Author Topic: 1:32nd scale Hansa-Brandenburg W.20  (Read 20517 times)
Online Mike Norris (UK)
« on: April 07, 2021, 12:26:07 AM »
As I'm nearing the completion of the Fokker D.II model build, I've started preparing the next model.
This will be another resin kit from 'Omega Models', which will represent the Hansa-Brandenburg W.20, Serial No:1552, photographed on the 14th of March 1918, at the seaplane experimental centre (SVK) at Warnemunde before being accepted for naval use (by the SAK).
The Hansa-Brandenburg W.20 was designed during late 1917 and early 1918  by Ernst Heinkel whilst working at Hansa-Brandenburg.
The intention for this small, unarmed spotter float plane was for it to be partially dismantled and stored in a water tight container on board the projected ‘Cruiser’ class of submarine, such as U139 and U155.
It was to be removed from its container, assembled quickly and launched whilst the submarine was on the surface.
After the flight, the submarine would surface again, the aircraft loaded, dismantled and stowed in its container, after which the submarine could submerge.
The aircraft was intended to be prepared for flight or stowing in less than 2 minutes and was to be stored inside the container which measured 20 feet long and 6 feet in diameter.
However, the intended submarines to be used were never built before the armistice and only three W.20 aircraft were built.
The first version, Ser No:1551, had only fuselage to upper wing support struts.
The second version, Ser No:1552 had interplane struts added between the wings and these struts were wire crossed braced.
In addition the span of the lower wings was increased.
The third and final version, Ser No:1553 had the interplane struts replaced by single interplane struts.
Although this design of Ernst Heinkel never saw operational service, he did design a similar aircraft in 1921, which was known as the Caspar-Heinkel U1.
Two examples were purchased by the U.S. Navy for evaluation.
This aircraft was intended to fit into a smaller space of 18 feet long and 4 feet 6 inches diameter.
The design was a cantilever wing biplane, powered by a 50 hp engine and capable of a speed of 87 mph with a climb rate of 1000 m in 6 minutes.
Four men could dismantle and stow the aircraft in only 22 seconds and reassemble it in only 31 seconds.
One of the aircraft was wrecked when being transported on a truck when the aircraft struck low hanging trees.
Interestingly Heinkel built and sold two examples to the Japanese, who subsequently followed on with this technology in WW2.
« Last Edit: April 17, 2021, 07:36:57 PM by Mike 'Sandbagger' Norris »
Re: 1:32nd scale Hansa-Brandenburg W.20
« Reply #1 on: April 07, 2021, 12:30:01 AM »
Tagging along Mike  ;)
Very cool subject matter and totally different ! ....I love it ! :)
« Reply #2 on: April 07, 2021, 03:46:02 AM »
Great choice of subject, Mike! I will be paying rapt attention! ATB, Marc
Offline hrcoleman66
« Reply #3 on: April 07, 2021, 10:31:03 AM »
What a cute little machine.
Looking forward to this!
Hugh
Offline Dave Brewer
« Reply #4 on: April 07, 2021, 03:19:20 PM »
Another excellent choice Mike-I have one half-completed but currently in the naughty corner, I'll be fascinated to see how you cope with the challenges it presents.
Dave.
« Reply #5 on: April 07, 2021, 08:48:18 PM »
I think the biggest problem with this model, apart from the quality and detail of the resin parts, is the lack of reference material available.
I can't find much, apart from a few photographs and especially for the engine installation.
Offline Fvdm
« Reply #6 on: April 09, 2021, 02:08:06 AM »
What a nice little subject. Maybe four men could dismantle and stow the aircraft in 22 secondse but they still have to wait a couple of minutes for the engine to cool down  ;D
« Reply #7 on: April 09, 2021, 06:52:10 AM »
This kit does present the modeler with challenges, to put it mildly.
The supplied kit itself comprises of parts which are solely resin and unlike many more up market companies, ‘Omega Models’ do not reinforce parts, such as wing struts, with metal rods. This makes the supplied resin struts very weak when flexed.
All of the resin parts have mold ‘flash’ that will need to be removed and larger items, such as the wings, do have some warping, which is not uncommon in resin kits.
The kit does not supply many parts required to make this an accurate model, for example an instrument panel, all of the necessary wing float struts, all of the centre engine bearer struts etc.
The lower wing one piece molding is not the correct shape according to the drawings supplied.
The kit parts have no locating pegs or holes, which can cause alignment problems during assembly.
The instructions supplied for assembling the model are virtually non-existent, being only several sheets of photo-copied data with only one section view of the fuselage internal parts.
The remaining sheets are the kit contents and basic three-view drawings and some small colour profiles.The kit instructions do not give assembly instructions, apart from the two side drawings and they only list parts with no exploded assembly views.
Also, some of the information refers to different versions of this aircraft, not the kit supplied Series 2 (1552) model.
The decals supplied are of reasonable quality but are not the normal, ‘cookie’ cut slide transfer. Instead the decals are printed on sheets of carrier which covers the entire sheets.
Therefore if used, each decal will need to be carefully cut out from its sheet before application to the model. Also the surface of these decals is easily damage, such as from being scratched, so if used, care is needed handling these decals.
The kit does supply any ground equipment, such as a basic ‘beaching’ trolley or trestles.
Anyway, The basic hull has been prepared as well as a modified 'Wings Cockpit' figure (LSK 07A).
« Reply #8 on: April 09, 2021, 09:03:05 AM »
The figure looks good in the cockpit.
« Reply #9 on: April 11, 2021, 04:52:02 AM »
Just a quick updated.
The front decking has been fitted and I've added the 'splash' rail around the edge of the hull.
Also the nose 'bump' padding to the nose, neither of which are represented in the kit,
« Reply #10 on: April 11, 2021, 08:34:39 AM »
Fine choice of the subject and a great start, as usual. I will be watching with interest.
« Reply #11 on: April 11, 2021, 11:25:19 AM »
Your usual attention to detail Mike. Well done!
« Reply #12 on: April 11, 2021, 01:48:00 PM »
Nice start!!
« Reply #13 on: April 11, 2021, 09:03:57 PM »
« Reply #14 on: April 11, 2021, 11:38:47 PM »
Very interesting project of a never seen before aircraft. Looking forward to next steps.
