Author Topic: Roden SPAD VII 19 Sq. RFC 1/32nd scale:SPAD VII Lafayette:Nieuport 28 94th Aero  (Read 110586 times)
Great progress on a dicey task, Rick.  And thanks to Alexis and yourself for putting this in your build thread.
Very convincing results on the double wires Rick  :) I will also use Tamiya thin glue , but this can ruin your work very quickly if too much is applied and I have had that happen before  ::)
Those are going to look really nice once painted up which I'm looking forward to seeing  :)
Thanks Alexis! I didn't mention that on the first Day I was using Tamiya Extra Thin very sparingly to help with the process. Just a very small amount in areas that were giving Me problems. For the most part I was using the Tamiya setting solution. NOT paying attention I mixed up the Cement with the Setting solution.  Luckily I was able to remove the Gooey Mess without any damage to the wires  ::) That is one reason I am so happy that your tip on the X20A worked so well on day two! I did not have to open the Tamiya Glue bottle  8)
Thanks Ken. I am pretty sure that this Method has worked.... for Me at Least! Like I said Alexis was a life saver with the X20A tip!
« Last Edit: April 13, 2021, 12:41:16 AM by RAGIII »
Hi Rick ,
I have tried Tamiya's decal setting system with mixed results , find that they really don't work all that well even on their own decals . My go too is Microscale's Super Sol and Sol . If those don't work then I which switch and use the Tamiya thinner or their liquid glue .
Superb work as always Rick, I think your high standard has even gone up a notch since I went on leave last Summer. That rigging is amazing!
Thanks Richie. I will post a couple of photos later of the latest work on this one.
Here are the promised photos. I have to admit there are a few bumps and lumps but I am satisfied with My first use of this technique. If I do it again I will do better  8)
Hello, Rick -
Your Roden N.28 looks great to me - and regarding the wires I don't suppose the real ones were as neat as we would like to think.
No lumps or bumps are apparent to me Rick, all I can see is a very fine model of a beautiful little biplane. I always admire your French camouflage painting. If the next one is going to be even better I can't wait to see it!
I agree with Dave: sometimes we try to make perfect models to represent far from perfect subjects whereas a little imperfection here and there would probably be more representative of the real thing. I would be very happy with that.
That is a really nice outcome! It is soooo beautiful :-*
I need also this Nieuport type in my collection.
Offline Fvdm
I think you did  real great job on this. If it's the painting, the rigging or something else, it all looks real nice to me.
Hi Rick your Ni28 is a beauty!
Rick , those double covered wires turned out fantastic ..well done on a awesome build ! :)
Gotta agree with Alexis on the double wires and the build Amigo.
You’ve got some patience Rick!
Looks great!
