Author Topic: 1:32nd scale Fokker D.II  (Read 19765 times)
Re: 1:32nd scale Fokker D.II
« Reply #30 on: March 22, 2021, 05:42:30 AM »
Some really good details for improving this kit, Mike! Great progress and some good advice... Regards, Marc.
« Reply #31 on: March 22, 2021, 06:06:23 AM »
Great work on the skid Mike. As always the Aviattic Fabric looks excellent.
« Reply #32 on: March 22, 2021, 08:36:36 AM »
This is all really starting to pull together now !
Offline hrcoleman66
« Reply #33 on: March 22, 2021, 08:54:31 AM »
Those Aviatic decals look great!
I'd be interested to see a close up of the "Streaky" section.
Hugh
« Reply #34 on: March 22, 2021, 09:50:19 AM »
Hugh
Hi Hugh,
'Aviattic' decals laid over a gloss clear coated 'Tamiya' Deck Tan (XF55) base colour,
« Last Edit: March 22, 2021, 08:07:48 PM by Mike 'Sandbagger' Norris »
« Reply #35 on: March 25, 2021, 05:59:26 AM »
A few updates for the Fokker D.II build.
The pilot figure has been painted and is fitted into the cockpit.
Also the engine is now fitted.
The general weathering is a combination of 'Flory Models' Dark Dirt fine clay wash and 'Tamiya' Weathering Master Set A (Mud).
The engine exhaust and oil erosion on the fuselage forward side panels is 'Tamiya' Flat Aluminium (X16) stipple brushed over the green.
Then the same 'Flory Models' wash dabbed into the Aluminium painted surface.
The same technique was used for the doped linen erosion on the forward streaked decal area, but for that, 'Tamiya' Deck Tan (X55) was stippled on before the 'Flory' wash was applied.
'AK Interactive' Engine Oil (2019) was brushed at the outlet of the side panels and under the forward fuselage.
« Reply #36 on: March 25, 2021, 07:03:39 AM »
Really looking great Mike. The weathering has toned down the stark look of the streak decals and makes for a much better look!
Offline hrcoleman66
« Reply #37 on: March 25, 2021, 08:07:49 AM »
The Flory models wash really brought it to life Mike.
Looking awesome!
Hugh
« Reply #38 on: March 25, 2021, 10:16:35 PM »
Beautiful out come with the weathering Mike !
Online PrzemoL
« Reply #39 on: March 26, 2021, 12:45:19 AM »
Gorgeous modelling, as usual from your bench, Mike. I will follow this build with great interest.
« Reply #40 on: March 26, 2021, 01:29:29 AM »
Very nice and inspiring! I should get my hands on some of that Flory stuff...
« Reply #41 on: March 26, 2021, 02:45:14 AM »
Fredrik , I highly recommend it . I have been using it for about 5 years now and love it !
« Reply #42 on: March 26, 2021, 03:33:28 AM »
Some really nice weathering effects there, Mike! I like the way you have treated different metal and fabric areas with appropriate weathering... I'm learning a lot... Regards, Marc.
« Reply #43 on: March 26, 2021, 04:43:46 AM »
Hi Fredrik,
Here's an extract from my build logs explaining 'Flory Models' clay washes, which might be of help if you decide to purchase any of the washes.
Flory Model clay washes:
The washes I tend to use are the ‘Flory Models’ Clay Wash ’Grime’ and ’Dark Dirt’, which come in various shades and consist of a suspended and very fine clay pigment. They are brushed over the surface to be weathered and dry in around 30 minutes. When dry, use either a piece of good, absorbent kitchen roll or a soft brush to remove as much of the clay wash as you need to achieve the desired effect. The kitchen roll can be used dry or very slightly dampened. If dampened, the dried clay is re-activated and the clay wash can be more easily be removed or worked as
required.
First I seal the surface with an airbrushed semi-matte clear coat, such as ‘Alclad’ Light Sheen (ALC-311), which dries quickly. A gloss coat tends to stop the clay wash ‘gripping’ the surface when it is  applied and it can run off or just puddle. A more matte coat can cause the clay wash to ‘grip’ too much, making it difficult to remove or even to wash it off completely.
NOTE 1: The more glossy the applied sealing coat is, the more the chance there is that the applied ’Flory’ clay wash will not spread fully, but rather form puddles or beads of wash.
If this happens, add a few drops of ordinary kitchen washing up liquid to the clay wash. This will break the surface tension of the wash, allowing it spread fully.
NOTE 2: Always decant the amount of clay wash you need, rather than dipping the brush directly into the wash bottle. Dipping into the wash bottle can transfer contaminants from the brush into the wash, will can cause the wash to become thick and unusable.
NOTE 3: When a sealing coat is applied over areas treated with clay wash weathering, the
intensity of the applied wash tends to darken. This should be considered when removing the clay wash, otherwise the final effect may appear too dark.
NOTE 4: ‘Flory’ current range of washes are: Dark Dirt, Grime, Black, Light (white), Mud, Sand, Rust and Concrete. All of these washes can be mixed to create many colour shades for different weathering finishes.
To apply the clay wash is just a matter of brushing all over the surface to be weathered.
It doesn’t matter really how much is applied as it can be left on for any period, as it is easily removed without any effect on the surface underneath.
If you don't achieve your desired effect, you can wash it all off and start again.
Use a soft brush or absorbent kitchen roll, which are dry or very slightly dampened, to brush or wipe off the clay wash in the direction of airflow over the aircraft.
Even then dab them onto a dry piece of the paper, until they are almost dry. Any wetter and you’ll find that you are removing too much of the clay wash.
If that happens you can re-apply the wash and start again.
f you’re not happy with the final effect, you can easily remove the clay wash by brushing with a wet brush or even airbrush water over the surface.
Dry off the surfaces washed and then re-apply the clay wash and try again until you are satisfied.
The technique is to 'damp' brush or wipe over the surface to re-activate the clay wash and at the same time, to smear it over areas that had no clay wash.
It’ll dry within 30 minutes.
Then remove as much you want until you get the desired effect.
Once finished, run the brush under a tap to rinse out any residual clay pigments.
Finally, seal the surface with airbrushed clear coat of your choice, which will seal in the applied clay wash.
« Last Edit: March 26, 2021, 05:00:55 AM by Mike 'Sandbagger' Norris »
« Reply #44 on: March 26, 2021, 06:07:12 AM »
The single ‘GasPatch’ early LMG ‘Spandau’ 08 has been fitted.
This required modification of both the gun and fuselage decking panel.
I used the 'GasPatch' ammunition belt instead of the kit supplied photo-etch part.
I also had to scratch the empty ammunition belt chute as the kit does not include the chute?
The eight 'transportation' posts have also been added to the fuselage sides and lower wings.
Now onto the struts then pre-rigging,
« Last Edit: March 26, 2021, 07:37:54 AM by Mike 'Sandbagger' Norris »
