Author Topic: 1:32nd scale Hansa-Brandenburg W.20  (Read 20570 times)
Re: 1:32nd scale Hansa-Brandenburg W.20
« Reply #75 on: May 04, 2021, 06:05:50 AM »
Super clean work, Mike.
I love floatplanes and I think this will be a great model.
Bye, Manni
Online Mike Norris (UK)
« Reply #76 on: May 09, 2021, 06:28:59 AM »
I've applied the decals to the model.
The base colour, despite most profiles showing it a light blue, was more probably the standard light grey.
This was 'Tamiya' Medium Sea Grey 2 (XF83) lightly airbrushed over a Dark Sea Grey (XF54) base coat.
The kit supplied lozenge decals were replaced with ‘Aviattic’ linen effect Lozenge (ATT32113).
Undersides of the flight surfaces were covered with ‘Aviattic’ linen weave effect (ATT32236).
The instrument panel was scratched using plastic card, decal from 'Airscale’ Generic WW1 instruments (AS32 WW1) and bezels from ‘Airscale’ Instrument Bezels (PE32 BEZ).
I decided to cut out and use the kit supplied markings, despite them being very fragile and not 'cookie' cut.
Light weathering was done using 'Flory Models' Dark Dirt and Grey fine clay washes.
Everything was sealed with 'Alclad' Light Sheen (ALC-311) clear coat lacquer.
Other weathering was then applied using 'AK Interactive' Kerosene (AK2039) and 'Tamiya' Weathering Master Set D  (Oil stain).
Now it's onto pre-rigging before assembly can start,
« Last Edit: May 09, 2021, 07:25:22 PM by Mike 'Sandbagger' Norris »
« Reply #77 on: May 09, 2021, 07:51:05 AM »
Must say Mike , you are making quick work with this one . She is looking fantastic !
« Reply #78 on: May 09, 2021, 11:02:14 AM »
The decals look excellent. Well done on the painting also.
« Reply #79 on: May 09, 2021, 05:04:55 PM »
Fantastic work. The colors and the naval lozenge looks great, Mike.
Bye Manni.
« Reply #80 on: May 12, 2021, 12:36:32 AM »
All of the pre-rigging has been added prior to assembly of the model.
The line used is 'Stroft' 0.08 mm diameter mono-filament with blackened 0.4 mm diameter Brass tube from 'Albion Alloy's'.
All of the lines have yet to be tensioned and turnbuckles to be painted, which can only be done after assembly of the various parts.
« Last Edit: May 12, 2021, 12:44:01 AM by Mike 'Sandbagger' Norris »
Offline kkarlsen
« Reply #81 on: May 12, 2021, 01:47:53 AM »
Beautiful work Mike!!
Kent
« Reply #82 on: May 12, 2021, 03:14:25 AM »
Oh my... how I love watching your builds. And here is another treat!
« Reply #83 on: May 12, 2021, 03:23:10 AM »
Love that rigging method, very precise work as always.
« Reply #84 on: May 12, 2021, 05:26:05 AM »
Now the fun begins,
« Reply #85 on: May 12, 2021, 06:34:40 AM »
Wow - this is coming on a treat, Mike
Good luck on the next bit!
« Reply #86 on: May 12, 2021, 07:00:53 PM »
Mike, this looks terrific! The rigging is really clever. The plane looks great. Looking for the next steps.
Bye,
« Reply #87 on: May 12, 2021, 09:35:35 PM »
That is a lot of Buckles Looking fantastic Mike!
Offline Fvdm
« Reply #88 on: May 13, 2021, 03:29:34 AM »
Nice start on the rigging.
« Reply #89 on: May 13, 2021, 10:16:26 PM »
The engine assembly and its support frame are now completed.
I've added representations of the pipes to and from the cockpit 'pulse meters', oil tank supply pipe, HT supply lead and carburettor control cable and lever.
I've also added the fuel supply pipe from the upper wing fuel tank to the carburettor, but this can't be connected until the upper wing is fitted.
I just wonder how companies like this expect modelers to be able to create the engine support frame from two pieces of wire and a rough drawing of the area, which is actually on the only 'instruction' sheet supplied.
Hey-Ho - moving on - Next up is the fitting of the upper wing,
Mike .
