Author Topic: Friedrichshafen FF33L - Polish White 9 (1/32, Lukgraph)  (Read 34489 times)
Re: Friedrichshafen FF33L - Polish White 9 (1/32, Lukgraph)
« Reply #45 on: May 28, 2021, 10:01:18 PM »
Beautiful detail and just enough for what is seen. Looks Fantastic in place!
« Reply #46 on: May 28, 2021, 11:07:43 PM »
Really like how the rockers are in different positions , nice touch  :)
« Reply #47 on: May 28, 2021, 11:10:13 PM »
Oh, that is in the kit engine, I did not change it, just had to cut the push rods of different lengths :-)
« Reply #48 on: May 29, 2021, 03:36:54 AM »
The interior work is nicely done and it all seems to fit nicely between the fuselage halves.  Engine seems to fit in their nicely as well.  Some seam clean up and you can move on to the next phase of the build.  I haven't received mine yet, but am looking forward to it.  I am looking forward to seeing your next update and your comments and take on the kit.
Offline Fvdm
« Reply #49 on: May 29, 2021, 03:01:31 PM »
That's a real nice Benz. Luckgraph did a nice job on the rockers, placing them in different positions.
Offline Kamil Zoszak
« Reply #50 on: May 29, 2021, 05:56:52 PM »
Great kit with great work. I'm still trying to follow your skills in modeling
« Reply #51 on: May 29, 2021, 08:59:03 PM »
Thank you once more.
And here are the last glimpses before closing. Benz got some dirt, one former under it had to be trimmed to avoid collision with pipes at the engine bottom, elevator control lines are added, mainly for the sake of the rear cockpit, in the front one they are not to be seen, so some fiction is allowed...
« Reply #52 on: May 29, 2021, 10:13:03 PM »
The Benz looks fabulous Przemo!  1:1.  Interior very realistic and appealing.  Great work. ;D
Best regards,
« Reply #53 on: May 30, 2021, 12:18:31 PM »
 :)  Looking good Prze !
« Reply #54 on: May 30, 2021, 06:27:46 PM »
What kind of paint and color You use to paint engine carter?
« Reply #55 on: May 30, 2021, 11:06:55 PM »
Superb work!
« Reply #56 on: June 08, 2021, 07:03:20 AM »
Thank you, everyone.
I use Vallejo Metal Color acrylics, here it is Aluminium and Dark Aluminium.
And I was not idle in those days. Lots of preparations underway.
The fuselage was closed, seams filled, sanded and polished, a couple of air bubbles in the rear bottom end filled with plastic inserts, too. Now it is ready to accept the lower wings and stabilizers.
The wings were all over polished, their resin surface bears some traces of 3D printing, all those were duly removed. When cleaning the leading edges from traces of casting blocks a couple of air bubbles were unearthed - filled and sanded.
I am also doing plans for the assembly. The wings with dihedral will require a simple template. But the floats with 10 struts and two crossbars between them require a special plan. For the moment I decided to build the internal Ns from the single struts, what will hopefully allow for a stable connection of the float assembly to the fuselage, then the outer 4 single struts will be added. I am still not sure if I will do it before completing the wing cellule or afterwards.
Anyway, the template for those Ns is traced based on the dimensions given in Herris monograph.
« Reply #57 on: June 08, 2021, 09:13:05 AM »
The fuselage looks great as does your prep work!
« Reply #58 on: June 08, 2021, 09:34:10 PM »
I'm sure your prep work will pay dividends when it's time to paint.  Great looking work here.
« Reply #59 on: June 08, 2021, 09:52:08 PM »
Nice prep work Prze  :)
