Author Topic: 1/32 Chinese Polikarpov R-1  (Read 7372 times)
Offline The_Magnificent_Squadron
Re: 1/32 Chinese Polikarpov R-1
« Reply #15 on: April 13, 2021, 04:14:42 PM »
I agree that the interior is just amazing. Mind you the remainder of the build is not too bad either...! This one will be a stunner and in Chinese markings too - we do not see many of them.
Thank you
« Reply #16 on: April 13, 2021, 04:20:00 PM »
Very fine work all around. The interior, the outer colours... I am one big fan of Ninaks. But seeing it in the Soviet R1 version brings me to ask, do we know if they differed somehow from the original? Or is it just the educated guess from WNW that they were exact copies?
Cosmetically the R-1 didn't differ much from the original. The main difference is around the radiator with some R-1s have the slats removed or not fitted and also side of the radiator looked different being more like a triangle compared with the English sides. however a photo of a exported one shows the sides of the radiator like they are on the model. The other cosmetic difference would be the paint schemes
internally its a bit hit and miss. I know the pilots seat was different being a more square thing but i decided to just use the kits seat. i also know that they were fitted with holsters for a pistol in both the pilots and observers cockpits. here is a good article on the R-1 or P-1
https://en.topwar.ru/16259-istoriya-sovetskoy-aviacii-polikarpov-r-1-pervyy-seriynyy-sovetskiy-samolet.html
thank you
« Reply #17 on: April 13, 2021, 06:41:07 PM »
thank you
Thank you for the explanations and, more importantly, for the link to that interesting article/monograph!
And good luck with your spectacular build!
« Reply #18 on: April 13, 2021, 11:15:18 PM »
Nice work!  Is that the interrupter gear linkage on the lift side of the fuse under the machine gun?
« Reply #19 on: April 14, 2021, 05:16:04 AM »
Stunning work, I don't know this aircraft which makes this build even more interesting. Amazingly precise work!
« Reply #20 on: April 15, 2021, 03:00:46 AM »
yes it is, im not sure why it wasn't on the interior though
« Reply #21 on: April 15, 2021, 03:01:10 AM »
Thank you
« Reply #22 on: April 15, 2021, 03:05:17 AM »
While its not super visible on the DSLR photos mainly due to the gloss coat and it being a very slight variation i have also used my modeller licence and tried to replicate painted over soviet markings on the top wings
Next update either tommorow or on Saturday
Offline hrcoleman66
« Reply #23 on: April 15, 2021, 01:26:45 PM »
The colour and tonal variation looks perfect!
The painted over starts on the upper wing are subtle, yet effective.
Hugh
Offline Fvdm
« Reply #24 on: April 17, 2021, 08:23:56 AM »
What a great build. I like the painted over stars a lot.
« Reply #25 on: April 17, 2021, 11:25:11 PM »
Stunning paint work. The markings look exceptional as does the subtle weathering/ shading!
« Reply #26 on: April 18, 2021, 03:28:00 AM »
Thank you
Thank you, it cant be really seen in the final photo unfortunately
Hugh
Thank you
« Reply #27 on: April 18, 2021, 03:28:47 AM »
The build is now finished, check it out on the finished post section
Thank you for reading
« Reply #28 on: April 18, 2021, 05:16:34 AM »
Awesome!
