enough.
« Reply #71 on: May 12, 2022, 07:50:51 AM »
Thank you, Willem and Frank.
Frank, it seems that this primer holds to resin perfectly. I had no problems with masking, no paint peeling, so I can highly recommend it.
And tonight I finished my Lloyd. A  few photos here, the proper gallery will come soon.
« Reply #72 on: May 12, 2022, 08:56:26 AM »
Congratulations Prze, another stunning build!
« Reply #73 on: May 12, 2022, 08:17:54 PM »
Congratulations on completing this work of art! Such nice colours, depth of colour, details, etc. Very inspiring!
« Reply #74 on: May 13, 2022, 02:55:17 AM »
Wonderful as always, Przemo. A true work of art.
