Author Topic: 1:32nd scale Fokker D.II  (Read 19731 times)
Re: 1:32nd scale Fokker D.II
« Reply #45 on: March 26, 2021, 09:02:27 PM »
Hi Fredrik,
Here's an extract from my build logs explaining 'Flory Models' clay washes, which might be of help if you decide to purchase any of the washes.
Thanks so much! I'll put it on my shopping list.
« Reply #46 on: March 27, 2021, 05:53:35 AM »
The pilot looks happier than before, Possibly because He now has that beautiful Spandau in front of him  ;D Excellent detail work as always Mike!
« Reply #47 on: March 28, 2021, 04:58:38 AM »
Ooh, some lovely details there, Mike! Enjoying this so much! Marc.
« Reply #48 on: March 28, 2021, 09:53:56 AM »
Just a quick update.
Looking at photographs it's difficult to see detail for the interplane struts on this aircraft.
Some look to be of wood construction only.
Others seem to show a tubular reinforcing tube that was fitted to the leading edge of each strut with wood aerofoil struts attached to its rear edge.
Also what appears to be four 'wrappings' of either linen or metal around each strut.
Normally strut wrapping would be linen and these were used to help prevent the wood struts from splitting under stress.
Anyway, the kit 'wrappings' were over sized so I decided to modify all eight struts.
The 'wrappings' were sanded off and the leading edge tubes, which are not represented on the kit struts, were scribed.
Base coated with 'Tamiya' Deck Tan (XF78), then clear coat sealed.
The wood areas were masked off and 'Alclad' Steel (ALC112) was airbrushed over the tubes.
Clear coated again then 'Flory Models' Dark Dirt clay wash applied.
Clear coated yet again and 1 mm wide strips were applied from the ‘Xtradecal’ Parallel Stripes (White XPS2) set.
A final clear coat was then applied to seal everything.
The cutout in the two inboard, rear interplane struts, are to allow the wing warping control lines to route from the fuselage to the outboard struts.
« Last Edit: March 28, 2021, 08:25:01 PM by Mike 'Sandbagger' Norris »
« Reply #49 on: March 28, 2021, 10:34:33 AM »
Thumbs up Mike , struts look excellent  :)
« Reply #50 on: March 28, 2021, 11:03:19 AM »
Excellent solution to the struts Mike. They look Terrific!
Offline Fvdm
« Reply #51 on: March 28, 2021, 10:02:10 PM »
That are some nice looking struts Mike.
« Reply #52 on: March 29, 2021, 04:50:07 AM »
Two of the six wing warp control lines were attached to the base of the rear interplane struts on the lower wings.
The two control lines were routed between the lower wings through twin pulleys, mounted on a support frame in front of the cockpit.
Mono-filament lone of 0.08 mm diameter and routed through 0.2 mm diameter holes above the pulleys.
'GasPatch' 1:48th One End turnbuckles fitted with 0.4 mm diameter blackened brass tube.
« Last Edit: March 29, 2021, 08:07:07 PM by Mike 'Sandbagger' Norris »
« Reply #53 on: March 29, 2021, 09:58:05 AM »
   Wonderful focus and follow through on detail Mike, it's a real pleasure to follow your progress here. No "tactical look aways" from Kit short comings and nothing but the finest solutions as always with your Builds. Nicely done!
Offline hrcoleman66
« Reply #54 on: March 29, 2021, 10:40:18 AM »
Struts and Controls looking very good.  Making notes.
Hugh
« Reply #55 on: March 29, 2021, 11:31:14 AM »
As always, excellent details Mike!
« Reply #56 on: March 29, 2021, 09:48:02 PM »
Yes, excellent details.
Offline Fvdm
« Reply #57 on: March 30, 2021, 01:56:07 AM »
« Reply #58 on: March 30, 2021, 07:50:56 AM »
I've finished pre-rigging stage now.
Thirty two lines with 'GasPatch' One End type turnbuckles and two with double ended Type C turnbuckles.
Also the Rudder and Elevators have their control lines fitted.
Tube used is blackened 0.5 mm and 0.4 mm diameter with 0.12 or 0.08 mm diameter mono-filament.
Now all I have to do is fit the anchor points to their various locations and the ten struts and upper wing can be fitted,
« Reply #59 on: March 30, 2021, 01:04:14 PM »
Excellent Mike!
