Author Topic: Encore/Roden SE5a McCudden 56 sq.. Phoenix thrice Risen  (Read 89421 times)
Re: Encore/Roden SE5a McCudden 56 sq.. Phoenix thrice Risen
« Reply #210 on: March 20, 2022, 06:30:38 AM »
Very promising start on the Se!
« Reply #211 on: March 20, 2022, 06:43:49 AM »
Thanks and don't quit looking. I would love to see you tackle the Roden SE5a in 1/48th ;D
PS: This is my old build of the Roden 1/48th scale SE5A Zac.
You're not helping!!  ;D
« Reply #212 on: March 20, 2022, 06:58:36 AM »
 ;D
« Last Edit: March 25, 2022, 03:52:35 AM by RAGIII »
« Reply #213 on: March 29, 2022, 10:58:49 AM »
After esting a day or two following MY Vacation I have gotten back to work on the two SE5as'. I have drilled all of the rigging holes in the Viper version and made sure that all were still opened on the McCudden bird. I also installed the engine and cowling on Grinnell-Milnes viper.
I added some wrinkles using sprue goo:
« Reply #214 on: March 29, 2022, 06:46:12 PM »
That's great progress, Rick -
Like the added wrinkles to the fuselage.  I'm keeping my fingers crossed for you on this SE5a build.
« Reply #215 on: March 30, 2022, 03:54:19 AM »
Thanks Dave! Here is a little heads up on the tail rigging. The "Standard" rigging is seen on the WNW instruction sheet below:
In 56 squadron it was discovered that in prolonged dives there was a tendency for the fin / tail to twist. The remedy was a 3rd bracing wire. Encore/ Roden got this correct so if anyone is doing a 56 squadron SE5a add this wire:
« Reply #216 on: March 30, 2022, 11:46:01 AM »
Progessing is coming along nicely Rick
« Reply #217 on: March 30, 2022, 05:09:12 PM »
Fine progress.
And that is an interesting rigging detail, I was not aware of. Thanks for sharing this, Rick.
Online macsporran
« Reply #218 on: March 30, 2022, 05:37:35 PM »
Great progress, Rick. Likewise, the additional rigging cable is a detail that has escaped me for over half a decade! Muchas gracias.
P.S. it seems RAGIII Sqdn planes also have a tendency to dive OOC - maybe a few extra rigging lines would be a useful precaution on all future builds?
« Reply #219 on: March 30, 2022, 06:31:03 PM »
Great progress on both aircraft Rick!
Again, if you keep up this speed of building, you will soon need a new display cabinet  ;)
« Reply #220 on: March 30, 2022, 09:13:56 PM »
Excellent work, Rick!
Keep going  ;)
« Reply #221 on: March 31, 2022, 12:25:33 AM »
Thanks Alexis!
Fine progress.
Thanks Przemo! As for the tail rigging it is explained in "High In The Empty Blue" using period sketches. Since we are talking about WW1 aircraft I probably should have said if doing a 56 squadron SE5a it "Most Likely" had the  3rd wire  ;D
Thanks Sandy. As for the tail rigging note My comment to Przemo above. Lets hope that extra wire works as you suggest for My "Nosedives"  ::)
Thanks Willem. You are correct about a "New Display Case". I can fit one of the two SE5a models in My 2nd case, the other will need a new home  ;D
Keep going  ;)
Thanks Bob!
« Reply #222 on: April 02, 2022, 05:44:03 AM »
Rick,
    Add me to the list of those who had missed the extra wire on the tail until you pointed it out. By coincidence I was just starting the rigging on my Rhys Davids 56 Sqn. WNW SE.5a when you posted this, absolutely perfect timing! Thanks for sharing this info with us.
« Reply #223 on: April 02, 2022, 06:08:07 AM »
Rick,
I am Happy the info was helpful Lance. Roden actually provides a small indicator for all three lines on the fin of their SE kit.
PS: I think I forgot to do the wire on My Rhys Davids build using the WNW kit  :-\
« Last Edit: April 02, 2022, 06:17:03 AM by RAGIII »
« Reply #224 on: April 02, 2022, 12:03:15 PM »
I did some more work today. I positioned the ailerons in a more realistic position, filled the circular opening on the fuselage underside and replaced with plastic card to represent the cover as seen on the original. I also cut out the spent shell opening. Finally I primed all of the fuselage and wing surfaces. The results showed I still have a bit more filling and sanding to do in a few places.
