Author Topic: Eduards Pfalz D.III  (Read 22646 times)
Eduards Pfalz D.III
« on: April 01, 2021, 07:32:52 AM »
With the Fokker almost done I feel like doing another quick build and it's been waaaay to long since I built a Pfalz D.III .  :)
Offline hrcoleman66
Re: Eduards Pfalz D.III
« Reply #1 on: April 01, 2021, 09:03:39 AM »
Wow!  I thought the Fokker was a quick build.  I'm still trying to get details finished on my BE12!
This will be interesting.  I don't think I've ever seen a build of this kit.
Hugh
Offline Mark A
« Reply #2 on: April 01, 2021, 10:41:51 AM »
Nice choice! I have the D.IIIa on the bench and it's going together rather well.
A bit annoying that Eduard missed the pipes going to and from the radiator in the top wing though.
But nothing good references and a bit of scratch building can't sort.
Offline phil2015
« Reply #3 on: April 01, 2021, 02:25:43 PM »
they skipped those on the albatros d iii also (but not on the dv).  it seems like a strange omission as that seems such a large part of the plane's profile.
« Reply #4 on: April 01, 2021, 03:21:44 PM »
If I was dizzy before Alexis, I’m on the floor now  ???
One of my favourite aircraft though  ;D
« Reply #5 on: April 02, 2021, 01:19:46 AM »
Nice choice, Alexis! Some speedy building going on... but great subjects! ATB, Marc.
« Reply #6 on: April 02, 2021, 01:46:05 AM »
Looking forward to another by The Queen of the Pfalz!
« Reply #7 on: April 02, 2021, 03:39:03 AM »
Another oldie but goodie.  Looking forward to this one Alexis.
« Reply #8 on: April 02, 2021, 09:15:57 AM »
Thanks guys , glad to have you all tagging along on this one .
Hugh , you are correct on that not many builds of this kit have been seen . So I hope I don't mess it up !
Mark A , I have built the D.IIIa 7 times now with 4 more still in the stash in 48 scale , enjoy the build . It's a nice kit  :)
Guy , like I said be easier if you just sit ! ;)
« Reply #9 on: April 03, 2021, 09:42:54 AM »
Spent part of the morning removing parts from their trees for clean up when I notice on the tail section , Eduard has molded the tail wing root upside down !
Not something I really want to fix with this older plastic . It's hard to sand and is or can be brittle  :( ::) . I have read reviews of this kit and no one has mentioned this ????
Offline Fvdm
« Reply #10 on: April 03, 2021, 06:04:53 PM »
Sorry to hear that Eduard made a mistake. Just sand it real carefully and it should be alright. If you think it's to brittle you can glue some styrene behind it to strengthen it.
« Reply #11 on: April 03, 2021, 07:20:55 PM »
That’s easy Alexis,
Just glue the tail plane upside down too - voilá - perfect fit!  ;D
Ps if you need any more top tips, don’t hesitate to ask  ;)
« Reply #12 on: April 03, 2021, 11:19:28 PM »
Are you saying that the root curves towards the bottom of the aircraft? If not then it is correct to have an upsweep on the leading edge  for the DIII isn't it?
« Last Edit: April 04, 2021, 01:57:20 AM by RAGIII »
« Reply #13 on: April 04, 2021, 12:55:43 AM »
Since it looks like a butt joint ::) anyway couldn't you fabricate the part in 40 thou, sand off the offending bit and glue it on - easy being an arm chair builder......
« Reply #14 on: April 04, 2021, 03:07:33 AM »
Searching in the dim, dark recesses of my mind Alexis, I think Eduard are correct. The tailplane was like that - there was a story that the Pfalz was a real favourite of balloon - busters, and the usual tactic was a screaming dive from altitude to avoid the flak, and the Pflaz was a good "diver", and then the inverted tailplane aerofoil helped pull it out of the dive at low level... Now I can simply not remember where I read all this, let me peruse the books! Regards, Marc.
