Author Topic: Lloyd C.V Polish service (1/32, Lukgraph)  (Read 48526 times)
Re: Lloyd C.V Polish service (1/32, Lukgraph)
« Reply #45 on: April 09, 2022, 01:36:06 AM »
Excellent work on the jig. The construction is looking fantastic and like Ken has stated all of the surface prep is paying off!
« Reply #46 on: April 09, 2022, 06:36:41 AM »
Wow, no remaining printing layers visible, super! Fine work.
« Reply #47 on: April 10, 2022, 05:37:05 AM »
I have prepared a cardboard jig
That is a fantastic way of creating a jig! Great idea Prze!
« Reply #48 on: April 13, 2022, 01:08:50 AM »
I daresay that finally after repeated sessions with CA glue, sanding paper of several grades and primer, the wings and tail seams are ready.
« Reply #49 on: April 20, 2022, 03:48:14 AM »
A few more items done. 16 turnbuckles for main rigging fitted with eyelets. Rigging eyelets in wings, centrepiece struts and undercarriage struts mounted. Horns at u/c struts for rubber cord suspension added. 4 control horns for ailerons made from plastic as replacement for inadequately flat PE kit pieces.
« Reply #50 on: April 20, 2022, 03:55:10 AM »
Exquisite work, Prze!
« Reply #51 on: April 21, 2022, 07:07:09 AM »
Very Impressive as always!
« Reply #52 on: April 27, 2022, 07:00:10 AM »
Finally some colours! The linen surfaces painted and shaded, with some hints of the inner structure visible from underneath. Then masked and a base for veneer colour is being applied.
« Reply #53 on: April 27, 2022, 07:30:30 AM »
Breathtaking paint work, Prze!
Offline Rafael Berlin
  • e^(i*pi)+1 = 0
« Reply #54 on: May 05, 2022, 04:43:49 AM »
The linen surface with the pre shading is not from this world. Simply perfect. Beautiful.  :)
« Reply #55 on: May 05, 2022, 06:31:11 AM »
Thank you, Zac and Raphael.
The wood is painted. It is quite dark but then, who knows how it really was  ;)
« Reply #56 on: May 06, 2022, 01:58:45 AM »
Great progress, the "wood" looks nice.
What brand of white primer you use on resin? Does it "bites" into the resin?
« Reply #57 on: May 06, 2022, 03:06:32 AM »
Thanks, Frank.
I have shown the primer bottle at the beginning of my thread. It is Mig One Shot Primer. I did not notice any interaction with the resin. And if you possibly refer to that zone on the upper wings where I had a technical break in wood application, it is mostly the play of clear brown shades/intensity and the semi gloss/gloss surface. It will all be varnished and unified, after decaling and wash.  ;)
« Reply #58 on: May 06, 2022, 11:42:58 PM »
Airbrushing complete. Decalling under way.
« Reply #59 on: May 07, 2022, 05:04:49 AM »
Lovely rich tone to the wood, Prze. I like it!
