Author Topic: Friedrichshafen FF33L - Polish White 9 (1/32, Lukgraph)  (Read 34645 times)
Re: Friedrichshafen FF33L - Polish White 9 (1/32, Lukgraph)
« Reply #75 on: June 19, 2021, 06:25:35 AM »
Thanks Prze ,
Over all not a heavy kit ...nice !
Offline DeLano80
« Reply #76 on: June 19, 2021, 06:48:31 AM »
I think this kit looks fantastic and you are doing a great job thus far.
Nice jigs by the way.
« Reply #77 on: June 19, 2021, 11:36:16 PM »
Thank you.
The floats are now armed with fittings and rigging eyelets, so the assembly has started.
« Reply #78 on: June 19, 2021, 11:41:55 PM »
Awesome work as always!
« Reply #80 on: June 21, 2021, 01:35:06 AM »
Thank you, Mike, I have already seen these footage.
« Reply #81 on: June 21, 2021, 02:11:52 AM »
Subassemblies being readied for airbrush.
« Reply #82 on: June 21, 2021, 02:24:21 AM »
Favorite part ...painting !
« Reply #83 on: June 21, 2021, 03:37:08 AM »
With all of your years of experience you are again build a resin kit in a absolute masterful way!
This is pure joy to watch this show.
« Reply #84 on: June 21, 2021, 04:16:48 AM »
+1 on that!
Great work to follow as well!
« Reply #85 on: June 21, 2021, 07:11:44 AM »
Thanks.
And to conclude today work, the upper wings connected using the same jig. And the interplane struts after extensive repair work with CA glue and plastic inserts. Some air bubbles are still there, but below the surface 🙂
Offline mammut08
« Reply #86 on: June 21, 2021, 07:27:29 AM »
Hi,
I about to start on this kit myself, so I have been following along. I see that you moved the locating holes for the N-struts on the floats. Does this change the vertical distance between the floats and the fuselage or are all the struts the proper length, with just the mounting holes in the wrong places?
Best,
« Reply #87 on: June 21, 2021, 07:50:05 AM »
Hi,
Best,
The kit struts fit perfectly the locating holes in the kit (3D design). When the holes are moved the entire assembly changes. I have made my templates based on the dimensions from SVK acceptance sheets printed in Herris book. With these ready it turned out that the front and rear legs of the Ns are quite fine but the diagonal intermediate strut had to be much longer.
Offline christw
« Reply #88 on: June 22, 2021, 05:05:11 PM »
It's a fascinating montage full of lessons. You make me want really to get this kit and give it a shot, despite the difficulties.
Many thanks.
« Reply #89 on: June 22, 2021, 10:00:08 PM »
 I am following ao many projects I lost track of this for a week or so and checked in to see amazing progress with lots of clever modelling solutions. Have made note of the use of jigs! :)
