Author Topic: Nieuport 17bis  (Read 12003 times)
Offline RLWP
  • Bodger
Re: Nieuport 17bis
« Reply #30 on: May 17, 2021, 03:45:57 AM »
Lovely work, so far Richard! I have no good advice for the side panels, maybe just try a plastic sheet, score as required to represent stringers, and see if it fits! You could get really lucky.... Regards, Marc.
I’ll make formers and indeed use scored styrene sheet. The issue is - until I have the engine I don’t know what diameter the aeroplane will be at the front.
The kit is overscale which I’m not particularly surprised at. I have found from my scratchbuilds that fitting  kit engines into scale models often leads to them interfering with the cowl. So I just need to wait for the postman.
Offline RLWP
  • Bodger
Re: Nieuport 17bis
« Reply #31 on: May 24, 2021, 06:42:40 PM »
The engine has arrived:
This is the rather nice Lukgraph Clerget, a 3D printed engine with lovely detail. And it builds up to a pretty near scale size too:
This means I can now make a cowling and bring the firewall down to the correct size, meaning I can then get on with the fuselage sides
While I was waiting, I built a card rocket:
Re: Nieuport 17bis
« Reply #32 on: May 24, 2021, 07:24:40 PM »
That 3d printed engine looks great, glad you can move on with the build now. The card rocket looks like a lot of fun too!
Offline RLWP
  • Bodger
Re: Nieuport 17bis
« Reply #33 on: May 24, 2021, 08:19:22 PM »
It was, I downloaded it from here: https://currell.net/models/v2.htm
Re: Nieuport 17bis
« Reply #34 on: May 24, 2021, 09:14:55 PM »
What a brilliant website! They even that the R101 airship. My Grandad helped build it, looks like I shall have a fun project to distract me soon!
Re: Nieuport 17bis
« Reply #35 on: May 25, 2021, 01:59:13 AM »
That engine is going to be awesome! A lot better than the Hobby Craft Clerget I was planning to use  8)
Re: Nieuport 17bis
« Reply #36 on: May 25, 2021, 03:31:35 AM »
That engine looks great, Richard! Rocket on! Regards, Marc.
Re: Nieuport 17bis
« Reply #37 on: May 25, 2021, 10:07:36 AM »
Always nice when a build can move forward , that engine looks really nice ! Also really like the rocket ...that is really cool !
Offline RLWP
  • Bodger
Re: Nieuport 17bis
« Reply #38 on: May 25, 2021, 05:30:27 PM »
Just for even more fun, the V2 with a 1916 R.A.F Aerial Target:
Different generations of unmanned aerial vehicles.
What Josef Jacobs and his dog make of it all, I don't know
Re: Nieuport 17bis
« Reply #39 on: May 25, 2021, 09:38:34 PM »
The engine will make a fine addition to your build.
Are the V2, aerial target, and Jacobs figures all in the same scale?
Offline RLWP
  • Bodger
Re: Nieuport 17bis
« Reply #40 on: May 25, 2021, 11:21:09 PM »
Yes, all 1/32 scale
Re: Nieuport 17bis
« Reply #41 on: May 25, 2021, 11:31:46 PM »
I suspect Josef's dog is wondering where his ball went and why he hasn't had a snack for a while. :D
Offline RLWP
  • Bodger
Re: Nieuport 17bis
« Reply #42 on: May 26, 2021, 02:21:38 AM »
Re: Nieuport 17bis
« Reply #43 on: May 26, 2021, 08:08:52 PM »
At least he has a stick to fetch there! ::)
Offline RLWP
  • Bodger
Re: Nieuport 17bis
« Reply #44 on: June 01, 2021, 05:57:57 PM »
Anyway...
I'm not sure why it is that these pretty interchangeable rotary engines (Gnome, Clerget, LeRhone, Oberursel) all ended living in quite different cowls. I haven't managed to reuse a mould yet! I turned up one for the short Clerget cowl of the 17bis and vac formed one:
I wanted to avoid a difficult join between the cowl and the upped deck, so I stuck them together. This means the Clerget has to be finished and installed before I could finish the fuselage:
The Lukgraph Clerget is a beautiful thing, highly recommended. It's a same this cowling hides so much of it
And, having scratched my head about 'are both sides the same?' (yes - otherwise the oval openings don't work), 'where is the centreline of the curvature of the fuselage?' (I stuck with running parallel to the upper longeron) and 'where did the support go?' (I guessed) - I have made the sides:
Now I can paint those, make and install the empty belt reel, repair all the handling damage and close her up
