Author Topic: Jeannin Stahltaube 271/14 (1/32, Wingnut Wings)  (Read 23447 times)
Re: Jeannin Stahltaube 271/14 (1/32, Wingnut Wings)
« Reply #30 on: November 26, 2021, 08:55:54 AM »
With each update I'm speechless at the effort and detail you're putting in, and then we get to the engine. Oh, wow! That is utterly gorgeous work!
« Reply #31 on: November 26, 2021, 03:03:17 PM »
Beautiful work in riggings and the engine.
« Reply #32 on: November 27, 2021, 12:02:45 AM »
Plugs and wiring, and the overall engine look Fantastic. Bracing wire rigging is outstanding.
« Reply #33 on: December 04, 2021, 02:19:46 AM »
The engine weathered and fitted with those linkages I wanted to add. Now the fuselage can be closed and the lower water pipes can be attached. The carb side will be open, the other one - closed.
Offline Grant
« Reply #34 on: December 04, 2021, 02:50:32 AM »
Stunning work!
« Reply #35 on: December 04, 2021, 03:06:04 AM »
And the assembly begun...
« Reply #36 on: December 04, 2021, 06:33:36 AM »
Oooooh, that's pretty! I volunteer to swing the prop for the test runs and flights!!
« Reply #37 on: December 04, 2021, 07:39:09 AM »
Amazing progress on the dove  :) What else should we expect from you?
« Reply #38 on: December 04, 2021, 08:24:32 AM »
Simply Stunning work as always!
« Reply #39 on: December 04, 2021, 04:59:48 PM »
Gorgeous engine bay!
« Reply #40 on: December 14, 2021, 08:45:34 AM »
Thank you...
And Taube finally looks like Taube. Fuselage seams are treated, wings and tail attached, the control cables attach points fitted with eyelets, spoke wheels made from Alb B.II PE pieces (luckily found in my spare box) because I damaged the thin spokes in the Taube PE pieces. The former ones are a bit thicker and thus easier to work on. The u/c is just dry fitted to the fuselage for the picture.
« Reply #41 on: December 14, 2021, 08:47:54 AM »
Absolutely Gorgeous and your usual precise detail and construction!
« Reply #42 on: December 14, 2021, 09:13:02 AM »
Very impressive, Prze. The model is looking very much the part now. Your interior work is, as always, top notch.
Gayr
Offline Grant
« Reply #43 on: December 14, 2021, 10:28:50 AM »
Absolutely stunning work Prze!
How long have been working on this one?
Just incredible detail work.
« Reply #44 on: December 14, 2021, 06:36:17 PM »
Thank you, gentlemen.
Thanks. This one is on the bench since the first days of November, 6 weeks up till now. And I may just be able to have it completed at the end of this year  8)
