Author Topic: 1:32nd scale Hansa-Brandenburg W.20  (Read 21009 times)
Re: 1:32nd scale Hansa-Brandenburg W.20
« Reply #90 on: May 13, 2021, 10:19:40 PM »
All this work looks great, Mike.  You're usual attention to detail will certainly pay off in the end by being very visible here.
« Reply #91 on: May 14, 2021, 12:06:14 AM »
That's all the wire in the kit ? Not even close enough to build the engine/wing struts  :o Either way Mike your version turned out fantastic , looking forward on seeing the top wing mounted .
« Reply #92 on: May 14, 2021, 03:53:30 AM »
Alexis - just for you,
The upper wing is now fitted.
The ailerons as well as the tail unit have yet to be fitted.
Now onto the rigging !!
« Reply #93 on: May 14, 2021, 05:17:53 AM »
What a beauty this is becoming  Mike!
Already started taking notes on the rigging...
Looking forward to the end result.
« Last Edit: May 14, 2021, 08:01:26 AM by Rookie »
« Reply #94 on: May 14, 2021, 07:25:20 AM »
Looks Terrific as a bi plane! This is another fine piece of Modeling on a kit that lacks finesse in some areas...like that engine mount  support frame!
« Reply #95 on: May 14, 2021, 10:54:02 AM »
Thanks Mike  :) :-*
 She looks fab !!!
« Reply #96 on: May 15, 2021, 01:30:52 AM »
The rigging for the wings and ailerons is done.
'GasPatch' 1:48th metal turnbuckles with 0.08 mm diameter mono-filament and blackened 4 mm diameter tube.
Now onto the tail unit,
« Reply #97 on: May 15, 2021, 01:40:45 AM »
Great job on the rigging Mike!
And, is it me or does the gravety tank look different than in earlier pictures?
« Reply #98 on: May 15, 2021, 02:07:14 AM »
Hi Willem,
It's you  ;D - the tank hasn't changed,
« Reply #99 on: May 15, 2021, 04:47:21 AM »
The assembly all coming together really looks great Mike! The rigging on the struts and engine support frame isAwesome!
« Reply #100 on: May 15, 2021, 05:12:58 AM »
This could well be my favourite of your builds so far, it's looking like a real show stopper.
« Reply #101 on: May 15, 2021, 06:15:03 AM »
The tail unit with elevators and rudder is done.
Bracing and rudder control cables are 0.08 mm diameter mono-filament with blackened 4 mm diameter tube.
Apart from the propeller, that's the aircraft completed.
Now it's onto creating a beaching trolley and the figures,
« Reply #102 on: May 15, 2021, 07:37:31 AM »
Superb build Mike!
Offline Fvdm
« Reply #103 on: May 15, 2021, 04:21:55 PM »
Wow, what a superb build Mike. Really a masterpiece. When I look at the last pic in this post it seems like the support frame on the left side is out of position. But it could also be I'm totally wrong.
« Reply #104 on: May 15, 2021, 07:40:04 PM »
Hi Fvdm,
Yes that cross member is not parallel to the fuselage.
It was, but at some point during construction the frame tilted slightly and I didn't notice it.
Unfortunately, it's too late to rectify it now without wrecking the model :(
