Author Topic: Encore/Roden SE5a McCudden 56 sq.. Phoenix thrice Risen  (Read 89362 times)
Re: Encore/Roden SE5a McCudden 56 sq.. Phoenix thrice Risen
« Reply #180 on: March 10, 2022, 10:29:38 AM »
I spent a few hours of bench time today finishing the framework and beginning the interior painting process. I added some wrinkles to the interior using thick acryic craft paint. The interior surfaces were then sprayed with a mix of a Tamiya beige and white. Afterwards oils were used in the usual manner to create a wood effect. Next up once the oils dry will be washes and dry brushing to pull it all together.
« Reply #181 on: March 11, 2022, 03:59:23 AM »
Looking promising Rick! I have a 48th SE on my list so I'll be watching closely for inspiration.
« Reply #182 on: March 11, 2022, 05:15:18 AM »
Nice start with the wood work Rick and I like the fabric effect on the inside .
« Reply #183 on: March 11, 2022, 05:21:34 AM »
Thanks Zac. If you are going to build the 1/48th Roden kit If I recall correctly it pretty much assembles identically to this 1/32nd version. Although I don't think it had the engine?
Thanks Alexis. If all goes well today I will apply the washes, do some drybrushing, add some Tamiya clear orange to the frames, and finally add the bracing wires  8)
« Last Edit: March 11, 2022, 05:40:34 AM by RAGIII »
« Reply #184 on: March 11, 2022, 08:59:21 AM »
I have applied the washes to dirty up the cockpit. Also used Tamiya clear orange...sparingly. Finally the bracing wires have been added using stretched sprue. This is one of those cockpits that when all is said and done, not much shows.
« Last Edit: March 11, 2022, 09:57:02 AM by RAGIII »
« Reply #185 on: March 11, 2022, 09:46:15 AM »
Looking great Rick.
WD
« Reply #186 on: March 12, 2022, 03:02:31 AM »
Looking great Rick.
WD
Thanks Warren!
RAIII
« Reply #187 on: March 12, 2022, 03:27:23 AM »
Awesome Rick , looks fantastic all dirty up !
« Reply #188 on: March 12, 2022, 06:21:47 AM »
That looks excellent Rick, great work!
That's handy to know, thank you. I'm happy without an engine.
« Reply #189 on: March 13, 2022, 12:35:34 AM »
Thanks Alexis. I do like MY aircraft to have a well used look   8)
Thanks Zac! I worked a bit on the seat and cut out the inspection panels on the tail surfaces yesterday. Today I hope to start adding a few details to the interior and work on the IP.
« Reply #190 on: March 13, 2022, 10:49:34 PM »
Nice progress on this one Rick! I know I'm going to enjoy and learn a lot.. Regards, Marc.
« Reply #191 on: March 13, 2022, 11:08:45 PM »
Nice! Funagain begunagain!!
« Reply #192 on: March 14, 2022, 12:01:13 AM »
Thanks Marc . I am not going to do much that is out of the ordinary but as always I appreciate the feedback!
Yep  ;D  I did a bit more work Yesterday. I used British instruments from an Eduard WW1 PE set to enhance the IP. I am sure they are not in their proper place compared to the real bird but they do look better than No Instruments at all  8)
« Reply #193 on: March 14, 2022, 12:31:01 AM »
That's all looking very good, Rick.  The IP is great!
« Reply #194 on: March 14, 2022, 12:40:44 AM »
Thanks Ken! One more a little closer:
